Request for Spice model for MAX16054
MAX16054
Production
The MAX16054 is a pushbutton on/off controller with a single switch debouncer and built-in latch. It accepts a noisy input from a mechanical switch and...
Datasheet
MAX16054 on Analog.com
LTspice
Production
LTspice® is a powerful, fast, and free SPICE simulator software, schematic capture and waveform viewer with enhancements and models for improving the simulation...
LTspice on Analog.com
Hello mike.
As per my knowledge, I dont have the access. can you guide to get the access and procedure to get the spice model.
Hi Raj0224 ,
LTspice models are prioritized based on market (volume) requirements, so, unfortunately, I cannot request a model from a single query. What is your expected volume for this part?
That said, the LTC.… pushbutton controllers have LTspice models.
mike
LTC is not suits for my application:
I need a startup and latch IC to prove the concept and proto.
Application: IC should capable of start-up for 48-70V pulse voltage (>=10mS) and should latch till manual reset or logic reset happen.
Suggest if any
Hi Raj0224 ,
Unfortunately, I cannot answer (nor is EZ designed to address) product selection questions. Can I suggest you try other support options: www.analog.com/.../support.html.
mike (LTspice team)
