LT3758
Production
The LT3758/LT3758A are wide input range, current mode, DC/DC controllers which are capable of generating either positive or negative output voltages. They...
Datasheet
LT3758 on Analog.com
Hi LEACH ,
I can put in a request, but unlikely it will be done soon. Does your company wok with an FAE? Since the frequency can be set via the Rt pin, can you use that to model the behavior you are looking for?
mike
Hello Mike, I will use the synch pin to use the LTC6908.
Can you make the request.
Thank you very much
Hi LEACH ,
In the meantime, you might be able to simulate the spread spectrum effect by using a behavioral resistor for Rt.
mike
Hello Mike, did you have time to add the SYNC pin for the LT3758 model? Thank you.
