IsWine.dll
Software Version: 24.1.10
I'm running Parallels on a Mac.
I download LTSpice and the installer starts.
It fails and says a dll is missing, but it doesn't give me any clue how to fix it.
Fatal error with IsWine.dll
It says contact my system administer, but that's me.
Here is the log file:
=== Verbose logging started: 9/21/2025 19:00:04 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (0C:38) [19:00:04:080]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (0C:04) [19:00:04:102]: Resetting cached policy values
MSI (c) (0C:04) [19:00:04:102]: Machine policy value 'Debug' is 0
MSI (c) (0C:04) [19:00:04:102]: ******* RunEngine:
******* Product: \\Mac\Home\Downloads\LTspice64.msi
******* Action:
******* CommandLine: **********
MSI (c) (0C:04) [19:00:04:104]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (c) (0C:04) [19:00:04:105]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (0C:04) [19:00:04:106]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (c) (0C:04) [19:00:04:111]: Access database with Impersonation
MSI (c) (0C:04) [19:00:04:330]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (0C:04) [19:00:04:671]: SOFTWARE RESTRICTION POLICY: Verifying package --> '\\Mac\Home\Downloads\LTspice64.msi' against software restriction policy
MSI (c) (0C:04) [19:00:04:671]: SOFTWARE RESTRICTION POLICY: \\Mac\Home\Downloads\LTspice64.msi has a digital signature
MSI (c) (0C:04) [19:00:05:026]: SOFTWARE RESTRICTION POLICY: \\Mac\Home\Downloads\LTspice64.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (0C:04) [19:00:05:090]: Cloaking enabled.
MSI (c) (0C:04) [19:00:05:090]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (0C:04) [19:00:05:095]: End dialog not enabled
MSI (c) (0C:04) [19:00:05:095]: Original package ==> \\Mac\Home\Downloads\LTspice64.msi
MSI (c) (0C:04) [19:00:05:095]: Package we're running from ==> C:\Users\loren\AppData\Local\Temp\8b5dcb.msi
MSI (c) (0C:04) [19:00:05:101]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (0C:04) [19:00:05:105]: APPCOMPAT: looking for appcompat database entry with ProductCode '{84E30485-8D73-4034-96C3-7D676700A60B}'.
MSI (c) (0C:04) [19:00:05:106]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (0C:04) [19:00:05:117]: MSCOREE not loaded loading copy from system32
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'TransformsSecure' is 0
MSI (c) (0C:04) [19:00:05:121]: User policy value 'TransformsAtSource' is 0
MSI (c) (0C:04) [19:00:05:121]: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'DisablePatch' is 0
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'DisableMsi' is 0
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (0C:04) [19:00:05:121]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (0C:04) [19:00:05:121]: Running product '{84E30485-8D73-4034-96C3-7D676700A60B}' with user privileges: It's not assigned.
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (0C:04) [19:00:05:121]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (0C:04) [19:00:05:123]: APPCOMPAT: looking for appcompat database entry with ProductCode '{84E30485-8D73-4034-96C3-7D676700A60B}'.
MSI (c) (0C:04) [19:00:05:124]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (0C:04) [19:00:05:142]: Transforms are not secure.
MSI (c) (0C:04) [19:00:05:142]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\loren\Downloads\LTspiceInstall.log'.
MSI (c) (0C:04) [19:00:05:142]: Command Line: CURRENTDIRECTORY=C:\Users\loren CLIENTUILEVEL=0 CLIENTPROCESSID=9484
MSI (c) (0C:04) [19:00:05:142]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1D897F0D-7E72-4F39-A451-735AC8C2D017}'.
MSI (c) (0C:04) [19:00:05:143]: Product Code passed to Engine.Initialize: ''
MSI (c) (0C:04) [19:00:05:143]: Product Code from property table before transforms: '{84E30485-8D73-4034-96C3-7D676700A60B}'
MSI (c) (0C:04) [19:00:05:143]: Product Code from property table after transforms: '{84E30485-8D73-4034-96C3-7D676700A60B}'
MSI (c) (0C:04) [19:00:05:143]: Product not registered: beginning first-time install
MSI (c) (0C:04) [19:00:05:143]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (0C:04) [19:00:05:143]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (0C:04) [19:00:05:143]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (0C:04) [19:00:05:144]: Adding new sources is allowed.
MSI (c) (0C:04) [19:00:05:144]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (0C:04) [19:00:05:144]: Package name extracted from package path: 'LTspice64.msi'
MSI (c) (0C:04) [19:00:05:144]: Package to be registered: 'LTspice64.msi'
MSI (c) (0C:04) [19:00:05:145]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (0C:04) [19:00:05:145]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (0C:04) [19:00:05:145]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (0C:04) [19:00:05:145]: Running product '{84E30485-8D73-4034-96C3-7D676700A60B}' with user privileges: It's not assigned.
MSI (c) (0C:04) [19:00:05:145]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\loren'.
MSI (c) (0C:04) [19:00:05:145]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (0C:04) [19:00:05:145]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '9484'.
MSI (c) (0C:04) [19:00:05:145]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (0C:04) [19:00:05:145]: TRANSFORMS property is now:
MSI (c) (0C:04) [19:00:05:145]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '450'.
MSI (c) (0C:04) [19:00:05:149]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming
MSI (c) (0C:04) [19:00:05:149]: SHELL32::SHGetFolderPath returned: C:\Users\loren\Favorites
MSI (c) (0C:04) [19:00:05:149]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (0C:04) [19:00:05:150]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Documents
MSI (c) (0C:04) [19:00:05:150]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Local
MSI (c) (0C:04) [19:00:05:151]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Pictures
MSI (c) (0C:04) [19:00:05:152]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (0C:04) [19:00:05:152]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (0C:04) [19:00:05:152]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (0C:04) [19:00:05:154]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (0C:04) [19:00:05:154]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (0C:04) [19:00:05:155]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Desktop
MSI (c) (0C:04) [19:00:05:156]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (0C:04) [19:00:05:156]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (0C:04) [19:00:05:158]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 32
MSI (c) (0C:04) [19:00:05:165]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
MSI (c) (0C:04) [19:00:05:165]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
MSI (c) (0C:04) [19:00:05:165]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (0C:04) [19:00:05:166]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (0C:04) [19:00:05:166]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Loren Carpenter'.
MSI (c) (0C:04) [19:00:05:166]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\loren\AppData\Local\Temp\8b5dcb.msi'.
MSI (c) (0C:04) [19:00:05:166]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is '\\Mac\Home\Downloads\LTspice64.msi'.
MSI (c) (0C:04) [19:00:05:166]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (0C:04) [19:00:05:166]: EEUI - Running MsiEmbeddedUI code
MSI (c) (0C:98) [19:00:05:405]: Cloaking enabled.
MSI (c) (0C:98) [19:00:05:405]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (0C:98) [19:00:05:405]: Connected to service for CA interface.
MSI (c) (0C!34) [19:00:06:666]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:666]: PROPERTY CHANGE: Adding CHAINERUIPROCESSID property. Its value is '10648Chainer'.
