Issue while processing data from LTSpice in Python
I use Python (3.9) for automatically generating a netlist for LTSpice. The part of creating the netlist and running the simulation works fine. When importing the simulation data from the created .raw-file, I encountered some weird issue I wasn't able to solve:
While plotting a signal in LTSPice (e.g., current through resistor R2) works just fine, the same data seems to become a mess after importing it into Python (utilizing PyLTSpice). I tried to use another package for importing the data like ltspice, but still the same behavior.
As a voltage source I use a PWL-file (sine, amplitude=1V, f=50Hz), which seems to be a part of the problem. When I use a sine signal from LTSPice, and simulate some 10 signal periods, everything works out fine. However, what I want is to simulate just one signal period with a PWL-file (the now used sine is just for testing, this signal will be of arbitrary waveform in the future).
A workaround seems to be a combination of running LTSPice in 'ascii-mode' and utilization of the .save command. However, I want to avoid this solution since working with binary output seems more elegant to me..
Maybe someone could help! Thanks in advance!!
Signal plotted in LTSpice:
Same signal imported and plotted with Python:
Netlist (change file extemsion to .net):
netlist_equCircuit_strandedWire.txt
Title: * automatically gernerated netlist
Date: Thu Aug 26 20:44:32 2021
Plotname: Transient Analysis
Flags: real forward
No. Variables: 26
No. Points:           49
Offset:   0.0000000000000000e+000
Command: Linear Technology Corporation LTspice XVII
Variables:
	0	time	time
	1	V(kn10)	voltage
	2	V(kn20)	voltage
	3	V(kn11)	voltage
	4	V(kn21)	voltage
	5	V(kn12)	voltage
	6	V(kn22)	voltage
	7	V(kn13)	voltage
	8	V(kn23)	voltage
	9	V(kn14)	voltage
	10	V(kn24)	voltage
	11	I(L4)	device_current
	12	I(L3)	device_current
	13	I(L2)	device_current
	14	I(L1)	device_current
	15	I(L0)	device_current
	16	I(R4)	device_current
	17	I(R3)	device_current
	18	I(R2)	device_current
	19	I(R1)	device_current
	20	I(R0)	device_current
	21	I(V4)	device_current
	22	I(V3)	device_current
	23	I(V2)	device_current
	24	I(V1)	device_current
	25	I(V0)	device_current
Binary:
��׊�����L������O�����(Q������Q�����AR��C�����g�C~���{�C�����g�C~���{�C�����g�C~���{���ך>��s'����
,����[.�����/����0���e�e��7d�jb���^��e�e��7d�jb���^��e�e��7d�jb���^���ת>���S§����}˧����Ч����^ҧ�����ӧ�?�Y���������?�Y���������?�Y�����������׺>������������������b����������Ջ��H��-����r����Ջ��H��-����r����Ջ��H��-����r�����>���sm�����,������������������y����q�`n��cg�kY���=��q�`n��cg�kY���=��q�`n��cg�kY���=�����>��U����4�����V���� h�����p�������}����Zr}���������}����Zr}���������}����Zr}����fR�R��>�����Z�������Ē�����T�������������k"�������e�#���Se�í������e�#���Se�í������e�#���Se�í�ڌ[�h��>.߻ �E�.߻�F�.߻G�.߻78G�.߻ZTG�湛���x��w �ar��湛���x��w �ar��湛���x��w �ar��<_ڻ�t?5�C��5�}K�5�L�5�!|�5�'���`>��8��k�=��J���<��`>��8��k�=��J���<��`>��8��k�=��J���<��� p�?p�����y�p���D&|�p����F}�p�����}�p���� ~���Ƽ�PF�]�Ž��D��?þ��Ƽ�PF�]�Ž��D��?þ��Ƽ�PF�]�Ž��D��?þ�<bp	?�ĺ��,׻�ĺ�n�ٻ�ĺ�,�ڻ�ĺ��rۻ�ĺ�)�ۻ��+��q����*������(���+��q����*������(���+��q����*������(��'�((?�'t!��ԡ#��V�$��HL%���%��[���#�변�۬��}E|��[���#�변�۬��}E|��[���#�변�۬��}E|�3�F?�����^�����b����H�c����$�d���� -e�A��l�2�����z�0��孿A��l�2�����z�0��孿A��l�2�����z�0��孿)R���2!?_�(�aʐ�_�(��V��_�(����_�(��L��_�(�;�����齍Gi�D@�n7f�7<���齍Gi�D@�n7f�7<���齍Gi�D@�n7f�7<⿸��(�#?Х���)������ຼyU���Z�����H�����!
