Hello, I tested a little bit, so now I have a question: why these almost identical subcircuits gives the different results?
This works good:
This doesn't work:
The only difference is different pin names, I changed tj to t1, t1 is different from name of pin name inside subcircuit, and it creates problem.
But I thought that only pin order matters, not name of node inside of subcircuit, its name should be invisible to outside circuit, but seems it doesn't work this way.
Thank you in advance.
