I don't understand why ADI is making LTspice worse day by day which was once a beautiful simulation tool.
1.The same simulation which was ran 100 times with old LTspice and once switched to new version unable to run even simple simulation
2.Why do you need to change something which is not required in first place ?
3.if you need to add new feature that's fine but why are you changing existing things like table function syntax earlier there was curly bracket now it changed to first bracket
What did you achieve by changing table function syntax ? this is only one example there plenty of example this type nonsense changes .
Please don't turn this excellent tool into nightmare.