��Z�����H�����!
��Z�����H�����!
�G����Q&?��Z�\hڼ��Z�T	߼��Z��iἳ�Z��⼳�Z�S9�Ʉ1�����0�J?����*�Ʉ1�����0�J?����*�Ʉ1�����0�J?����*�w6��5�*?�$��L_��$������$��V���$��q��$��_���4j����Fh�,[��`��4j����Fh�,[��`��4j����Fh�,[��`�+�W�_4�d�ǽ�-��d�ǽ�#��d�ǽh3��d�ǽ�@��d�ǽ�ȉ��I׾FuV�S�Կx�Q�#g���I׾FuV�S�Կx�Q�#g���I׾FuV�S�Կx�Q�#g���ޓ`;?���;������QUɽ���˽��̽�b������J�Ǔ���f��b������J�Ǔ���f��b������J�Ǔ���f�	$�jM�����ʌf�����Y;p������`u�����xx������ay�\�¿��A�����^�;����\�¿��A�����^�;����\�¿��A�����^�;����Bz&�gBV?s�Ӿ�]��s�ӾxV��s�Ӿz���s�Ӿ�¾s�Ӿ��þ�
�3.��Wv��#��G���
�3.��Wv��#��G���
�3.��Wv��#��G�”D;I��b�hJ'����hJ'�M��hJ'��B�hJ'�3 �hJ'�< �z�P���%�u������e�z�P���%�u������e�z�P���%�u������e�Lc�4j?ZW�^�?�ZW��H�ZW�zxM�ZW�f�O�ZW��6Q��r��(v"������‚͕®r��(v"������‚͕®r��(v"������‚͕��H�2?u��A�H<h��A�NKs��A�L:y��A��M|��A��}�<V���E������>�o��<V���E������>�o��<V���E������>�o���]_2K{}?/GE��p7�/GE�_@�/GE��+E�/GE�>�G�/GE��H����8��
��;J��O�����8��
��;J��O�����8��
��;J��O��s�J��t���$�B���$�����$�!���$�.���$�~����o��\��Wk�J����Z���o��\��Wk�J����Z���o��\��Wk�J����Z���eu�+�?撱�6���撱�F���撱��b��撱��߽�撱��$���T��V��e������‰T��V��e������‰T��V��e��������LKx_/��JJ��Q�JJ�E�\�JJ���b�JJ��f�JJ�˩g�����
�3��>��>},���������
�3��>��>},���������
�3��>��>},�������0{3�?�/0�f���/0��
���/0�Z����/0�x����/0����[�i�|��*�]��������[�i�|��*�]��������[�i�|��*�]�����-�
E�r���E��Z����E�����E���:
��E�����E��m-��fd�Q����\���ҿƁA��fd�Q����\���ҿƁA��fd�Q����\���ҿƁA��L�鲄?"{	=W��;"{	=l�d;"{	=}�;;"{	=n{%;"{	=��;s�p<nH=ѓ�=�2>8��>s�p<nH=ѓ�=�2>8��>s�p<nH=ѓ�=�2>8��>nSY�]���P
>���=�P
>�r�=�P
>��=�P
>;��=�P
>q��=�l%?��?kI#@���@F.A�l%?��?kI#@���@F.A�l%?��?kI#@���@F.A2Z�M0�?��p>��@>��p>/�H>��p>�M>��p> )O>��p>#AP>㲢?:)�@��A@��A㲢?:)�@��A@��A㲢?:)�@��A@��AX��*#�����>��>��>ڰ�>��>_�>��>c��>��>��>95'@�>�@�Z$A+��A95'@�>�@�Z$A+��A95'@�>�@�Z$A+��A`�?��#?�?��#?B'?��#?B�?��#?4}?��#?Tj?$ft@���@�pAV��A�X`B$ft@���@�pAV��A�X`B$ft@���@�pAV��A�X`Bl��:m���_?M/H?�_?W�Q?�_?��V?�_?�&Y?�_?5yZ?���@5�)A���A�#B�d�B���@5�)A���A�#B�d�B���@5�)A���A�#B�d�BX�ȧ}?��e?ȧ}?"bp?ȧ}?�5v?ȧ}?V;y?ȧ}?+�z?	��@[�BA,Z�A��;B�O�B	��@[�BA,Z�A��;B�O�B	��@[�BA,Z�A��;B�O�B�
q1f쎿��?�h?��?��s?��?`�y?��?V�|?��?�2~?���@^EAs��A'S>B1��B���@^EAs��A'S>B1��B���@^EAs��A'S>B1��B*;L]n��?(�z?�Ne?(�z?�Ep?(�z?+(v?(�z?h5y?(�z?U�z?���@��BAaO�Al�;B%�B���@��BAaO�Al�;B%�B���@��BAaO�Al�;B%�B	����?Щz?�e?Щz?ap?Щz?��u?Щz?-�x?Щz?�~z?��@k|BA��A��;B��B��@k|BA��A��;B��B��@k|BA��A��;B��Bl��:-��0Y?5�H?0Y?@~R?0Y?��W?0Y?lZ?0Y?^�[?r��@w�*A†�A�r$Br��@w�*A†�A�r$Br��@w�*A†�A�r$B�7�&�U�?|�?Zr?|�?ѷ?|�?��?|�?�� ?|�?��!?��|@��@6��A�bfB��|@��@6��A�bfB��|@��@6��A�bfB΍�����X:�>lm�>X:�>n��>X:�>Y��>X:�>%��>X:�>��>��2@%ñ@w/A�A|�"B��2@%ñ@w/A�A|�"B��2@%ñ@w/A�A|�"B��/�Sȓ?QXY>�d_>QXY>�Nk>QXY>��q>QXY>�u>QXY>��v>N��?!|?@�ݼ@��7A���AN��?!|?@�ݼ@��7A���AN��?!|?@�ݼ@��7A���A��xP����)�=L�>�)�=Os
