LTM9100 evaluation board DC2423B Ltspice simulation runs supper slow.
change LTM9100 LTspice demo to DC2423B configuration, it run supper slow and can not get result,
does it anyway to increase the speed?
LTM9100
Production
The LTM9100 μModule® (micromodule) controller is a complete, galvanically isolated switch controller with I2C interface, for use as a load switch or...
Datasheet
LTM9100 on Analog.com
MStokowski - Moved from Power Management to LTspice. Post date updated from Thursday, January 9, 2025 11:41 PM UTC to Thursday, May 8, 2025 8:13 PM UTC to reflect the move.
MStokowski - Moved from Power Management to LTspice. Post date updated from Thursday, May 8, 2025 8:13 PM UTC to Thursday, May 8, 2025 8:13 PM UTC to reflect the move.
Hi ltm9100 ,
Since there has been no response in the Power forum, I've moved this to LTspice. We'll take a look.
mike
Hi ltm9100 ,
It looks like your FET model has a problem, I produced this log from LTspice 24.1.8:
Instance "q1:M112": Length shorter than recommended for a level 1 MOSFET.
Instance "q1:M111": Length shorter than recommended for a level 1 MOSFET.
Direct Newton iteration failed to find .op point. (Use ".option noopiter" to skip.)
Starting Gmin stepping
mike
