No image from sensor: Failed to get frame from device
I am using the AD-FXTOF1-RBZ in combination with the Raspberry Pi 3 B+ and i do not get an image from the sensor.
When the application window (aditof-demo.sh) is opened the initialization in the terminal works correct. After hitting the button play in any setting of the application, there are two error-messages. First "select timeout" and seccond "Failed to get frame from device", like in the following picture.
While the application is open, you can hear a pulsed signal from the sensor and it gets on temperature. The window with the image does not open. You can not change the
settings or close the application anymore.
The following picture shows the rebuilding of the SDK. Maybe it is because of the error message in line seven.
Thanks in advance.
Dustin
  • Hello Dustin,
    Can you give me more details abouth the setup? (I.e power supply).
    I would recommend powering the camera's interposer from a separate power supply since pi might not be able to support it.
    Septimiu.
  • Hello Septimiu,
    I am using a seperat usb power supply for the interposer (12.75 W; 5.1 V; 2.5 A).
    For safety I measured the current consumption with an oscilloscope. The sensor consumes permanently a current of around 160 mA with spikes of up to 1 A. I think the power supply should be sufficient for this.
    Thanks a lot.
    Best regards
    Dustin
  • Right after you get the "select timeout" error, can you open up another terminal and run dmesg? And post the output here?
  • Thank you for your reply. Here is the screen shot of the terminal.
    The output is even longer, but basically it repeats the message "could not write to register 0".
    Hope you can do something with it.
    Best regards
    Dustin
  • Just to make sure: are you powering up the interposer before powering up the RPI?
    Can you dump the entire dmesg log into a file and attach it here? The "could not write to register 0" message is a know issue and it doesn't affect in anyway the interaction with the camera. But due to the large number of messages, other messages are not visible in the window from your screenshot.
    Are you using the latest SD card image?
  • Yes, I am powering the the interposer before the Raspberry Pi.
    And yes, I am using the latest SD card image (from here https://github.com/analogdevicesinc/aditof_sdk#supported-embedded-platforms, AD-FXTOF1-EBZ for Raspberry Pi 3,4).
    The whole output from the terminal is in the following code.
    [  250.460855] addi9036 0-0064: could not write to register 0
    [  250.460859] addi9036 0-0064: could not write to register 0
    [  250.460863] addi9036 0-0064: could not write to register 0
    [  250.460866] addi9036 0-0064: could not write to register 0
    [  250.460870] addi9036 0-0064: could not write to register 0
    [  250.460874] addi9036 0-0064: could not write to register 0
    [  250.460878] addi9036 0-0064: could not write to register 0
    [  250.460882] addi9036 0-0064: could not write to register 0
    [  250.460886] addi9036 0-0064: could not write to register 0
    [  250.460890] addi9036 0-0064: could not write to register 0
    [  250.460894] addi9036 0-0064: could not write to register 0
    [  250.460901] addi9036 0-0064: could not write to register 0
    [  250.460905] addi9036 0-0064: could not write to register 0
    [  250.460909] addi9036 0-0064: could not write to register 0
    [  250.460913] addi9036 0-0064: could not write to register 0
    [  250.460917] addi9036 0-0064: could not write to register 0
    [  250.460921] addi9036 0-0064: could not write to register 0
    [  250.460925] addi9036 0-0064: could not write to register 0
    [  250.460929] addi9036 0-0064: could not write to register 0
    [  250.460933] addi9036 0-0064: could not write to register 0
    [  250.460937] addi9036 0-0064: could not write to register 0
    [  250.460940] addi9036 0-0064: could not write to register 0
    [  250.460944] addi9036 0-0064: could not write to register 0
    [  250.460948] addi9036 0-0064: could not write to register 0
    [  250.460952] addi9036 0-0064: could not write to register 0
    [  250.460956] addi9036 0-0064: could not write to register 0
    [  250.460960] addi9036 0-0064: could not write to register 0
    [  250.460964] addi9036 0-0064: could not write to register 0
    [  250.460968] addi9036 0-0064: could not write to register 0
    [  250.460972] addi9036 0-0064: could not write to register 0
    [  250.460976] addi9036 0-0064: could not write to register 0
    [  250.460979] addi9036 0-0064: could not write to register 0
    [  250.460983] addi9036 0-0064: could not write to register 0
    [  250.460987] addi9036 0-0064: could not write to register 0
    [  250.460991] addi9036 0-0064: could not write to register 0
    [  250.460995] addi9036 0-0064: could not write to register 0