>�)�=`�>�)�=<�>�)�=��>��c?>�?Ź^@,T�@��LA��c?>�?Ź^@,T�@��LA��c?>�?Ź^@,T�@��LA���
qq�?�29<eG=�29<P� =�29<�r'=�29<�
+=�29<��,=��>=�?�т?|��?��g@��>=�?�т?|��?��g@��>=�?�т?|��?��g@�Əv�?�w�;1��<�w�;�=�w�;��=�w�;B=�w�;��=:+g>+��>�b_?���?N	D@:+g>+��>�b_?���?N	D@:+g>+��>�b_?���?N	D@{�G�z�?21�%qo�<21�%�!�<21�%��<21�%[��<21�%^��<!MF>���>}??U"�?�%@!MF>���>}??U"�?�%@!MF>���>}??U"�?�%@
PWL-file:
sine_50Hz_1V.txt
0.0,0.0
0.00020202020202020202,0.0634239196565645
0.00040404040404040404,0.12659245357374926
0.0006060606060606061,0.18925124436041021
0.0008080808080808081,0.2511479871810792
0.00101010101010101,0.3120334456984871
0.0012121212121212121,0.3716624556603276
0.0014141414141414141,0.42979491208917164
0.0016161616161616162,0.4861967361004687
0.0018181818181818182,0.5406408174555976
0.00202020202020202,0.5929079290546404
0.0022222222222222222,0.6427876096865393
0.0024242424242424242,0.690079011482112
0.0026262626262626263,0.7345917086575333
0.0028282828282828283,0.7761464642917568
0.0030303030303030303,0.8145759520503357
0.0032323232323232323,0.8497254299495144
0.0034343434343434343,0.8814533634475821
0.0036363636363636364,0.9096319953545183
0.0038383838383838384,0.9341478602651067
0.00404040404040404,0.9549022414440739
0.004242424242424242,0.9718115683235417
0.0044444444444444444,0.984807753012208
0.004646464646464647,0.9938384644612541
0.0048484848484848485,0.998867339183008
0.00505050505050505,0.9998741276738751
0.0052525252525252525,0.9968547759519424
0.005454545454545455,0.9898214418809327
0.0056565656565656566,0.9788024462147787
0.005858585858585858,0.9638421585599422
0.006060606060606061,0.9450008187146685
0.006262626262626263,0.9223542941045813
0.006464646464646465,0.8959937742913359
0.006666666666666666,0.8660254037844387
0.006868686868686869,0.8325698546347714
0.007070707070707071,0.795761840530832
0.007272727272727273,0.7557495743542583
0.007474747474747474,0.712694171378863
0.007676767676767677,0.6667690005162916
0.00787878787878788,0.6181589862206052
0.00808080808080808,0.5670598638627709
0.008282828282828282,0.5136773915734066
0.008484848484848484,0.4582265217274105
0.008686868686868687,0.4009305354066136
0.008888888888888889,0.3420201433256689
0.00909090909090909,0.28173255684142967
0.009292929292929294,0.22031053278654036
0.009494949494949495,0.1580013959733499
0.009696969696969697,0.09505604330418244
0.009898989898989899,0.031727933498067656
