AD8615 LTspice model - typical or min/max values?
I'm simulating the effects of temperature variation of the AD8615 configured as a TIA. Does the LTspice model embody the typical or min/max characteristics of the device (e.g., input voltage offset)? I would like to understand if my simulation results represent a typical device or the worst case scenario in terms of response to temperature variation.
James
Thread Notes
  • Hi  ,
    Devices are normally modeled to represent most of what is represented on the datasheet, this includes offset (min/max), Temperature variance, Thresholds, current limits, etc.
    Models are referenced from its datasheet; hence, the response of the simulation will definitely be as expected by its performance as stated in the datasheet.
    Best Regards,
    Earl