    [  250.460999] addi9036 0-0064: could not write to register 0
    [  250.461004] addi9036 0-0064: could not write to register 0
    [  250.461008] addi9036 0-0064: could not write to register 0
    [  250.461011] addi9036 0-0064: could not write to register 0
    [  250.461015] addi9036 0-0064: could not write to register 0
    [  250.461019] addi9036 0-0064: could not write to register 0
    [  250.461023] addi9036 0-0064: could not write to register 0
    [  250.461027] addi9036 0-0064: could not write to register 0
    [  250.461031] addi9036 0-0064: could not write to register 0
    [  250.461035] addi9036 0-0064: could not write to register 0
    [  250.461039] addi9036 0-0064: could not write to register 0
    [  250.461043] addi9036 0-0064: could not write to register 0
    [  250.461047] addi9036 0-0064: could not write to register 0
    [  250.461051] addi9036 0-0064: could not write to register 0
    [  250.461054] addi9036 0-0064: could not write to register 0
    [  250.461058] addi9036 0-0064: could not write to register 0
    [  250.461062] addi9036 0-0064: could not write to register 0
    [  250.461066] addi9036 0-0064: could not write to register 0
    [  250.461070] addi9036 0-0064: could not write to register 0
    [  250.461074] addi9036 0-0064: could not write to register 0
    [  250.461078] addi9036 0-0064: could not write to register 0
    [  250.461082] addi9036 0-0064: could not write to register 0
    [  250.461086] addi9036 0-0064: could not write to register 0
    [  250.461089] addi9036 0-0064: could not write to register 0
    [  250.461093] addi9036 0-0064: could not write to register 0
    [  250.461097] addi9036 0-0064: could not write to register 0
    [  250.461101] addi9036 0-0064: could not write to register 0
    [  250.461105] addi9036 0-0064: could not write to register 0
    [  250.461109] addi9036 0-0064: could not write to register 0
    [  250.461113] addi9036 0-0064: could not write to register 0
    [  250.461117] addi9036 0-0064: could not write to register 0
    [  250.461121] addi9036 0-0064: could not write to register 0
    [  250.461125] addi9036 0-0064: could not write to register 0
    [  250.461128] addi9036 0-0064: could not write to register 0
    [  250.461132] addi9036 0-0064: could not write to register 0
    [  250.461136] addi9036 0-0064: could not write to register 0
    [  250.461140] addi9036 0-0064: could not write to register 0
    [  250.461144] addi9036 0-0064: could not write to register 0
    [  250.461148] addi9036 0-0064: could not write to register 0
    [  250.461152] addi9036 0-0064: could not write to register 0
    [  250.461156] addi9036 0-0064: could not write to register 0
    [  250.461160] addi9036 0-0064: could not write to register 0
    [  250.461163] addi9036 0-0064: could not write to register 0
    [  250.461167] addi9036 0-0064: could not write to register 0
    [  250.461171] addi9036 0-0064: could not write to register 0
    [  250.461175] addi9036 0-0064: could not write to register 0
    [  250.461179] addi9036 0-0064: could not write to register 0
    [  250.461183] addi9036 0-0064: could not write to register 0
    [  250.461187] addi9036 0-0064: could not write to register 0
    [  250.461191] addi9036 0-0064: could not write to register 0
    [  250.461195] addi9036 0-0064: could not write to register 0
    [  250.461199] addi9036 0-0064: could not write to register 0
    [  250.461202] addi9036 0-0064: could not write to register 0
    [  250.461206] addi9036 0-0064: could not write to register 0
    [  250.461210] addi9036 0-0064: could not write to register 0
    [  250.461214] addi9036 0-0064: could not write to register 0
    [  250.461219] addi9036 0-0064: could not write to register 0
    [  250.461223] addi9036 0-0064: could not write to register 0
    [  250.461227] addi9036 0-0064: could not write to register 0
    [  250.461230] addi9036 0-0064: could not write to register 0
    [  250.461234] addi9036 0-0064: could not write to register 0
    [  250.461238] addi9036 0-0064: could not write to register 0
    [  250.461242] addi9036 0-0064: could not write to register 0
    [  250.461246] addi9036 0-0064: could not write to register 0
    [  250.461250] addi9036 0-0064: could not write to register 0
    [  250.461254] addi9036 0-0064: could not write to register 0
    [  250.461258] addi9036 0-0064: could not write to register 0
    [  250.461262] addi9036 0-0064: could not write to register 0
    [  250.461265] addi9036 0-0064: could not write to register 0
    [  250.461269] addi9036 0-0064: could not write to register 0
    [  250.461273] addi9036 0-0064: could not write to register 0
    [  250.461277] addi9036 0-0064: could not write to register 0
    [  250.461281] addi9036 0-0064: could not write to register 0
    [  250.461285] addi9036 0-0064: could not write to register 0
