I want to use the system CN0185 specifically the filter at the end for a school project but i cant seem to open it and it only shows me this error message:
What can i do in this situation?
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTspice
Production
LTspice® is a powerful, fast, and free SPICE simulator software, schematic capture and waveform viewer with enhancements and models for improving the simulation...
LTspice on Analog.com
AD8646
Production
The AD8646 and the AD8647 are the dual, and the AD8648 is
the quad, rail-to-rail, input and output, single-supply amplifiers
featuring low offset voltage...
Datasheet
AD8646 on Analog.com
PaulCA - Moved from Differential Amplifiers & ADC Drivers to LTspice. Post date updated from Saturday, January 17, 2026 1:00 PM UTC to Tuesday, January 20, 2026 12:47 AM UTC to reflect the move.
PaulCA - Moved from Differential Amplifiers & ADC Drivers to LTspice. Post date updated from Tuesday, January 20, 2026 12:47 AM UTC to Tuesday, January 20, 2026 12:47 AM UTC to reflect the move.
AndrewDide Unfortunately, that .asc file in the CN0185 file package is a PADs file: https://help.solidworks.com/2022/English/SolidWorks/circuitworks/c_pads_ascii_format.htm
That said, we have a fiew tools that might help you create a schematic that can be exported to LTspice.
- https://tools.analog.com/en/filterwizard/
- https://tools.analog.com/en/signalchaindesigner/
If you want to try to build this circuit using Filter Wizard, the circuit note gives some clues about what the parameters to give Filter Wizard:
Then - in the components selection view, change the supplies to a single 5V supply, and change out the automatically chosen op amps with the AD8646:
Keep working on your design, until you are ready to generate LTspice files at the last tab view:
Hopefully this helps you make some progress.
-Anne
