Can we get a Simulation model for LTC 9111 IC
LTC9111
Recommended for New Designs
The LTC9111 is an IEEE 802.3cg compliant Single-Pair Power over Ethernet (SPoE) Powered Device (PD) controller. A wide 2.3V to 60V operating range capability...
Datasheet
LTC9111 on Analog.com
ADIN1100
The ADIN1100 is a low power, single port, 10BASE-T1L transceiver designed for industrial Ethernet applications and is compliant with the IEEE® 802.3cg...
Datasheet
ADIN1100 on Analog.com
Hi ADIN1100 ,
I communicated with the applications engineer in-charge of this Part Number and already asked for them to request for a model for this device.
Will get back to you as soon as the model for this device is created.
Best Regards,
Earl
