LTSpice failed during LTM4644 sim
Product Number: LTSpice
Software Version: 17.1.6
I ran into an interesting error while doing a hardware to model correlation on the LTM4644 using LTSpice (v17.1.6).  It’s not really a concern for me but I thought you might want to look into it.
I used an LTM4644 to generate the 3.3V supply for an ECAT tester with a 100nF on the Track/SS pin for a soft-start time of about 24ms.  Our ECAT contract manufacturer had high fall out on one of the DUT components.  The supplier asked them to increase the ramp rate to <1ms.  I chose 2.2nF and the C.M. reported major ringing on the LTM4644 output.  It turned out that during the rework, the tech removed the COMP cap first,  realized the mistake but replaced it with 100nF.   I decided to try to run an LTSpice sim to confirm that this caused the ringing.   The sim result starts to match the measured signal but then starts to fail at about 2.5ms then collapses at about 3.2 ms.
fixed typo
[edited by: JimTM at 8:03 PM (GMT -5) on 1 Feb 2023]
  • Hi  ,
    I tried to run the model of LTM4644 based on your description, see below, and manage to complete a run up to 4ms. Can you provide me your application circuit and made some screenshots of the errors you encountered.
    Thank you.
  • Hi Paul,
    Thanks for looking into this.  The problem shows up when you add 100nF cap on the COMP1 pin,  you have it open.
  • Hi  ,
    Can you attach your application circuit here?
    Thank you.
  • Version 4
    SHEET 1 2104 1000
    WIRE -160 -672 -352 -672
    WIRE -64 -672 -160 -672
    WIRE 32 -672 -64 -672
    WIRE 128 -672 32 -672
    WIRE -160 -624 -160 -672
    WIRE -64 -624 -64 -672
    WIRE 32 -624 32 -672
    WIRE 128 -624 128 -672
    WIRE -352 -576 -352 -672
    WIRE -1328 -432 -1600 -432
    WIRE -1216 -432 -1328 -432
    WIRE -1120 -432 -1216 -432
    WIRE -1024 -432 -1120 -432
    WIRE -544 -432 -1024 -432
    WIRE -400 -432 -544 -432
    WIRE -160 -416 -160 -560
    WIRE -64 -416 -64 -560
    WIRE 32 -416 32 -560
    WIRE 128 -416 128 -560
    WIRE -1328 -368 -1328 -432
    WIRE -1216 -368 -1216 -432
    WIRE -1120 -368 -1120 -432
    WIRE -544 -352 -544 -432
    WIRE -320 -352 -448 -352
    WIRE 816 -352 672 -352
    WIRE 1056 -352 896 -352
    WIRE 1184 -352 1056 -352
    WIRE 1296 -352 1184 -352
    WIRE 1520 -352 1296 -352
    WIRE 1792 -352 1520 -352
    WIRE 1888 -352 1792 -352
    WIRE -1600 -320 -1600 -432
    WIRE 1056 -320 1056 -352
    WIRE 1184 -320 1184 -352
    WIRE 1296 -320 1296 -352
    WIRE 1520 -320 1520 -352
    WIRE 1792 -320 1792 -352
    WIRE 1888 -320 1888 -352
    WIRE -1328 -272 -1328 -304
    WIRE -1328 -272 -1488 -272
    WIRE -1216 -272 -1216 -304
    WIRE -1216 -272 -1328 -272
    WIRE -1120 -272 -1120 -304
    WIRE -1120 -272 -1216 -272
    WIRE -1328 -256 -1408 -256
    WIRE -1216 -256 -1328 -256
    WIRE -1120 -256 -1216 -256
    WIRE -1024 -256 -1024 -432
    WIRE -1024 -256 -1120 -256
    WIRE -400 -256 -400 -432
    WIRE -320 -256 -400 -256
    WIRE 800 -256 672 -256
    WIRE 960 -256 880 -256