MSI (c) (0C!34) [19:00:06:666]: PROPERTY CHANGE: Adding AI_CLIENTPROCESSID property. Its value is '10648'.
MSI (c) (0C!34) [19:00:06:712]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
MSI (c) (0C!34) [19:00:06:713]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:794]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '603'. Its new value: '1100'.
MSI (c) (0C!34) [19:00:06:795]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '603'. Its new value: '1100'.
MSI (c) (0C!34) [19:00:06:795]: PROPERTY CHANGE: Modifying WindowsBuild property. Its current value is '9600'. Its new value: '26100'.
MSI (c) (0C!34) [19:00:06:795]: PROPERTY CHANGE: Adding AiArm64 property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:800]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
MSI (c) (0C!34) [19:00:06:800]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:883]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
MSI (c) (0C!34) [19:00:06:884]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:959]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '192'.
MSI (c) (0C!34) [19:00:06:959]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '200'.
MSI (c) (0C!34) [19:00:06:983]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
MSI (c) (0C!34) [19:00:06:983]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
MSI (c) (0C!34) [19:00:06:984]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
MSI (c) (0C!34) [19:00:06:991]: Note: 1: 2205 2: 3: AI_ControlConditionEx
MSI (c) (0C!34) [19:00:06:992]: Note: 1: 2228 2: 3: AI_ControlConditionEx 4: SELECT `Dialog_`,`Control_`,`Action`,`Condition` FROM `AI_ControlConditionEx`
MSI (c) (0C!34) [19:00:06:997]: Note: 1: 2205 2: 3: AI_EventMappingEx
MSI (c) (0C!34) [19:00:06:997]: Note: 1: 2228 2: 3: AI_EventMappingEx 4: SELECT `Dialog_`,`Control_`,`Event`,`Attribute` FROM `AI_EventMappingEx`
MSI (c) (0C!34) [19:00:07:192]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (0C!34) [19:00:07:192]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'PrepareDlg'
MSI (c) (0C!34) [19:00:07:233]: PROPERTY CHANGE: Adding AI_HWND_EUI property. Its value is '1115370'.
MSI (c) (0C:04) [19:00:07:266]: PROPERTY CHANGE: Adding MSICLIENTUSESEMBEDDEDUI property. Its value is '1'.
MSI (c) (0C:04) [19:00:07:267]: PROPERTY CHANGE: Adding SourceDir property. Its value is '\\Mac\Home\Downloads\'.
MSI (c) (0C:04) [19:00:07:267]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is '\\Mac\Home\Downloads\'.
MSI (c) (0C:38) [19:00:07:268]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 9/21/2025 19:00:07 ===
MSI (c) (0C:04) [19:00:07:277]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (c) (0C:04) [19:00:07:277]: Machine policy value 'DisableRollback' is 0
MSI (c) (0C:04) [19:00:07:277]: User policy value 'DisableRollback' is 0
MSI (c) (0C:04) [19:00:07:277]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (0C:04) [19:00:07:278]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '1100'. Its new value: '601'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '1100'. Its new value: '601'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
MSI (c) (0C:04) [19:00:07:278]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '1'. Its new value: '0'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '601'. Its new value: '600'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '601'. Its new value: '600'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '600'. Its new value: '502'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '600'. Its new value: '502'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '502'. Its new value: '501'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '502'. Its new value: '501'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '501'. Its new value: '500'.
MSI (c) (0C:04) [19:00:07:279]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '501'. Its new value: '500'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '1'. Its new value: '0'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '500'. Its new value: '400'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '500'. Its new value: '400'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '400'. Its new value: '1100'.
MSI (c) (0C:04) [19:00:07:280]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '400'. Its new value: '1100'.
MSI (c) (0C:04) [19:00:07:287]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (0C:04) [19:00:07:287]: Doing action: INSTALL
Action 19:00:07: INSTALL.
Action start 19:00:07: INSTALL.
MSI (c) (0C:04) [19:00:07:288]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (0C:04) [19:00:07:289]: Running UISequence
MSI (c) (0C:04) [19:00:07:289]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (0C:04) [19:00:07:289]: Doing action: AI_SET_INSTALL
Action 19:00:07: AI_SET_INSTALL.
Action start 19:00:07: AI_SET_INSTALL.
MSI (c) (0C:04) [19:00:07:290]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
Action ended 19:00:07: AI_SET_INSTALL. Return value 1.
MSI (c) (0C:04) [19:00:07:290]: Skipping action: AI_SET_MAINT (condition is false)
MSI (c) (0C:04) [19:00:07:290]: Skipping action: AI_SET_RESUME (condition is false)
MSI (c) (0C:04) [19:00:07:290]: Skipping action: AI_SET_PATCH (condition is false)
MSI (c) (0C:04) [19:00:07:290]: Skipping action: AI_CORRECT_INSTALL (condition is false)
MSI (c) (0C:04) [19:00:07:290]: Doing action: AI_DETECT_MODERNWIN
Action 19:00:07: AI_DETECT_MODERNWIN.
Action start 19:00:07: AI_DETECT_MODERNWIN.
MSI (c) (0C:60) [19:00:07:292]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6A3F.tmp, Entrypoint: DetectModernWindows
MSI (c) (0C:98) [19:00:07:293]: Cloaking enabled.
MSI (c) (0C:98) [19:00:07:293]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (0C:98) [19:00:07:293]: Connected to service for CA interface.
Action ended 19:00:07: AI_DETECT_MODERNWIN. Return value 1.
MSI (c) (0C:04) [19:00:07:542]: Doing action: AI_DETECT_WINTHEME
Action 19:00:07: AI_DETECT_WINTHEME.
Action start 19:00:07: AI_DETECT_WINTHEME.
MSI (c) (0C:58) [19:00:07:545]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6B3A.tmp, Entrypoint: DetectWindowsTheme
Action ended 19:00:07: AI_DETECT_WINTHEME. Return value 1.
MSI (c) (0C:04) [19:00:07:748]: Doing action: AI_EmbeddedUiAsync
Action 19:00:07: AI_EmbeddedUiAsync.
Action start 19:00:07: AI_EmbeddedUiAsync.
Action ended 19:00:07: AI_EmbeddedUiAsync. Return value 1.
MSI (c) (0C:04) [19:00:07:750]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6C06.tmp, Entrypoint: EmbeddedUIInstallHandleAccessServer
MSI (c) (0C:04) [19:00:07:750]: Skipping action: AI_IaLogPkgStarted (condition is false)
MSI (c) (0C:04) [19:00:07:750]: Doing action: AI_EnableDebugLog
Action 19:00:07: AI_EnableDebugLog.
Action start 19:00:07: AI_EnableDebugLog.
MSI (c) (0C:A4) [19:00:07:752]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6C07.tmp, Entrypoint: EnableDebugLog
AI_EnableDebugLog: Log disabled
Action ended 19:00:08: AI_EnableDebugLog. Return value 1.
MSI (c) (0C:04) [19:00:08:020]: Doing action: AI_DpiContentScale
Action 19:00:08: AI_DpiContentScale.
