ADR1001 Bipolar ±5V DAC Drive Using
The user encountered an issue with the ADR1001 in LTspice where setting the negative supply to -7V or lower results in an output of -1V, indicating potential protection function activation. The final answer confirms this is a known issue with the LTspice model affecting the INV1 and INV2 pins, and it does not reflect the actual performance of the ADR1001 with a negative heater GND.
Product Number: ADR1001
Software Version: LTspice
Hello.
I have a question about ADR1001.
I designed the circuit in LTspice based on Figure 47 in the datasheet, but setting the negative supply to -7V results in an output of -1V.
When a negative supply of -7V or lower is applied, it appears the protection function is activated. Is this behavior correct?
Best regards.
Thread Notes
