LTSPICE MAC standard model replacement
hi All
I installed LTSPICE on a MAC with Mojave and i would like to replace the standard models in the /lib/cmp directory by the improved version from http://ltwiki.org/index.php?title=Components_Library_and_Circuits
unfortunately when i replace the files or even delete them, only the old models content appear in LTPICE (just like if they were built in the binary !!!)
for example i wish to simulate with a BFR193 model, but the default standard.bjt file does not contains such a device.
the replacement of these files works perfectely on a PC but the MAC it seems not to work as expected.
any idea ?
Best regards
    •  Super User
    on Jul 31, 2019 5:04 AM
    The file is in the path below
    /Users/username/Library/Application Support/LTspice/Lib/cmp/standard.bjt
    The same applies to the other model files  standard.xxx.
    Don't change the files in the path below.
    /Applications/LTspice.app/Contents/lib/
    Are you aware that when you use  models which are not in the common standard.bjt, that other users can't simulate your schematics, becasue they don't have the extra models?
    I never change the standard.xxx files. I always copy the extra models into the folder of the schematic and add a .lib filename to the schematic.
    Helmut