Action start 19:00:08: AI_DpiContentScale.
MSI (c) (0C:84) [19:00:08:030]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6D21.tmp, Entrypoint: DpiContentScale
Action ended 19:00:08: AI_DpiContentScale. Return value 1.
MSI (c) (0C:04) [19:00:08:239]: Doing action: AI_ResolveKnownFolders
Action 19:00:08: AI_ResolveKnownFolders.
Action start 19:00:08: AI_ResolveKnownFolders.
MSI (c) (0C:A0) [19:00:08:243]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6DFD.tmp, Entrypoint: AI_ResolveKnownFolders
MSI (c) (0C!D0) [19:00:08:327]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\loren\Saved Games\'.
MSI (c) (0C!D0) [19:00:08:328]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\loren\AppData\Roaming\Microsoft\Windows\Libraries\'.
MSI (c) (0C!D0) [19:00:08:328]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents\'.
MSI (c) (0C!D0) [19:00:08:328]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public\'.
MSI (c) (0C!D0) [19:00:08:328]: PROPERTY CHANGE: Adding UserProfileFolder property. Its value is 'C:\Users\loren\'.
MSI (c) (0C!D0) [19:00:08:328]: PROPERTY CHANGE: Adding IIsWWWRootFolder property. Its value is 'C:\inetpub\wwwroot\'.
Action ended 19:00:08: AI_ResolveKnownFolders. Return value 1.
MSI (c) (0C:04) [19:00:08:441]: Doing action: PrepareDlg
Action 19:00:08: PrepareDlg.
Action start 19:00:08: PrepareDlg.
Action ended 19:00:08: PrepareDlg. Return value 1.
MSI (c) (0C:04) [19:00:08:448]: Doing action: IsWine.dll
Action 19:00:08: IsWine.dll.
Action start 19:00:08: IsWine.dll.
MSI (c) (0C:90) [19:00:08:450]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSI6EC9.tmp, Entrypoint: IsRunningUnderWine
MSI (c) (0C:98) [19:00:08:451]: Cloaking enabled.
MSI (c) (0C:98) [19:00:08:451]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (0C:98) [19:00:08:451]: Connected to service for CA interface.
CustomAction IsWine.dll returned actual error code 1157 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (c) (0C:04) [19:00:08:523]: Note: 1: 1723 2: IsWine.dll 3: IsRunningUnderWine 4: C:\Users\loren\AppData\Local\Temp\MSI6EC9.tmp
Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action IsWine.dll, entry: IsRunningUnderWine, library: C:\Users\loren\AppData\Local\Temp\MSI6EC9.tmp
MSI (c) (0C:04) [19:00:10:776]: Product: LTspice -- Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action IsWine.dll, entry: IsRunningUnderWine, library: C:\Users\loren\AppData\Local\Temp\MSI6EC9.tmp
Action ended 19:00:10: IsWine.dll. Return value 3.
MSI (c) (0C:04) [19:00:10:794]: Doing action: FatalError
Action 19:00:10: FatalError.
Action start 19:00:10: FatalError.
MSI (c) (0C!C8) [19:00:10:808]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (0C!C8) [19:00:10:808]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
MSI (c) (0C!C8) [19:00:13:358]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
MSI (c) (0C!C8) [19:00:13:736]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
Action ended 19:00:13: FatalError. Return value 2.
Action ended 19:00:13: INSTALL. Return value 3.
Action ended 19:00:13: AI_EmbeddedUiAsync. Return value 0.
Property(C): AI_INSTALLPERUSER = 1
Property(C): AI_IA_ENABLE = 0
Property(C): DiskPrompt = [1]
Property(C): UpgradeCode = {D7D4C089-7B20-418E-BA5E-E0557C67F5D9}
Property(C): AI_APP_FILE = [#LTspice.exe]
Property(C): ButtonText_Install = &Install
Property(C): IAgree = No
Property(C): AI_IA_CUSTOM_PROPERTIES = ALLUSERS|,Privileged|,APPDIR|,SourceDir|,VersionMsi|,USR_GUEST|,USR_ADMINISTRATOR|,USR_ANONYMOUS|,AdminUser|,GRP_USERS|,GRP_ADMINISTRATORS|,COMPANYNAME|,WindowsBuild|
Property(C): ButtonText_Continue = &Continue
Property(C): SecureCustomProperties = OLDPRODUCTS;AI_NEWERPRODUCTFOUND
Property(C): AI_BITMAP_DISPLAY_MODE = 0
Property(C): ButtonText_Decline = &Decline
Property(C): AI_PREDEF_LCONDS_PROPS = AI_DETECTED_ALL
Property(C): WindowsTypeNT5X = Windows XP/2003
Property(C): AI_IA_SEND_HTTPS = 1
Property(C): AI_IA_APPLICATION_ID = 63d14d904a6e51432bb45eee
Property(C): WindowsTypeNT40 = Windows NT 4.0
Property(C): AI_ThemeStyle = style5blue
Property(C): ARPPRODUCTICON = ADI.exe
Property(C): DialogBitmap = dialog.jpg
Property(C): ALLUSERS = 1
Property(C): ButtonText_Yes = &Yes
Property(C): ARPCOMMENTS = This installer database contains the logic and data required to install LTspice.
Property(C): WindowsTypeNT60 = Windows Vista/Server 2008
Property(C): ARPCONTACT = LTspice@analog.com
Property(C): WindowsTypeNT40Display = Windows NT 4.0
Property(C): ButtonText_TryAgain = &Try Again
Property(C): ButtonText_Cancel = Cancel
Property(C): AiEmbeddedUI = 1
Property(C): ARPHELPLINK = https://LTspice.analog.com
Property(C): ARPURLINFOABOUT = https://LTspice.analog.com
Property(C): ARPURLUPDATEINFO = https://LTspice.analog.com
Property(C): AiWinUI = 1
Property(C): ButtonText_Remove = &Remove
Property(C): CTRLS = 2
Property(C): WindowsTypeNT5XDisplay = Windows XP/2003
Property(C): ButtonText_Finish = &Finish
Property(C): Manufacturer = Analog Devices Inc.
Property(C): ProductCode = {84E30485-8D73-4034-96C3-7D676700A60B}
Property(C): ButtonText_Repair = &Repair
Property(C): ProductLanguage = 1033
Property(C): ProductVersion = 24.1.10.4
Property(C): WindowsType9XDisplay = Windows 9x/ME
Property(C): ProductName = LTspice
Property(C): WindowsType9X = Windows 9x/ME
Property(C): ButtonText_Return = &Return
Property(C): WindowsTypeNT = Windows 9x/ME/NT/2000/XP/Vista/Windows 7/Windows 8 x86/Windows 8.1 x86/Windows 10 x86
Property(C): WindowsTypeNT50 = Windows 2000
Property(C): WindowsTypeNT50Display = Windows 2000
Property(C): WindowsTypeNT60Display = Windows Vista/Server 2008
Property(C): PROMPTROLLBACKCOST = P
Property(C): AppsShutdownOption = All
Property(C): EnableUserControl = 1
Property(C): WindowsTypeNTDisplay = 32-bit Windows versions
Property(C): ButtonText_OK = OK
Property(C): ErrorDialog = ErrorDlg
Property(C): INSTALLLEVEL = 3
Property(C): ButtonText_Browse = Br&owse...
