Analog Filter Wizard
40kHz BP.json.txt
	"Name": "40kHz BP",
	"Description": "Center 40kHz\nPass 60kHz\n4 order",
	"Tool": "FW",
	"Version": "1.1",
	"Design": {
		"visitedTabs": [
			"filter-type",
			"specifications",
			"components",
			"tolerances"
		"filterType": "bandPass",
		"specifications": {
			"gain": 26,
			"gainUnit": "dB",
			"passbandAttenuation": -3,
			"passbandFrequency": 60000,
			"stopbandAttenuation": -40,
			"stopbandFrequency": 550000,
			"filterResponseValue": 0.15,
			"filterResponseSlider": "32",
			"centerFrequency": 40000
		"components": {
			"vsPlus": 5,
			"vsMinus": -5,
			"optimization": "RecommendedSpecificComponents",
			"optimizationPreference": "specific",
			"compensateForGbw": true,
			"stages": [
					"stageLetter": "A",
					"componentSizing": 56,
					"gain": 161,
					"gainEnabled": true,
					"implementation": "deliyannisFriend",
					"opAmps": "AD8039"
					"stageLetter": "B",
					"gain": 161,
					"opAmps": "AD8039"
			"recommendedAmps": [],
			"sortOrder": [
				0,
				1
		"tolerances": {
			"resistorTolerance": "1%",
			"capacitorTolerance": "1%",
			"inductorTolerance": "5%",
			"opAmpGbwTolerance": "20%",
			"resistorPreferredSeries": "E24",
			"capacitorPreferredSeries": "E24",
			"inductorPreferredSeries": "E12"
		"nextSteps": {}
	"CreatedDate": "2020-05-07 09:40:55 AM",
	"UpdatedDate": "2020-05-07 09:40:55 AM"
The gain feedback resistor goes to the amplifier positive input. Where do I go wrong?
    •  Super User
    on May 7, 2020 12:16 PM 9 months ago
    Hello nielsudk,
    The program realize the circuit with the "Deliyannis-Friend Filter". The positive feedback is used to increase Q. See page 14 in the PDF.
    https://hasler.ece.gatech.edu/Courses/ECE3400/Proj4/CMOSActiveFilters_Temes01.pdf
    Nevertheless the calculated magnitude response is far off from the target, because you have used resistors from the series E24.
    Theoretically calculated filter by the Analog Filter Wizard
    Active filter circuit created from Filter Wizard.
    You should use 1% resistors to get closer to the nominal ferquency response. Therefore select the E96 series for the resistors.
    The resistor values in the positive feedback should be kOhms and not Ohms.
    Corrected: See the follow-up answers.
    Helmut
    design.zip
    on May 7, 2020 12:55 PM 9 months ago in reply to helmuts
    Hi Helmut,
    Thanks for the excellent analysis.  I have nothing to add - you've covered it all.
    Regarding the small resistors - when using the "Pick for me" modes (Low Power, Voltage Range, and Low Noise) the tool should give bigger values than the resistor values in the saved file.  But in "I want to choose" mode, the tool gives a lot of leeway to adjust these resistors with the feedback resistor slider.  (Called gain resistor slider, because they set the gain in the low-pass and high-pass cases, but not really in our bandpass case here.)  , I wonder if while you were learning about these feedback resistors, you adjusted the feedback resistor slider to the left?  If not, do you remember how to reproduce the small resistor behavior, starting from loading the tool from scratch?
    Matt
    •  Super User
    on May 7, 2020 1:37 PM 9 months ago in reply to Matt.Duff
    Hello Matt,
    Thanks a lot for your help with the slider for "Gain Resistors". I had overlooked this feature.
    I just tried with another browser and the slider for "Gain Resistors" has been on the very left side - lowest resistor values.
    Helmut
  • Thank you Helmut and Matt
    Positive feedback.... I should have known
    I remember the feedback resistor low values were there before touching the slider. I also remember the slider could change the values, but they were still in the low Ohm range and never in kOhm. Strange
