Need a Spice model for ICL8038
Category: Datasheet/Specs
Product Number: ICL8038
I need a Spice model for the ICL8038 waveform generator.  Do you have one, or know a library that has one?
Thanks for any help,
Peter
Top Replies
  • Hi  ,
    I think the part number that you are asking of a model is not a product of Analog Devices. Our library is specifically created from Analog Devices products.
    If you would like to simulate a similar…
  • Hi  ,
    If you would like to simulate a similar model using LTspice, Analog Devices offers a wide variety of part number that has a similar function as your desired part, you can explore that option and then we could help you find a model for that as long as it is an Analog Devices/Maxim products.
    Best Regards,
    Earl
  • Earl,
        Ah.  Got it.  Maxim has a similar part (MAX1044) but it's missing a function that I need ("BOOST" on pin 1).  If I was more familiar with the Spice model coding I woukd ask for the MAX1044 model and then add the BOOST function, but I'm just starting to learn about Spice.
        In any event, thanks for the quick and informative reply.  I'll only leave questions about A.D. devices here in the future.
    Best,
        Peter
  • Hi  ,
    No problem, in general this forum is dedicated to support any LTspice related concerns. Feel free to use this forum.
    In the light of your inquiry, charge pump models are currently being created.
    Best Regards,
    Earl