Property(C): ButtonText_Exit = &Exit
Property(C): ButtonText_Accept = &Accept
Property(C): ButtonText_Ignore = &Ignore
Property(C): ButtonText_No = &No
Property(C): ButtonText_Reset = &Reset
Property(C): ButtonText_Resume = &Resume
Property(C): ButtonText_Retry = &Retry
Property(C): ButtonText_Abort = &Abort
Property(C): CtrlEvtChanging = Changing
Property(C): CtrlEvtRemoving = Removing
Property(C): CtrlEvtRepairing = Repairing
Property(C): CtrlEvtchanges = changes
Property(C): CtrlEvtremoves = removes
Property(C): CtrlEvtrepairs = repairs
Property(C): InstallMode = Typical
Property(C): InstallModeComplete = Complete
Property(C): InstallModeCustom = Custom
Property(C): InstallModeTypical = Typical
Property(C): Setup = Setup
Property(C): Wizard = Setup Wizard
Property(C): Progress1 = Installing
Property(C): Progress2 = installs
Property(C): AiPrerequisitesColums = PrereqLabel,PrereqReq,PrereqFound,PrereqAction
Property(C): Text_Next = Next
Property(C): ButtonText_Back = < &Back
Property(C): ButtonText_Next = &Next >
Property(C): Text_Install = Install
Property(C): AI_CommitButton = ButtonText_Install
Property(C): CompleteSetupIcon = completi
Property(C): CustomSetupIcon = custicon
Property(C): DefaultUIFont = DlgFont8
Property(C): DlgTitleFont = {\DlgFontBold8}
Property(C): ExclamationIcon = exclamic
Property(C): InfoIcon = info
Property(C): InstallerIcon = insticon
Property(C): RemoveIcon = removico
Property(C): RepairIcon = repairic
Property(C): UpDirIcon = Up
Property(C): NewDirIcon = New
Property(C): AI_CF_TITLE_TEXT_STYLE = {\CfTitleFont}
Property(C): BannerBitmap = banner.jpg
Property(C): AI_FrameColor = steelblue
Property(C): AI_LOG_CHECKBOX = 1
Property(C): TabBackground = tabback
Property(C): AI_CURRENT_YEAR = 2025
Property(C): AI_PACKAGING_TOOL = Advanced Installer 23.0 build c8eaa33e
Property(C): AI_BUILD_NAME = MsiBuild
Property(C): AI_EMBEDDED_FILES_LOCATION = 1
Property(C): AI_BOOTSTRAPPERLANGS = 1033;
Property(C): AI_BOOTSTRAPPERORIGINALLANG = 1033
Property(C): AI_PACKAGE_TYPE = x64
Property(C): MsiLogFileLocation = C:\Users\loren\Downloads\LTspiceInstall.log
Property(C): AI_INSTALL = 1
Property(C): LocalAppDataFolder = C:\Users\loren\AppData\Local\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): SystemFolder = C:\WINDOWS\SysWOW64\
Property(C): SourceDir = \\Mac\Home\Downloads\
Property(C): VersionNT = 1100
Property(C): RedirectedDllSupport = 2
Property(C): MSICLIENTUSESEMBEDDEDUI = 1
Property(C): PackageCode = {1D897F0D-7E72-4F39-A451-735AC8C2D017}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Users\loren
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 9484
Property(C): VersionDatabase = 450
Property(C): MsiSystemRebootPending = 1
Property(C): VersionMsi = 5.00
Property(C): VersionNT64 = 1100
Property(C): WindowsBuild = 26100
Property(C): ServicePackLevel = 0
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): WindowsFolder = C:\WINDOWS\
Property(C): WindowsVolume = C:\
Property(C): System64Folder = C:\WINDOWS\system32\
Property(C): RemoteAdminTS = 1
Property(C): TempFolder = C:\Users\loren\AppData\Local\Temp\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): AppDataFolder = C:\Users\loren\AppData\Roaming\
Property(C): FavoritesFolder = C:\Users\loren\Favorites\
Property(C): NetHoodFolder = C:\Users\loren\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): PersonalFolder = C:\Mac\Home\Documents\
Property(C): PrintHoodFolder = C:\Users\loren\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): RecentFolder = C:\Users\loren\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): SendToFolder = C:\Users\loren\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): MyPicturesFolder = C:\Mac\Home\Pictures\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): FontsFolder = C:\WINDOWS\Fonts\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 0
Property(C): Msix64 = 0
Property(C): Intel = 15
Property(C): PhysicalMemory = 8186
Property(C): VirtualMemory = 3689
Property(C): LogonUser = loren
Property(C): UserSID = S-1-5-21-2465353752-2153159348-47818898-1000
Property(C): UserLanguageID = 1033
Property(C): ComputerName = LORENCARPEN7FF4
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 5120
Property(C): ScreenY = 2880
Property(C): CaptionHeight = 45
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): MsiTabletPC = 1
Property(C): TextHeight = 32
Property(C): TextInternalLeading = 6
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 19:00:13
Property(C): Date = 9/21/2025
Property(C): MsiNetAssemblySupport = 4.8.9032.0
Property(C): MsiWin32AssemblySupport = 6.3.26100.3775
Property(C): AdminUser = 1
Property(C): Privileged = 1
Property(C): USERNAME = Loren Carpenter
Property(C): DATABASE = C:\Users\loren\AppData\Local\Temp\8b5dcb.msi
Property(C): OriginalDatabase = \\Mac\Home\Downloads\LTspice64.msi
Property(C): AIEXTERNALUI = 1
Property(C): CHAINERUIPROCESSID = 10648Chainer
Property(C): AI_CLIENTPROCESSID = 10648
Property(C): PRIMARYFOLDER = APPDIR
Property(C): AI_HWND_EUI = 1115370
Property(C): AiArm64 = 1
Property(C): AI_SYSTEM_DPI = 192
Property(C): AI_SYSTEM_DPI_SCALE = 200
Property(C): SOURCEDIR = \\Mac\Home\Downloads\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): SavedGamesFolder = C:\Users\loren\Saved Games\
Property(C): WindowsLibrariesFolder = C:\Users\loren\AppData\Roaming\Microsoft\Windows\Libraries\
Property(C): PublicDocumentsFolder = C:\Users\Public\Documents\
Property(C): PublicFolder = C:\Users\Public\
Property(C): UserProfileFolder = C:\Users\loren\
Property(C): IIsWWWRootFolder = C:\inetpub\wwwroot\
MSI (c) (0C:04) [19:00:14:046]: Destroying RemoteAPI object.
MSI (c) (0C:98) [19:00:14:046]: Custom Action Manager thread ending.
