LTspice Ascend/Descend Shortcut Key
The user inquired about shortcut keys for hierarchical navigation in LTspice version 26.0.1. The final answer confirmed that there are no dedicated shortcut keys for this function, but it is a feature under consideration. The user currently uses double-clicking to descend and CTRL+F4 to ascend by closing the current tab.
Product Number: N/A
Software Version: Ver (x64): 26.0.1
Hi!
Question is regarding LTspice shortcut keys -- is there a shortcut key to navigate hierarchically across the LTspice schematic?
On version 26.0.1, I don't see shortcut keys to descend or ascend blocks (Tools > Settings > Schematic tab > Keyboard Shortcuts.
Descending has a workaround through double-clicking the block symbol.
Ascending on the otherhand does not have a workaround. I press CTRL+F4 to close the current schematic tab and (hopefully) bring up the last active tab which is usually 1 hierarchy higher than the closed tab.
Can this be configured manually?
Thanks!
Cheers,
Gen
