FRA analysis of example circuit LTC3722-1
Product Number: LTC3722-1
Software Version: LTSpice 26.0.1
We are currently attempting to simulate Frequency Response Analysis (FRA) for the LTC3722-1 using LTspice. However, we are unable to obtain the Bode plot waveforms in the respective window, even when using the example applications available in the LTspice library.
We have also followed the instructions provided in the LTspice help documentation, but the issue persists.
Could you please assist us in resolving this? Your guidance would be greatly appreciated.
Thank you for your support, and we look forward to your response.8865.CH-1 Design PSFB design fra .asc
Parameter
Specification
Reference / Notes
Input Voltage Range
16 VDC – 34 VDC
Input Voltage (Nominal)
28 VDC
28 VDC Bus
Output Voltage Range
1 VDC – 5 VDC (Adjustable)
Via 10 kΩ Linear POT
Output Voltage Tolerance
±10%
Across adjustable range
Output Current (Continuous)
20 A
100% rated load
Output Current (Overload)
22 A (110%)
Pulse-by-pulse current limit (CS pin)
Output Current (Shutdown)
24 A (120%)
AUTO-RESTART hiccup mode
Maximum Output Power
100 W
At 5 V / 20 A
Target Efficiency
≥ 93%
At full load, nominal input
Output Ripple (Vpp)
≤ 50 mVpp
At 5 V / 20 A output
Max Effective Duty Cycle
80% (D_eff)
At V_in,min, V_out = 5 V
Switching Frequency
100 kHz
CH-1 clock
Isolation Voltage
1500 VDC min (Rev B)
 2×Vin,max+1000V
Thread Notes