MSI (c) (0C:04) [19:00:14:046]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\App.xbf'
MSI (c) (0C:04) [19:00:14:047]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\embeddeduiproxy.dll'
MSI (c) (0C:04) [19:00:14:047]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\embeddeduiproxy.dll
MSI (c) (0C:04) [19:00:14:047]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\EnhancedUI.exe'
MSI (c) (0C:04) [19:00:14:047]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\EnhancedUI.exe
MSI (c) (0C:04) [19:00:14:047]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\HtmlHostControl.xbf'
MSI (c) (0C:04) [19:00:14:047]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\InstallerAnalytics.dll'
MSI (c) (0C:04) [19:00:14:048]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\InstallerAnalytics.dll
MSI (c) (0C:04) [19:00:14:048]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\Microsoft.Toolkit.Win32.UI.XamlHost.dll'
MSI (c) (0C:04) [19:00:14:048]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\Microsoft.Toolkit.Win32.UI.XamlHost.dll
MSI (c) (0C:04) [19:00:14:048]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\Microsoft.UI.Xaml.dll'
MSI (c) (0C:04) [19:00:14:048]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\Microsoft.UI.Xaml.dll
MSI (c) (0C:04) [19:00:14:048]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\Microsoft.Web.WebView2.Core.dll'
MSI (c) (0C:04) [19:00:14:048]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\msvcp140.dll'
MSI (c) (0C:04) [19:00:14:049]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\msvcp140.dll
MSI (c) (0C:04) [19:00:14:049]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\msvcp140_app.dll'
MSI (c) (0C:04) [19:00:14:049]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\resources.pri'
MSI (c) (0C:04) [19:00:14:050]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\ucrtbase.dll'
MSI (c) (0C:04) [19:00:14:050]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\vcamp140_app.dll'
MSI (c) (0C:04) [19:00:14:050]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\vccorlib140_app.dll'
MSI (c) (0C:04) [19:00:14:050]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\vcomp140_app.dll'
MSI (c) (0C:04) [19:00:14:050]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\vcruntime140.dll'
MSI (c) (0C:04) [19:00:14:051]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\vcruntime140.dll
MSI (c) (0C:04) [19:00:14:051]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\vcruntime140_app.dll'
MSI (c) (0C:04) [19:00:14:051]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI15555\WinUiBootstrapperEui.dll'
MSI (c) (0C:04) [19:00:14:051]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555\WinUiBootstrapperEui.dll
MSI (c) (0C:04) [19:00:14:052]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI15555
MSI (c) (0C:04) [19:00:14:052]: EEUI - Error while trying to remove temporary directory
=== Logging stopped: 9/21/2025 19:00:14 ===
MSI (c) (0C:04) [19:00:14:052]: Windows Installer installed the product. Product Name: LTspice. Product Version: 24.1.10.4. Product Language: 1033. Manufacturer: Analog Devices Inc.. Installation success or error status: 1603.
MSI (c) (0C:04) [19:00:14:054]: Grabbed execution mutex.
MSI (c) (0C:04) [19:00:14:054]: Cleaning up uninstalled install packages, if any exist
MSI (c) (0C:04) [19:00:14:056]: MainEngineThread is returning 1603
=== Verbose logging stopped: 9/21/2025 19:00:14 ===
  • Hi   ,
    Thank you for the log. What version of Windows are you using in Parallels? Include the full version/flavor number if possible, e.g. Windows 11 22h3
    mike
  • Hi  ,
    We've created an installer to see if it addresses this issue:
    Run the following installation (make sure it is from scratch on a clean machine: no AppData/Local/LTspice nor AppData/local/Programs/ADI):
    https://LTspice.analog.com/download/24.1.10_test/LTspice64.msi
    Please let us know if this solves the problem. If not, can you run msiexec from the command line:
    msiexec /i "<Path to>\LTspice64.msi" /L*v "<Path to>\MyAppInstall.log
    …and share the log in this thread.
    Thank you,
    mike
  • The AppData files are not there.
    Still broken.
    Downloaded it (_test version) 3 times.
    I get the “Welcome to LTSpice Setup Wizard” panel immediately followed with a popup that says:
    There is a problem with this Windows installer package.  A DLL
    Loren
  • Still broken.  Please keep this thread open.
    Having too much difficulty finding the log file.
    10 different searches haven't found in.
    Clues appreciated.
    Loren
  • Please keep this thread open.
    Clues as to where to find the log file would be appreciated.  Searches fail.
    Loren
  • msiexec /i "\\Mac\Home\Downloads\LTspice64 (5).msi" /L*v C:\Users\Loren\Downloads\SpiceInstallNew.log  worked.
    === Verbose logging started: 10/8/2025 21:01:15 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\WINDOWS\system32\msiexec.exe ===
    MSI (c) (5C:D4) [21:01:15:837]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (5C:D4) [21:01:15:838]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
    MSI (c) (5C:A0) [21:01:15:860]: Resetting cached policy values
    MSI (c) (5C:A0) [21:01:15:860]: Machine policy value 'Debug' is 0
    MSI (c) (5C:A0) [21:01:15:860]: ******* RunEngine:
    ******* Product: \\Mac\Home\Downloads\LTspice64 (5).msi
    ******* Action:
    MSI (c) (5C:A0) [21:01:15:863]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (5C:A0) [21:01:15:863]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (5C:A0) [21:01:15:865]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
    MSI (c) (5C:A0) [21:01:15:871]: Access database with Impersonation
    MSI (c) (5C:A0) [21:01:16:088]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
    MSI (c) (5C:A0) [21:01:16:440]: SOFTWARE RESTRICTION POLICY: Verifying package --> '\\Mac\Home\Downloads\LTspice64 (5).msi' against software restriction policy
    MSI (c) (5C:A0) [21:01:16:441]: SOFTWARE RESTRICTION POLICY: \\Mac\Home\Downloads\LTspice64 (5).msi has a digital signature
    MSI (c) (5C:A0) [21:01:16:757]: SOFTWARE RESTRICTION POLICY: \\Mac\Home\Downloads\LTspice64 (5).msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (5C:A0) [21:01:16:786]: Cloaking enabled.
    MSI (c) (5C:A0) [21:01:16:786]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (5C:A0) [21:01:16:788]: End dialog not enabled
    MSI (c) (5C:A0) [21:01:16:788]: Original package ==> \\Mac\Home\Downloads\LTspice64 (5).msi
    MSI (c) (5C:A0) [21:01:16:788]: Package we're running from ==> C:\Users\loren\AppData\Local\Temp\53ddb71.msi
    MSI (c) (5C:A0) [21:01:16:790]: APPCOMPAT: Compatibility mode property overrides found.
    MSI (c) (5C:A0) [21:01:16:791]: APPCOMPAT: looking for appcompat database entry with ProductCode '{84E30485-8D73-4034-96C3-7D676700A60B}'.
