Does LTSPICE have models for transmission lines that can be used to simulate traces on PCBs? Does it have a viable "ideal" transmission line model? Does it have a viable "lossy" transmission line model? What are those models called? Thank you.
Hi DV2012LTspice ,
Yes, LTspice have this different transmission lines. You can find more information in LTspice help file.
Thank you.
Can I please get a more succinct answer? Perhaps even the names of the model to use for the lossy model and for the ideal model? Thanks.
Simply open the Help window and type " transmission " in the search line and hit enter. The syntax and model information will appear in the list.
To add symbols to a schematic use the ltline (lossy) and tline (ideal) components found in same spot as the other generic components like voltage sources etc.
