LTSpice installs but does not run (Win11Pro, HP845 laptop)
Product Number: LT S
Software Version: 26.0.2
I have an HP laptop model 845 running Windows 11 Pro. I am trying to replace an older LTSpice installation (v17.11) with v26.0.2. It installs using Powershell (admin level), but will not run after install.
I used the verbose option as suggested in another thread, my install command:
msiexec /i "C:\Users\mtarr\Desktop\Installer - 2026-05-14 v26.0.2\LTspice64.msi" /L*v C:\Users\mtarr\Desktop\MyAppInstall.log
I am including the install log. Any help would be appreciated.
Thank you,
Morty Tarr
0250.MyAppInstall.log
  • Hi  ,
    We'll look at the log, thanks.
    In the meantime, there is a chance this is the problem. Can you also send your LTspice.ini. It should be here: Property(C): AppDataFolder = C:\Users\[user]\AppData\Roaming\
    Actually, can you search for all LTspice.ini files on your system, if there are others floating around?
    mike
  • Hi  ,
    FYI. There are two reasons for LTspice "not to start" that cover most cases:
    • The .ini is corrupted
    • LTspice cannot find its libraries
    mike
  • Hi Mike,
    At the location you suggested there were 2 files. I am attaching them both. I searched the rest of the C: drive and there are no other instances of ltspice,ini.
    I'll try to install again, but I don't think we changed anything.
    If I do fresh install on the C: drive as usual, how will LTSpice not find it's libraries? I suspect a permissions error somewhere.
    Thank you
    Morty
    I can't find attach - so here's the data inline:
    file:  LTspice.ini
    [Options]
    UUID=16829951328287107078
    CaptureAnalytics=false
    LastRunVersion=26.0.2
    HighestRunVersion=26.0.2
    Solver=0
    DisableSchSubdirPlaceComp=false
    ShowCheckSum=false
    SymbolSearchPathDisabled=false
    LibrarySearchPathDisabled=false
    SpicePriority=1
    PlotPriority=1
    LastFileTypeOpened=0
    LastControlPanelPage=-1
    Tabstopwidth=4
    grid=off
    GenerateExpandedListing=false
    DefaultTrtol=2
    DefaultTrapIntegration=true
    DefaultDoAntiTrapRinging=false
    TSKbypass=false
    Accept_3k4_Notation=true
    NoJFETtempAdjIsr=false
    AsciiRawFile=false
    DoRelinearization=false
    DoQuadraticWaves=false
    RelinIAbsTol=1e-09
    RelinRelTol=0.0025
    RelinVAbsTol=1e-05
    RelinearWindowPnts=1024
    CompressTranOnly=true
    SaveDeviceCurrents=true
    SaveSubcircuitNodeVoltages=false
    SaveSubcircuitDeviceCurrents=false
    saveOneCurrentPerDevice=false
    ShowSchematicGrid=false
    OrthogonalDrag=false
    AutoPan=true
    DirectCompPinShorts=false
    MinInductorDamping=true
    UseClocktoReseedMC=false
    EnableBetaOptimizations=false
    BoldSchFont=true
    ShowTitleBox=true
    ReverseMouseWheelScroll=false
    DefaultDeviceModels=true
    DefaultDeviceLibraries=true
    EnableWindowTabs=true
    SchFontSize=28
    SchematicFont=3
    PenWidth=1
    DataPenWidth=1
    CursorThickness=1
    WindowSize=0 0 0 0
    ToolBarStyle=0
    ToolBarIconSize=1
    AutoSaveOnSim=0
    MDIbackgroundImage=1
    AutoDeleteRawFiles=0
    DraftCursorType=0
    FastAccessRAM=0.4
    WaveformViewerFont=0
    WaveformViewerFontSize=10
    WaveformViewerBoldFont=true
    UseXORcursor=false
    RawCursorType=0
    MonochromePrinting=true
    NoGreekMus=false
    RadianMeasure=false
    DefaultTileType=true
    UseRawTempDir=false
    WarnOnNoIndRser=false
    [Colors]
    Grid=6579300
    InActiveAxis=9868950
    WaveColor0=0
    WaveColor1=11513775
    WaveColor2=65280
    WaveColor3=16711680
    WaveColor4=255
    WaveColor5=11513600
    WaveColor6=16711935
    WaveColor7=8421504
    WaveColor8=32768
    WaveColor9=11468800
    WaveColor10=32943
    WaveColor11=8388736
    WaveColor12=128
    WaveColor13=44975
    SchematicColor0=16711680
    SchematicColor1=16711680
    SchematicColor2=8323072
    SchematicColor3=16711680
    SchematicColor4=12648447
    SchematicColor5=0
    SchematicColor6=0
    SchematicColor7=0
    SchematicColor8=13107200
    SchematicColor9=16711680
    SchematicColor10=65535
    SchematicColor11=0
    SchematicColor12=12632256
    SchematicColor13=13107200
    NetlistNormalTextColor=0
    NetlistCommentTextColor=32768
    NetlistDotcmdTextColor=16711680
    NetlistBackgroundColor=16777215
    ContinuationLineColor=255
    [SchKeyBoardShortCut]
    Configure_Analysis=A
    Run_Simulation=Alt+R
    Halt_Simulation=Alt+S
    View_SPICE_Error_Log=Ctrl+L
    Zoom_Area=Z
    Zoom_Back=Shift+Z
    Zoom_to_Fit=Space
    Draw_Wire_Mode=W
    Place_Ground=G
    Place_Voltage_Source=V
    Place_Current_Source=I
    Place_Resistor=R
    Place_Capacitor=C
    Place_Inductor=L