    MSI (c) (5C:A0) [21:01:16:791]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (5C:A0) [21:01:16:795]: MSCOREE not loaded loading copy from system32
    MSI (c) (5C:A0) [21:01:16:797]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (5C:A0) [21:01:16:797]: User policy value 'TransformsAtSource' is 0
    MSI (c) (5C:A0) [21:01:16:797]: Note: 1: 2205 2: 3: MsiFileHash
    MSI (c) (5C:A0) [21:01:16:797]: Machine policy value 'DisablePatch' is 0
    MSI (c) (5C:A0) [21:01:16:797]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (5C:A0) [21:01:16:797]: Machine policy value 'DisableMsi' is 0
    MSI (c) (5C:A0) [21:01:16:797]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (5C:A0) [21:01:16:797]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (5C:A0) [21:01:16:797]: Running product '{84E30485-8D73-4034-96C3-7D676700A60B}' with user privileges: It's not assigned.
    MSI (c) (5C:A0) [21:01:16:798]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (5C:A0) [21:01:16:798]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (5C:A0) [21:01:16:798]: APPCOMPAT: looking for appcompat database entry with ProductCode '{84E30485-8D73-4034-96C3-7D676700A60B}'.
    MSI (c) (5C:A0) [21:01:16:798]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (5C:A0) [21:01:16:805]: Transforms are not secure.
    MSI (c) (5C:A0) [21:01:16:805]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Loren\Downloads\SpiceInstallNew.log'.
    MSI (c) (5C:A0) [21:01:16:805]: Command Line: CURRENTDIRECTORY=C:\Users\loren\Downloads CLIENTUILEVEL=0 CLIENTPROCESSID=348
    MSI (c) (5C:A0) [21:01:16:805]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{1D897F0D-7E72-4F39-A451-735AC8C2D017}'.
    MSI (c) (5C:A0) [21:01:16:805]: Product Code passed to Engine.Initialize: ''
    MSI (c) (5C:A0) [21:01:16:805]: Product Code from property table before transforms: '{84E30485-8D73-4034-96C3-7D676700A60B}'
    MSI (c) (5C:A0) [21:01:16:805]: Product Code from property table after transforms: '{84E30485-8D73-4034-96C3-7D676700A60B}'
    MSI (c) (5C:A0) [21:01:16:805]: Product not registered: beginning first-time install
    MSI (c) (5C:A0) [21:01:16:805]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
    MSI (c) (5C:A0) [21:01:16:805]: Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (5C:A0) [21:01:16:806]: User policy value 'SearchOrder' is 'nmu'
    MSI (c) (5C:A0) [21:01:16:806]: Adding new sources is allowed.
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
    MSI (c) (5C:A0) [21:01:16:806]: Package name extracted from package path: 'LTspice64 (5).msi'
    MSI (c) (5C:A0) [21:01:16:806]: Package to be registered: 'LTspice64 (5).msi'
    MSI (c) (5C:A0) [21:01:16:806]: Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (5C:A0) [21:01:16:806]: Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (5C:A0) [21:01:16:806]: User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (5C:A0) [21:01:16:806]: Running product '{84E30485-8D73-4034-96C3-7D676700A60B}' with user privileges: It's not assigned.
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\loren\Downloads'.
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '348'.
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
    MSI (c) (5C:A0) [21:01:16:806]: TRANSFORMS property is now:
    MSI (c) (5C:A0) [21:01:16:806]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '450'.
    MSI (c) (5C:A0) [21:01:16:807]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming
    MSI (c) (5C:A0) [21:01:16:807]: SHELL32::SHGetFolderPath returned: C:\Users\loren\Favorites
    MSI (c) (5C:A0) [21:01:16:807]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Network Shortcuts
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Documents
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Recent
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\SendTo
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Templates
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\ProgramData
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Local
    MSI (c) (5C:A0) [21:01:16:808]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Pictures
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\Users\loren\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\Mac\Home\Desktop
    MSI (c) (5C:A0) [21:01:16:809]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
    MSI (c) (5C:A0) [21:01:16:811]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
    MSI (c) (5C:A0) [21:01:16:811]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 32
    MSI (c) (5C:A0) [21:01:16:814]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
    MSI (c) (5C:A0) [21:01:16:814]: PROPERTY CHANGE: Adding AdminUser property. Its value is '1'.
    MSI (c) (5C:A0) [21:01:16:814]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (5C:A0) [21:01:16:814]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (5C:A0) [21:01:16:814]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Loren Carpenter'.
    MSI (c) (5C:A0) [21:01:16:814]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\loren\AppData\Local\Temp\53ddb71.msi'.
    MSI (c) (5C:A0) [21:01:16:814]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is '\\Mac\Home\Downloads\LTspice64 (5).msi'.
    MSI (c) (5C:A0) [21:01:16:814]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (5C:A0) [21:01:16:814]: EEUI - Running MsiEmbeddedUI code
    MSI (c) (5C:34) [21:01:17:194]: Cloaking enabled.
    MSI (c) (5C:34) [21:01:17:194]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (5C:34) [21:01:17:194]: Connected to service for CA interface.
    MSI (c) (5C!C0) [21:01:18:471]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:471]: PROPERTY CHANGE: Adding CHAINERUIPROCESSID property. Its value is '2948Chainer'.
    MSI (c) (5C!C0) [21:01:18:471]: PROPERTY CHANGE: Adding AI_CLIENTPROCESSID property. Its value is '2948'.
    MSI (c) (5C!C0) [21:01:18:519]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
    MSI (c) (5C!C0) [21:01:18:519]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:624]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '603'. Its new value: '1100'.
    MSI (c) (5C!C0) [21:01:18:624]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '603'. Its new value: '1100'.
    MSI (c) (5C!C0) [21:01:18:624]: PROPERTY CHANGE: Modifying WindowsBuild property. Its current value is '9600'. Its new value: '26100'.
    MSI (c) (5C!C0) [21:01:18:624]: PROPERTY CHANGE: Adding AiArm64 property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:629]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (5C!C0) [21:01:18:629]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:755]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (5C!C0) [21:01:18:755]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:913]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '192'.
    MSI (c) (5C!C0) [21:01:18:914]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '200'.
    MSI (c) (5C!C0) [21:01:18:938]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (5C!C0) [21:01:18:938]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (5C!C0) [21:01:18:940]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    MSI (c) (5C!C0) [21:01:18:949]: Note: 1: 2205 2: 3: AI_ControlConditionEx
    MSI (c) (5C!C0) [21:01:18:949]: Note: 1: 2228 2: 3: AI_ControlConditionEx 4: SELECT `Dialog_`,`Control_`,`Action`,`Condition` FROM `AI_ControlConditionEx`
    MSI (c) (5C!C0) [21:01:18:953]: Note: 1: 2205 2: 3: AI_EventMappingEx
    MSI (c) (5C!C0) [21:01:18:953]: Note: 1: 2228 2: 3: AI_EventMappingEx 4: SELECT `Dialog_`,`Control_`,`Event`,`Attribute` FROM `AI_EventMappingEx`
    MSI (c) (5C!C0) [21:01:19:208]: Note: 1: 2205 2: 3: AI_ControlEx
    MSI (c) (5C!C0) [21:01:19:208]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'PrepareDlg'
    MSI (c) (5C!C0) [21:01:19:251]: PROPERTY CHANGE: Adding AI_HWND_EUI property. Its value is '328988'.