    WIRE -544 -240 -544 -272
    WIRE -448 -240 -448 -352
    WIRE -448 -240 -544 -240
    WIRE -1408 -224 -1408 -256
    WIRE -1328 -224 -1328 -256
    WIRE -1216 -224 -1216 -256
    WIRE -1120 -224 -1120 -256
    WIRE 960 -208 960 -256
    WIRE 1056 -208 1056 -256
    WIRE 1056 -208 960 -208
    WIRE 1184 -208 1184 -256
    WIRE 1184 -208 1056 -208
    WIRE 1296 -208 1296 -256
    WIRE 1296 -208 1184 -208
    WIRE 1520 -208 1520 -240
    WIRE 1520 -208 1296 -208
    WIRE 1792 -208 1792 -256
    WIRE 1792 -208 1520 -208
    WIRE 1888 -208 1888 -256
    WIRE 1888 -208 1792 -208
    WIRE -864 -160 -976 -160
    WIRE -320 -160 -864 -160
    WIRE 768 -160 672 -160
    WIRE 944 -160 832 -160
    WIRE 1888 -160 1888 -208
    WIRE -1600 -112 -1600 -240
    WIRE -1488 -112 -1488 -272
    WIRE -1488 -112 -1600 -112
    WIRE -1408 -112 -1408 -160
    WIRE -1408 -112 -1488 -112
    WIRE -1328 -112 -1328 -160
    WIRE -1328 -112 -1408 -112
    WIRE -1216 -112 -1216 -160
    WIRE -1216 -112 -1328 -112
    WIRE -1120 -112 -1120 -160
    WIRE -1120 -112 -1216 -112
    WIRE -1488 -64 -1488 -112
    WIRE -544 -64 -544 -240
    WIRE -336 -64 -544 -64
    WIRE -976 16 -976 -160
    WIRE -976 16 -1600 16
    WIRE -320 32 -432 32
    WIRE -1600 64 -1600 16
    WIRE -432 128 -432 32
    WIRE -432 128 -960 128
    WIRE -320 128 -432 128
    WIRE 768 128 672 128
    WIRE 944 128 944 -160
    WIRE 944 128 832 128
    WIRE -1600 192 -1600 144
    WIRE -544 224 -544 -64
    WIRE -320 224 -544 224
    WIRE -320 320 -432 320
    WIRE -960 416 -960 128
    WIRE -432 416 -432 320
    WIRE -432 416 -960 416
    WIRE -320 416 -432 416
    WIRE 784 416 672 416
    WIRE 944 416 944 128
    WIRE 944 416 848 416
    WIRE -544 512 -544 224
    WIRE -320 512 -544 512
    WIRE -336 608 -496 608
    WIRE -960 704 -960 416
    WIRE -496 704 -496 608
    WIRE -496 704 -960 704
    WIRE -320 704 -496 704
    WIRE -304 704 -320 704
    WIRE 784 704 672 704
    WIRE 944 704 944 416
    WIRE 944 704 848 704
    WIRE -544 768 -544 512
    WIRE 608 832 608 768
    WIRE 944 832 944 704
    WIRE 944 832 608 832
    WIRE -960 864 -960 704
    WIRE -544 864 -544 832
    WIRE -544 864 -960 864
    WIRE -256 864 -256 768
    WIRE -256 864 -544 864
    WIRE 128 864 128 768
    WIRE 512 864 512 768
    WIRE 512 864 128 864
    WIRE -256 880 -256 864
    WIRE 32 896 32 768
    WIRE 416 896 416 768
    WIRE 416 896 32 896
    WIRE 944 896 944 832
    WIRE -64 928 -64 768
    WIRE 320 928 320 768
    WIRE 320 928 -64 928
    WIRE -160 976 -160 768
    WIRE 224 976 224 784
    WIRE 224 976 -160 976
    FLAG -1488 -64 0
    FLAG -352 -576 0
    FLAG 944 896 0
    FLAG -256 880 0
    FLAG 1888 -160 0
    FLAG -1600 192 0
    FLAG 1888 -352 OUTPUT
    FLAG -864 -160 3.3V
    SYMBOL PowerProducts\\LTM4644 176 176 R0
    SYMATTR InstName U1
    SYMBOL cap -1344 -368 R0
    SYMATTR InstName C1
    SYMATTR Value 10µ
    SYMATTR SpiceLine V=25 Irms=0 Rser=0 Lser=0 mfg="Murata" pn="GRM21BR61E106MA73" type="X5R"
    SYMBOL polcap -1232 -368 R0
    WINDOW 3 24 56 Left 2
