Peak switch current
Product Number: LT3467
Dear community,
I am simulating the typical application of "±15V Dual Output Converter with Output Disconnect" (from the datasheet of the LT3467) on LT SPICE.
It converts a 5V input into a ±15V output @ max 100mA, as shown below.
I am using the Analog Devices model of the converter and the suggested components for the capacitors, diodes and inductor. I put two resistive loads that draw approx. 30mA.
See a screenshot of the ciruit: /resized-image/__size/640x480/__key/communityserver-discussions-components-files/1020/pastedimage1748936809666v8.png
I encounter an issue on the peak switch current, when the converterter starts up. It exceeds the ratings on the datasheet of the switch current limit, which are between 0.8 and 1.4A at worst case.
In my simulation, I get a peak switch current of about 4.68A, when the converter starts to step up the voltage, as shown here: /resized-image/__size/1148x532/__key/communityserver-discussions-components-files/1020/pastedimage1748936538148v4.png
Is the model of the converter appropriate, meaning I'll get such a peak current also on a real circuit? Is this not desctructive to the converter or am I wrongly interpreting the switch current limit specification?
I would appreciate some feedback and I am available in case you need more information.
Helena