    MSI (c) (5C:A0) [21:01:19:293]: PROPERTY CHANGE: Adding MSICLIENTUSESEMBEDDEDUI property. Its value is '1'.
    MSI (c) (5C:A0) [21:01:19:293]: PROPERTY CHANGE: Adding SourceDir property. Its value is '\\Mac\Home\Downloads\'.
    MSI (c) (5C:A0) [21:01:19:293]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is '\\Mac\Home\Downloads\'.
    MSI (c) (5C:D4) [21:01:19:295]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
    === Logging started: 10/8/2025 21:01:19 ===
    MSI (c) (5C:A0) [21:01:19:302]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (c) (5C:A0) [21:01:19:303]: Machine policy value 'DisableRollback' is 0
    MSI (c) (5C:A0) [21:01:19:303]: User policy value 'DisableRollback' is 0
    MSI (c) (5C:A0) [21:01:19:303]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (5C:A0) [21:01:19:305]: Note: 1: 2203 2: C:\WINDOWS\Installer\inprogressinstallinfo.ipi 3: -2147287038
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '1100'. Its new value: '601'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '1100'. Its new value: '601'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '0'. Its new value: '14'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '14'. Its new value: '13'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '13'. Its new value: '12'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '12'. Its new value: '11'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '11'. Its new value: '10'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '1'. Its new value: '0'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '601'. Its new value: '600'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '601'. Its new value: '600'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '600'. Its new value: '502'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '600'. Its new value: '502'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '502'. Its new value: '501'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '502'. Its new value: '501'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '501'. Its new value: '500'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '501'. Its new value: '500'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '500'. Its new value: '400'.
    MSI (c) (5C:A0) [21:01:19:305]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '500'. Its new value: '400'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '10'. Its new value: '9'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '9'. Its new value: '8'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '8'. Its new value: '7'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '7'. Its new value: '6'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '6'. Its new value: '5'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '5'. Its new value: '4'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '4'. Its new value: '3'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '3'. Its new value: '2'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '2'. Its new value: '1'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying ServicePackLevel property. Its current value is '1'. Its new value: '0'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying VersionNT property. Its current value is '400'. Its new value: '1100'.
    MSI (c) (5C:A0) [21:01:19:306]: PROPERTY CHANGE: Modifying VersionNT64 property. Its current value is '400'. Its new value: '1100'.
    MSI (c) (5C:A0) [21:01:19:313]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (5C:A0) [21:01:19:313]: Doing action: INSTALL
    Action 21:01:19: INSTALL.
    Action start 21:01:19: INSTALL.
    MSI (c) (5C:A0) [21:01:19:315]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (5C:A0) [21:01:19:315]: Running UISequence
    MSI (c) (5C:A0) [21:01:19:315]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (5C:A0) [21:01:19:315]: Doing action: AI_SET_INSTALL
    Action 21:01:19: AI_SET_INSTALL.
    Action start 21:01:19: AI_SET_INSTALL.
    MSI (c) (5C:A0) [21:01:19:315]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
    Action ended 21:01:19: AI_SET_INSTALL. Return value 1.
    MSI (c) (5C:A0) [21:01:19:316]: Skipping action: AI_SET_MAINT (condition is false)
    MSI (c) (5C:A0) [21:01:19:316]: Skipping action: AI_SET_RESUME (condition is false)
    MSI (c) (5C:A0) [21:01:19:316]: Skipping action: AI_SET_PATCH (condition is false)
    MSI (c) (5C:A0) [21:01:19:316]: Skipping action: AI_CORRECT_INSTALL (condition is false)
    MSI (c) (5C:A0) [21:01:19:316]: Doing action: AI_DETECT_MODERNWIN
    Action 21:01:19: AI_DETECT_MODERNWIN.
    Action start 21:01:19: AI_DETECT_MODERNWIN.
    MSI (c) (5C:14) [21:01:19:319]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIE8DE.tmp, Entrypoint: DetectModernWindows
    MSI (c) (5C:34) [21:01:19:320]: Cloaking enabled.
    MSI (c) (5C:34) [21:01:19:320]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (5C:34) [21:01:19:320]: Connected to service for CA interface.
    Action ended 21:01:19: AI_DETECT_MODERNWIN. Return value 1.
    MSI (c) (5C:A0) [21:01:19:568]: Doing action: AI_DETECT_WINTHEME
    Action 21:01:19: AI_DETECT_WINTHEME.
    Action start 21:01:19: AI_DETECT_WINTHEME.
    MSI (c) (5C:C4) [21:01:19:570]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIE9D9.tmp, Entrypoint: DetectWindowsTheme
    Action ended 21:01:19: AI_DETECT_WINTHEME. Return value 1.
    MSI (c) (5C:A0) [21:01:19:766]: Doing action: AI_EmbeddedUiAsync
    Action 21:01:19: AI_EmbeddedUiAsync.
    Action start 21:01:19: AI_EmbeddedUiAsync.
    Action ended 21:01:19: AI_EmbeddedUiAsync. Return value 1.
    MSI (c) (5C:A0) [21:01:19:768]: Skipping action: AI_IaLogPkgStarted (condition is false)
    MSI (c) (5C:A0) [21:01:19:768]: Doing action: AI_EnableDebugLog
    Action 21:01:19: AI_EnableDebugLog.
    MSI (c) (5C:F8) [21:01:19:768]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIEAA5.tmp, Entrypoint: EmbeddedUIInstallHandleAccessServer
    Action start 21:01:19: AI_EnableDebugLog.
    MSI (c) (5C:F0) [21:01:19:771]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIEAA6.tmp, Entrypoint: EnableDebugLog
    Action ended 21:01:20: AI_EnableDebugLog. Return value 1.
    MSI (c) (5C:A0) [21:01:20:049]: Doing action: AI_DpiContentScale
    Action 21:01:20: AI_DpiContentScale.
    Action start 21:01:20: AI_DpiContentScale.
    MSI (c) (5C:FC) [21:01:20:060]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIEBD0.tmp, Entrypoint: DpiContentScale
    Action ended 21:01:20: AI_DpiContentScale. Return value 1.
    MSI (c) (5C:A0) [21:01:20:270]: Doing action: AI_ResolveKnownFolders
    Action 21:01:20: AI_ResolveKnownFolders.
    Action start 21:01:20: AI_ResolveKnownFolders.
    MSI (c) (5C:BC) [21:01:20:273]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIEC9C.tmp, Entrypoint: AI_ResolveKnownFolders
    MSI (c) (5C!78) [21:01:20:354]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\loren\Saved Games\'.
    MSI (c) (5C!78) [21:01:20:355]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\loren\AppData\Roaming\Microsoft\Windows\Libraries\'.
    MSI (c) (5C!78) [21:01:20:355]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents\'.
    MSI (c) (5C!78) [21:01:20:355]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public\'.
    MSI (c) (5C!78) [21:01:20:355]: PROPERTY CHANGE: Adding UserProfileFolder property. Its value is 'C:\Users\loren\'.
    MSI (c) (5C!78) [21:01:20:355]: PROPERTY CHANGE: Adding IIsWWWRootFolder property. Its value is 'C:\inetpub\wwwroot\'.
