LTSpice Version Differences
The user encountered inconsistent temperature sweep results between LTspice 24.0.12 and 26.0.1. The issue was resolved by using the recommended syntax '.step temp -55 125 10' to step the temperature from -55°C to 125°C in 10°C increments. The user also provided a ZIP file with the circuit for further review.
Product Number: LTspice
Software Version: 24.0.12 and 26.0.1
I am seeing different results with the same .asc circuit in different LTspice versions:
LTspice 24.0.12: V(ntc) changes with temperature and the comparator output switches at a threshold (as expected).
LTspice 26.0.1: V(ntc) and the computed NTC resistance look almost constant (flat plot), so V(out) does not change.
What is the recommended way to make this temperature sweep consistent across versions?