0.0101010101010101,-0.031727933498067414
0.010303030303030303,-0.09505604330418263
0.010505050505050505,-0.15800139597335008
0.010707070707070707,-0.22031053278654056
0.01090909090909091,-0.28173255684142984
0.011111111111111112,-0.34202014332566905
0.011313131313131313,-0.4009305354066138
0.011515151515151515,-0.4582265217274103
0.011717171717171716,-0.5136773915734061
0.01191919191919192,-0.567059863862771
0.012121212121212121,-0.6181589862206053
0.012323232323232323,-0.6667690005162915
0.012525252525252526,-0.7126941713788633
0.012727272727272728,-0.7557495743542584
0.01292929292929293,-0.7957618405308321
0.013131313131313131,-0.8325698546347713
0.013333333333333332,-0.8660254037844385
0.013535353535353536,-0.895993774291336
0.013737373737373737,-0.9223542941045814
0.013939393939393939,-0.9450008187146683
0.014141414141414142,-0.9638421585599422
0.014343434343434344,-0.9788024462147787
0.014545454545454545,-0.9898214418809327
0.014747474747474747,-0.9968547759519423
0.014949494949494949,-0.9998741276738751
0.015151515151515152,-0.998867339183008
0.015353535353535354,-0.9938384644612541
0.015555555555555555,-0.9848077530122081
0.01575757575757576,-0.9718115683235417
0.01595959595959596,-0.9549022414440739
0.01616161616161616,-0.9341478602651068
0.016363636363636365,-0.9096319953545182
0.016565656565656565,-0.8814533634475824
0.016767676767676768,-0.8497254299495144
0.016969696969696968,-0.8145759520503358
0.01717171717171717,-0.7761464642917572
0.017373737373737375,-0.7345917086575331
0.017575757575757574,-0.690079011482112
0.017777777777777778,-0.6427876096865396
0.01797979797979798,-0.5929079290546402
0.01818181818181818,-0.5406408174555974
0.018383838383838384,-0.4861967361004688
0.018585858585858588,-0.42979491208917114
0.018787878787878787,-0.37166245566032724
0.01898989898989899,-0.31203344569848707
0.01919191919191919,-0.2511479871810794
0.019393939393939394,-0.18925124436040974
0.019595959595959597,-0.12659245357374904
0.019797979797979797,-0.06342391965656452
0.02,-2.4492935982947064e-16
raw-File (change file extension to .raw):
Flags: real forward
No. Variables: 26
No. Points:           49
Variables:
	0	time	time
	1	V(kn10)	voltage
	2	V(kn20)	voltage
	3	V(kn11)	voltage
	4	V(kn21)	voltage
	5	V(kn12)	voltage
	6	V(kn22)	voltage
	7	V(kn13)	voltage
	8	V(kn23)	voltage
	9	V(kn14)	voltage
	10	V(kn24)	voltage
Binary:
��Z�����H�����!
��Z�����H�����!
�3.��Wv��#��G���
�3.��Wv��#��G���
��;J��O�����8��
��;J��O�����8��
�3��>��>},���������
�3��>��>},���������
>���=�P
>�r�=�P
>��=�P
>;��=�P