    Action ended 21:01:20: AI_ResolveKnownFolders. Return value 1.
    MSI (c) (5C:A0) [21:01:20:468]: Doing action: PrepareDlg
    Action 21:01:20: PrepareDlg.
    Action start 21:01:20: PrepareDlg.
    Action ended 21:01:20: PrepareDlg. Return value 1.
    MSI (c) (5C:A0) [21:01:20:476]: Doing action: IsWine.dll
    Action 21:01:20: IsWine.dll.
    Action start 21:01:20: IsWine.dll.
    MSI (c) (5C:A4) [21:01:20:478]: Invoking remote custom action. DLL: C:\Users\loren\AppData\Local\Temp\MSIED68.tmp, Entrypoint: IsRunningUnderWine
    MSI (c) (5C:34) [21:01:20:479]: Cloaking enabled.
    MSI (c) (5C:34) [21:01:20:479]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (5C:34) [21:01:20:479]: Connected to service for CA interface.
    MSI (c) (5C:A0) [21:01:20:567]: Note: 1: 1723 2: IsWine.dll 3: IsRunningUnderWine 4: C:\Users\loren\AppData\Local\Temp\MSIED68.tmp
    Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action IsWine.dll, entry: IsRunningUnderWine, library: C:\Users\loren\AppData\Local\Temp\MSIED68.tmp
    MSI (c) (5C:A0) [21:01:27:225]: Product: LTspice -- Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action IsWine.dll, entry: IsRunningUnderWine, library: C:\Users\loren\AppData\Local\Temp\MSIED68.tmp
    Action ended 21:01:27: IsWine.dll. Return value 3.
    MSI (c) (5C:A0) [21:01:27:242]: Doing action: FatalError
    Action 21:01:27: FatalError.
    Action start 21:01:27: FatalError.
    MSI (c) (5C!D4) [21:01:27:257]: Note: 1: 2205 2: 3: AI_ControlEx
    MSI (c) (5C!D4) [21:01:27:257]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
    MSI (c) (5C!D4) [21:01:29:890]: PROPERTY CHANGE: Adding AiEmbeddedDirectCall property. Its value is '1'.
    MSI (c) (5C!D4) [21:01:30:241]: PROPERTY CHANGE: Deleting AiEmbeddedDirectCall property. Its current value is '1'.
    Action ended 21:01:30: FatalError. Return value 2.
    Action ended 21:01:30: INSTALL. Return value 3.
    Action ended 21:01:30: AI_EmbeddedUiAsync. Return value 0.
    Property(C): MsiLogFileLocation = C:\Users\Loren\Downloads\SpiceInstallNew.log
    Property(C): CURRENTDIRECTORY = C:\Users\loren\Downloads
    Property(C): CLIENTPROCESSID = 348
    Property(C): VirtualMemory = 4264
    Property(C): Time = 21:01:30
    Property(C): Date = 10/8/2025
    Property(C): MsiWin32AssemblySupport = 6.3.26100.5074
    Property(C): DATABASE = C:\Users\loren\AppData\Local\Temp\53ddb71.msi
    Property(C): OriginalDatabase = \\Mac\Home\Downloads\LTspice64 (5).msi
    Property(C): CHAINERUIPROCESSID = 2948Chainer
    Property(C): AI_CLIENTPROCESSID = 2948
    Property(C): AI_HWND_EUI = 328988
    MSI (c) (5C:A0) [21:01:30:586]: Destroying RemoteAPI object.
    MSI (c) (5C:34) [21:01:30:586]: Custom Action Manager thread ending.
    MSI (c) (5C:A0) [21:01:30:587]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\App.xbf'
    MSI (c) (5C:A0) [21:01:30:587]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\embeddeduiproxy.dll'
    MSI (c) (5C:A0) [21:01:30:587]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\embeddeduiproxy.dll
    MSI (c) (5C:A0) [21:01:30:587]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\EnhancedUI.exe'
    MSI (c) (5C:A0) [21:01:30:588]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\EnhancedUI.exe
    MSI (c) (5C:A0) [21:01:30:588]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\HtmlHostControl.xbf'
    MSI (c) (5C:A0) [21:01:30:588]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\InstallerAnalytics.dll'
    MSI (c) (5C:A0) [21:01:30:588]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\InstallerAnalytics.dll
    MSI (c) (5C:A0) [21:01:30:588]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\Microsoft.Toolkit.Win32.UI.XamlHost.dll'
    MSI (c) (5C:A0) [21:01:30:588]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\Microsoft.Toolkit.Win32.UI.XamlHost.dll
    MSI (c) (5C:A0) [21:01:30:589]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\Microsoft.UI.Xaml.dll'
    MSI (c) (5C:A0) [21:01:30:589]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\Microsoft.UI.Xaml.dll
    MSI (c) (5C:A0) [21:01:30:589]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\Microsoft.Web.WebView2.Core.dll'
    MSI (c) (5C:A0) [21:01:30:589]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\msvcp140.dll'
    MSI (c) (5C:A0) [21:01:30:589]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\msvcp140.dll
    MSI (c) (5C:A0) [21:01:30:589]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\msvcp140_app.dll'
    MSI (c) (5C:A0) [21:01:30:589]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\resources.pri'
    MSI (c) (5C:A0) [21:01:30:590]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\ucrtbase.dll'
    MSI (c) (5C:A0) [21:01:30:590]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\vcamp140_app.dll'
    MSI (c) (5C:A0) [21:01:30:590]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\vccorlib140_app.dll'
    MSI (c) (5C:A0) [21:01:30:590]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\vcomp140_app.dll'
    MSI (c) (5C:A0) [21:01:30:590]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\vcruntime140.dll'
    MSI (c) (5C:A0) [21:01:30:591]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\vcruntime140.dll
    MSI (c) (5C:A0) [21:01:30:591]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\vcruntime140_app.dll'
    MSI (c) (5C:A0) [21:01:30:591]: FDeleteFolder: Deleting file 'C:\Users\loren\AppData\Local\Temp\MSI18886\WinUiBootstrapperEui.dll'
    MSI (c) (5C:A0) [21:01:30:591]: Note: 1: 1926 2: 1307 3: C:\Users\loren\AppData\Local\Temp\MSI18886\WinUiBootstrapperEui.dll
    MSI (c) (5C:A0) [21:01:30:591]: EEUI - Error while trying to remove temporary directory
    === Logging stopped: 10/8/2025 21:01:30 ===
    MSI (c) (5C:A0) [21:01:30:592]: Windows Installer installed the product. Product Name: LTspice. Product Version: 24.1.10.4. Product Language: 1033. Manufacturer: Analog Devices Inc.. Installation success or error status: 1603.
    MSI (c) (5C:A0) [21:01:30:592]: Grabbed execution mutex.
    MSI (c) (5C:A0) [21:01:30:592]: Cleaning up uninstalled install packages, if any exist
    MSI (c) (5C:A0) [21:01:30:594]: MainEngineThread is returning 1603
    === Verbose logging stopped: 10/8/2025 21:01:30 ===
