LT1013, LT1014 models still buggy
Product Number: LT1013
Software Version: 24
After upgrading to the most recent ltspice version , I ran into lots of trouble. Then I found this @ https://groups.io/g/LTspice:
WARNING:
The recent versions of LTspice for Windows (version 24.1.*) are a significant change from previous versions.  Any major program revision such as that can be subject to all sorts of problems, and this is no exception.  Analog Devices has worked hard to fix the new bugs.  Also, some of LTspice's behavior fundamentally changed, which may cause older simulations to no longer work.
Version 24.0.12 was the last version before this major change.
So I switched back to V 24.0.12.  But still  having problems : my old .asc files containing LT1013 with +5V single supply don't work anymore. When I rise supply voltage to >= 6.8V, simulation works again !?!
There is already an unanswered thread here:
ez.analog.com/.../missing-lt1013a-models
Did you change LT1013/14 models recently ?
When will these newly introduced bugs be fixed ?
Is there a workaround ?
TIA & best regards, Uwe
  • Hi  ,
    I'll check your schematic and operation of the model. It is possible there is a newish model bug.
    The warning on groups.io is related to legacy libraries that took advantage of undocumented LTspice features. If you are not using those libraries, you shouldn't see new problems. LTspice 24.1.6 is very stable, and all ADI models have been tested against it, including the LT1013/14.
    Unfortunately, an accounting bug in the 1013/1014 symbols was introduced at the same time as the introduction of LTspice 24.1, giving the impression that they were related. They were not.
    If you do see a problem pop up with a certain device, do check Help > Model Change Log to see if there was a recent update to that model. To wit, the original introduction of the symbol bug and the symbol fixes:
    02/17/25 LT1013D Corrected symbol.
    02/17/25 LT1013A Corrected symbol.
    02/17/25 LT1014 Corrected symbol.
    02/17/25 LT1014A Corrected symbol.
    02/17/25 LT1014D Corrected symbol.
    01/13/25 LT1013 Corrected output spike in transient startup condition.
    I will examine your particular schematic. I'm guessing it might also be related to that 1/13 update.
    mike
  • HI  ,
    There indeed seems to be a bug introduced in the 1/13 update. I'll enter a bug report.
    I do have a workaround for you, while the bug is fixed. I've set up a symbol that you can use in LTspice 24.1, with the symbol and (old) library attached in the zip. The library contains this sub:
    .subckt LT1013 1 2 3 4 5
    A1 2 1 0 0 0 0 0 0 OTA g=0 in=15f ink=60
    B1 0 N003 I=10u*dnlim(uplim(V(1),V(3)-1.1,.1), V(4)-0.4, .1)+1n*V(1)
    B2 N003 0 I=10u*dnlim(uplim(V(2),V(3)-1.09,.1), V(4)-0.41, .1)+1n*V(2)
    C6 3 1 .1p Rpar=20G noiseless
    C7 1 4 .1p noiseless Rpar=20G
    C8 2 4 .1p Rpar=20G noiseless
    C9 3 2 .1p Rpar=20G noiseless
    C10 N003 0 1f Rpar=100K noiseless
    D1 N005 3 XU
    D4 4 N005 XD
    M1 3 N004 5 5 N temp=27
    M2 4 N004 5 5 P temp=27
    C1 N004 0 12f Rpar=1Meg noiseless
    C3 3 5 .5p
    C4 5 4 .5p
    D5 N004 5 YU
    D6 5 N004 YD
    G1 0 N004 N005 0 1µ
    C2 2 1 1f Rpar=435Meg noiseless
    A2 0 N006 0 0 0 0 N005 0 OTA g=160u iout=9.59u Cout=23.4p Vhigh=1e308 Vlow=-1e308
    G2 0 N006 N007 0 1m
    L2 N006 0 .457m Cpar=5.08p Rser=1.29k Rpar=4.448275862068965k noiseless
    A3 0 N003 0 0 0 0 N007 0 OTA g=1m linear en=20.2n enk=2 Vhigh=1e308 Vlow=-1e308
    C11 N007 0 532p Rpar=1k noiseless
    D2 2 3 DBIAS
    D3 1 3 DBIAS
    .model XU D(Ron=1K Roff=100G Vfwd=-.72 epsilon=1.0 noiseless)
    .model XD D(Ron=1K Roff=100G Vfwd=-.114 epsilon=1.0 noiseless)
    .model YU D(Ron=500 Roff=1T Vfwd=.77 epsilon=.1 noiseless)
    .model YD D(Ron=1k Roff=1T Vfwd=.74 epsilon=.1 noiseless)
    .model DBIAS D(Ron=1k Roff=1T Vrev=0.6 revilimit=12n noiseless)
    .model N VDMOS(Vto=-100m Kp=70m)
    .model P VDMOS(Vto=100m Kp=70m pchan)
    .ends LT1013
    Note that all versions of the LT1013x and LT1014x use the same sub (above), so you can use the same symbol for all of them. This is an old library, so the convergence fixes will not apply.
    Place all files in the same directory, and it should just work.
    mike
    LT1013-LT1014_Workaround.zip
  • Hi  ,
    No problem. Hopefully you won't need it soon.
    mike
  • LT1413 model seems to be very closed to LT1013.