    SYMATTR Value 22µ
    SYMATTR InstName C2
    SYMATTR Description Capacitor
    SYMATTR Type cap
    SYMATTR SpiceLine V=25 Irms=1.76541 Rser=0.06 Lser=0 mfg="KEMET" pn="T521V226M025ATE060" type="Tantalum"
    SYMBOL cap -1424 -224 R0
    SYMATTR InstName C4
    SYMATTR Value 10µ
    SYMBOL cap -1344 -224 R0
    SYMATTR InstName C5
    SYMATTR Value 10µ
    SYMBOL cap -1232 -224 R0
    SYMATTR InstName C6
    SYMATTR Value 10µ
    SYMBOL cap -1136 -224 R0
    SYMATTR InstName C7
    SYMATTR Value 10µ
    SYMBOL polcap -1136 -368 R0
    WINDOW 3 7 54 Left 2
    SYMATTR Value 22µ
    SYMATTR InstName C3
    SYMATTR Type cap
    SYMBOL voltage -1600 -336 R0
    WINDOW 123 0 0 Left 0
    WINDOW 39 0 0 Left 0
    SYMATTR InstName V1
    SYMATTR Value 12
    SYMBOL cap -176 -624 R0
    SYMATTR InstName C8
    SYMATTR Value 100n
    SYMATTR SpiceLine V=25 Irms=0 Rser=0.035 Lser=766p
    SYMBOL cap -80 -624 R0
    SYMATTR InstName C9
    SYMATTR Value 22p
    SYMATTR SpiceLine V=25 Irms=0 Rser=0.035 Lser=766p mfg="Würth Elektronik" pn="885012205085 WCAP-CSGP 0402" type="X7R"
    SYMBOL cap 16 -624 R0
    SYMATTR InstName C10
    SYMATTR Value 22p
    SYMBOL cap 112 -624 R0
    SYMATTR InstName C11
    SYMATTR Value 22p
    SYMBOL cap 832 112 R90
    WINDOW 0 0 32 VBottom 2
    WINDOW 3 32 32 VTop 2
    SYMATTR InstName C13
    SYMATTR Value 2.2n
    SYMATTR SpiceLine V=16 Irms=0
    SYMBOL cap 848 400 R90
    SYMATTR InstName C14
    SYMATTR Value 2.2n
    SYMBOL cap 848 688 R90
    SYMATTR InstName C15
    SYMATTR Value 2.2n
    SYMBOL polcap 1040 -320 R0
    SYMATTR Value 680µ
    SYMATTR InstName C16
    SYMATTR Type cap
    SYMATTR SpiceLine V=6.3 Irms=3.14325 Rser=0.025 Lser=0
    SYMBOL cap 1168 -320 R0
    SYMATTR InstName C17
    SYMATTR Value 10µ
    SYMBOL cap 1280 -320 R0
    SYMATTR InstName C18
    SYMATTR Value 10µ
    SYMBOL cap 1776 -320 R0
    SYMATTR InstName C23
    SYMATTR Value 1µ
    SYMATTR SpiceLine V=50 Irms=0 Rser=0 Lser=0 mfg="Murata" pn="GCM21BR71H105MA03" type="X7R"
    SYMBOL cap 1872 -320 R0
    SYMATTR InstName C24
    SYMATTR Value 1µ
    SYMBOL res 896 -272 R90
    WINDOW 0 0 56 VBottom 2
    WINDOW 3 32 56 VTop 2
    SYMATTR InstName R1
    SYMATTR Value 13422
    SYMBOL voltage -1600 48 R0
    SYMATTR InstName V2
    SYMATTR Value 3.3
    SYMBOL cap -560 768 R0
    SYMATTR InstName C25
    SYMATTR Value 1µ
    SYMBOL res -560 -368 R0
    SYMATTR InstName R2
    SYMATTR Value 10
    SYMBOL cap 832 -176 R90
    SYMATTR InstName C12
    SYMATTR Value 2.2n
    SYMBOL res 912 -368 R90
    SYMATTR InstName R4
    SYMATTR Value 1n
    SYMBOL res 1504 -336 R0
    SYMATTR InstName R3
    SYMATTR Value 6.6
    TEXT -1592 -488 Left 2 !.tran 0 .01 0
  • Hi  ,
    Here's a response I get from the developer team.
    "I checked the corresponding code. There is nothing special in there, it should work.
    Google drive is known to lock files during sync. That may cause problems. Recommend to pause google drive for saving.".
    I suppose the problem is caused by google drive itself.
    Thanks.
