since Mike left, your team is trying to fix too many things that where not broken. But now brake some old and good simulations.
The old syntax checker worked on the expanded netlist. Which was exactly what is appropriate. Only disadvantage was, that it could not refer to the line and exact text of the netlist that comes out of the GUI.
The new too extended syntax checker now works on the net list that comes out of the GUI and is therefore not appropriate.
There is the ".include" feature that it breaks. The help says:
But the new syntax checkers don't always adhere to this!!!
And why not here?
The file problem1.pwl only contains the data point:
+1,3,
+2,9,
+3,81
In older versions of LTspice this worked flawless!
I have prepared a .asc which shows the problems:
Please restore the correct behavior of the syntax checker regarding ".include" an all cases where tbl= or V=table, I=table, R=table, P=table or PWL or Laplace= is used.
Maybe other cases use .include too, so best strictly follow the help for .include: "This directive includes the named file as if that file had been typed into the netlist instead of the .include command."
greetings
please set text size to 16
