Hi
how can I download the latest version of ADIsimRF to a computer which is not connected to the internet?
Thanks in anticipation
John
Hi
John
Done. I just emailed you Version 1.9. Version 2.0 is also "standalone", that is, your computer does not need to be connected to the web for it to run. However, your computer must be connected to the web during installation of rev 2.0 because it installs from a remote server.
Hi Enash, is it possible to get a zip version of the latest simrf tool? Whatever I do to install the tool, Win10 does not let me past setup.exe. I downloaded rev. 1.9 from this thread, but it does not support the transceiver I'd like to model.
Thank you!
You may want to try right-clicking on the .exe file and clicking on Install as Administrator. If may be that your corporate IT rules don't allow software to be installed from a remote server. If that is the case, it's not going to be possible to install. I could send you the up to date database (it's an MS Access file) which you could drop into the Rev 1.9 installation. But I'm not sure if this will work. Also finding the correct place to put it is tricky.
Yes, tried that together with complete bypass of Windows defender and firewall, etc: no luck. But will take the laptop home and check your idea about corporate IT rules. Thanks!