    Place_Diode=D
    Place_Component=P
    Place_Netname=N
    Place_Comment_Text=T
    Place_SPICE_Directive=. >
    Move_Mode=M
    Drag_Mode=S
    Rotate=Ctrl+R
    Mirror=Ctrl+E
    Delete_Mode=Backspace
    Duplicate_Mode=Ctrl+C
    Undo=Ctrl+Z
    Redo=Ctrl+Shift+Z
    Draw_Lines=(none)
    Draw_Rectangles=(none)
    Draw_Circles=(none)
    Draw_Arcs=(none)
    Schematic_Grid=Ctrl+G
    Unconn_Pin_Marks=Ctrl+U
    Text_Anchor_Marks=Ctrl+A
    Reset_T_0=0
    Place_BUS_Tap=B
    Place_COM=Alt+G
    [AsyKeyBoardShortCut]
    Object_Anchors=O
    Place_Pin=P
    Move_Mode=M
    Drag_Mode=S
    Undo=Ctrl+Z
    Redo=Ctrl+Shift+Z
    Draw_Lines=L
    Draw_Rectangles=R
    Draw_Arcs=A
    Draw_Circles=C
    Rotate=Ctrl+R
    Mirror=Ctrl+E
    Attribute_Editor=Ctrl+A
    Attribute_Window=Ctrl+W
    Zoom_Back=Shift+Z
    Zoom_In=Z
    Zoom_to_Fit=Space
    Show_Pin_Table=(none)
    [RawKeyBoardShortCut]
    Zoom_to_Fit=Space
    Zoom_Area=Z
    Zoom_Back=Shift+Z
    Vertically_Autorange=Ctrl+Y
    Redraw_Window=F5
    Toggle_Grid=Ctrl+G
    Add_Trace=A
    Add_Pane=P
    Add_Pane_Below=B
    Move_Pane_Up=U
    Move_Pane_Down=D
    Undo=Ctrl+Z
    Redo=Ctrl+Shift+Z
    Open_Plot_Settings_File=O
    Reload_Plot_Settings_File=Ctrl+Space
    Place_trace_cursor=C
    Clear_all_cursors=Shift+C
    Label_cursor_position=L
    Place_text_on_the_plot=T
    Draw_an_arrow_on_the_plot=(none)
    Draw_a_line_on_the_plot=I
    Draw_a_box_on_the_plot=R
    Draw_a_circle_on_the_plot=(none)
    Annotation_Line_Style/Color=(none)
    Copy_Plot_Annotations=Ctrl+C
    Move_Plot_Annotations=M
    Drag_Plot_Annotations=S
    Select_Steps=Shift+S
    [NetKeyBoardShortCut]
    Goto_Line_Number=Ctrl+G
    Undo=Ctrl+Z
    Redo=Ctrl+Shift+Z
    file:  LTspice_20260516_154930.ini
    [Options]
  • Hi  ,
    I don't see anything strange there. It does look like it had to upgrade your .ini to unicode. Not unusual.
    Can you list the exact steps you use to install. I.e.
    1. I logged in as Amin
    2. I installed and chose "Server" or "For me" or "For All"
    3. I logged out
    4. Logged in as me
    5. Tried to Start LTspice
    Is this a new machine with files from old machine (that ran LTspice XVII)?
    Zip any files you want to share and simply drag to the reply window.
    mike
  • Hi Mike,
    Here's the process I used to install LTSpice v26.0.2:
    Logged in as user (mtarr)
    Opened an elevated CMD window (admin rights)
    input path the LTSpice64.msi file in CMD window.
    Hit return, installer started up.
    Selected Install for All Users
    Everything finished as if nothing's wrong.
    Still in user account.
    LTSpice shortcut has the admin symbol on it.
    LTSpice would not run from user account.
    Switched to admin account.
    LTSpice runs from admin account.
    I will try to upload the CBS log separately (in case it fails).
    Thank you for your help!
    -Morty
    BTW: Are any attachments allowed? (I have the version that includes pictures that I would like to send - .pdf and .docx) - could convert to almost any allowed format.
  • Hi  ,
    Interesting. Have you tried installing without elevating? Or, can you not run an installer on that machine without elevating?
    Have you tried "Server" install instead off "for all"?
    Yes, best to zip them up and drag to this window.
    mike
  • Hi Mike,
    I installed the server version today from the user account without elevating (just clicked on the .msi file for v26.0.2). Same result as before - it runs from the admin account but is blocked by the user account.
    Is there a way to instantiate a run with a verbose log? It seems like something is blocking it from running in user mode. Also, please resend the correct usage of the verbose command for install, I could not locate the specific directions today.
    Thank you for your patience with this. I bought this specific laptop last year to run LTSpice almost as fast as my desktop. I was using the outdated v17.11 at that time because I had to correlate results with previous work.
    I have not tried to re-install v17, but there was no problem when I first installed it. The initial v26 install wiped it out.
    -Morty
  • Hi Mike,
    I tried to re-install the older version 17.1.11 from the user account. It worked, I can run it from the user account - no issues.
    So I'm thinking that something changed in the Windows installer since then.
    I thought this would be a good datapoint.
    -Morty
  • Hi  ,
    This might be a case where a screen share would do the trick. If you are willing, I will set it up.
    mike
  • Hi  ,
    msiexec /i "C:\MyPackages\LTspice64.msi" /L*V "C:\Logs\InstallerLog.log
