How to make model for toroidal transformer and associate it to a symbol
Product Number: OP1177
Software Version: 24.1.10
I am new in this. Just learning, I found that a coil non isolated circuit for small current can produce 4 times more current than a two coils transformer with same inductance. I don't know if it is correct. The isolation is relative because a resistor blow out is less probable that get in conduction than a transformer in my opinion. Maybe simulation that i did fail in the model that i used, in length and section despite i use inductance value length of pathway is not defined just LCR. I found the model in a page of a person called Bordonynov I am asking about any information to how I can do a model of a toroidal small transformer and how to associate it to a symbol. Also any information that can consider useful about this kind of simulation.
These are the simulations in question.
voltage regulator supply2amps.zip
voltage regulator supply2ampstrafo.zip
I did other with a modulator with a 555 without any efficiency improve
Edit Notes
Added another circuit with modulator.
[edited by: DarioLobos at 3:06 PM (GMT -5) on 24 Nov 2025]
  • Hi  ,
    I can't help you with evaluating your solution, or the Bordonynov library for that matter, but I might be able to help you create a symbol.
    mike
  • Yes. Many thanks The only way simple that found to improve efficiency is a very big capacitor. I am trying to check with doing something in the primary because current is always the same with any load. Two mosfet is a complicated circuit to a small transformer so. I was thinking to use a triak and cut peaks like a dimmer of a lamp across an optocpuple. I tried to use .model CSW to simulate a triac but didn't work. So the help of put a correct model in a simbol is very welcome, specially the triac.
    Mnay thanks.again.
    This are the circuits and simulations. last one is the one with the triac that I want to simulate.
  • This is the circuit with an autotransformer. both need to regulate current in primary or add a resistor for the usage in the primary so i will need to check the triac.with an autotransformer, non isolated circuit, can easy use mosfet instead of a triac.
  • Thanks I seen a video that teach me how to set up the model library for a triac :
    https://youtu.be/lRz1gql-BWw?si=yfZKDRROmHYxjCml
    and I could simulate my circuit and this step is finished the power supply vary form 15 watts in low load and 90 watts at 2 amps 12 volts load,  Attached is the simulation that shows power averages,
    Then I need to do 5 volts from this 12 and 3.1 volts for that i will use an auto transformer and a modulator that I designed with an NE555 the circuits are atttached I just to set up proper resistors for the needed voltages. The 555 supply signal for the coil and sense it after it.
