Description above is from (I thought) a related post - ignore
LTSpice v26.0.1 can't seem to find add-in (user) library files - I've tried using the 'inc' statement and the '.lib' statement with a full path, but the simulation aborts and returns a 'file not found' message with just a '.lib <modelname>.lib' reference (i.e. no path). I've played with symbol and library search paths in settings, putting the library file in different locations, and reorganizing a slightly-chaotic folder structure for downloaded files and libraries. Nothing seems to work.
I did see a related post for someone with same/similar issues on MacOS. The solution was to revert back to v24.x (under emulation environment) and then the library was found. Also suggested was to put the full model in the simulation (schematic). I'm trying to use a pulse transformer from Wurth,
Has something broken here?