    [  250.461289] addi9036 0-0064: could not write to register 0
    [  250.461293] addi9036 0-0064: could not write to register 0
    [  250.461297] addi9036 0-0064: could not write to register 0
    [  250.461301] addi9036 0-0064: could not write to register 0
    [  250.461304] addi9036 0-0064: could not write to register 0
    [  250.461308] addi9036 0-0064: could not write to register 0
    [  250.461312] addi9036 0-0064: could not write to register 0
    [  250.461316] addi9036 0-0064: could not write to register 0
    [  250.461320] addi9036 0-0064: could not write to register 0
    [  250.461324] addi9036 0-0064: could not write to register 0
    [  250.461328] addi9036 0-0064: could not write to register 0
    [  250.461332] addi9036 0-0064: could not write to register 0
    [  250.461336] addi9036 0-0064: could not write to register 0
    [  250.461339] addi9036 0-0064: could not write to register 0
    [  250.461343] addi9036 0-0064: could not write to register 0
    [  250.461347] addi9036 0-0064: could not write to register 0
    [  250.461351] addi9036 0-0064: could not write to register 0
    [  250.461355] addi9036 0-0064: could not write to register 0
    [  250.461359] addi9036 0-0064: could not write to register 0
    [  250.461363] addi9036 0-0064: could not write to register 0
    [  250.461367] addi9036 0-0064: could not write to register 0
    [  250.461371] addi9036 0-0064: could not write to register 0
    [  250.461375] addi9036 0-0064: could not write to register 0
    [  250.461378] addi9036 0-0064: could not write to register 0
    [  250.461382] addi9036 0-0064: could not write to register 0
    [  250.461386] addi9036 0-0064: could not write to register 0
    [  250.461390] addi9036 0-0064: could not write to register 0
    [  250.461394] addi9036 0-0064: could not write to register 0
    [  250.461398] addi9036 0-0064: could not write to register 0
    [  250.461402] addi9036 0-0064: could not write to register 0
    [  250.461406] addi9036 0-0064: could not write to register 0
    [  250.461410] addi9036 0-0064: could not write to register 0
    [  250.461414] addi9036 0-0064: could not write to register 0
    [  250.461417] addi9036 0-0064: could not write to register 0
    [  250.461421] addi9036 0-0064: could not write to register 0
    [  250.461425] addi9036 0-0064: could not write to register 0
    [  250.461429] addi9036 0-0064: could not write to register 0
    [  250.461433] addi9036 0-0064: could not write to register 0
    [  250.461437] addi9036 0-0064: could not write to register 0
    [  250.461441] addi9036 0-0064: could not write to register 0
    [  250.461445] addi9036 0-0064: could not write to register 0
    [  250.461449] addi9036 0-0064: could not write to register 0
    [  250.461453] addi9036 0-0064: could not write to register 0
    [  250.461457] addi9036 0-0064: could not write to register 0
    [  250.461460] addi9036 0-0064: could not write to register 0
    [  250.461464] addi9036 0-0064: could not write to register 0
    [  250.461468] addi9036 0-0064: could not write to register 0
    [  250.461472] addi9036 0-0064: could not write to register 0
    [  250.461476] addi9036 0-0064: could not write to register 0
    [  250.461480] addi9036 0-0064: could not write to register 0
    [  250.461484] addi9036 0-0064: could not write to register 0
    [  250.461488] addi9036 0-0064: could not write to register 0
    [  250.461492] addi9036 0-0064: could not write to register 0
    [  250.461496] addi9036 0-0064: could not write to register 0
    [  250.461500] addi9036 0-0064: could not write to register 0
    [  250.461503] addi9036 0-0064: could not write to register 0
    [  250.461507] addi9036 0-0064: could not write to register 0
    [  250.461511] addi9036 0-0064: could not write to register 0
    [  250.461515] addi9036 0-0064: could not write to register 0
    [  250.461519] addi9036 0-0064: could not write to register 0
    [  250.461523] addi9036 0-0064: could not write to register 0
    [  250.461527] addi9036 0-0064: could not write to register 0
    [  250.461531] addi9036 0-0064: could not write to register 0
    [  250.461535] addi9036 0-0064: could not write to register 0
    [  250.461539] addi9036 0-0064: could not write to register 0
    [  250.461543] addi9036 0-0064: could not write to register 0
    [  250.461547] addi9036 0-0064: could not write to register 0
    [  250.461551] addi9036 0-0064: could not write to register 0
    [  250.461555] addi9036 0-0064: could not write to register 0
    [  250.461558] addi9036 0-0064: could not write to register 0
    [  250.461562] addi9036 0-0064: could not write to register 0
    [  250.461566] addi9036 0-0064: could not write to register 0
    [  250.461570] addi9036 0-0064: could not write to register 0
    [  250.461574] addi9036 0-0064: could not write to register 0
    [  250.461578] addi9036 0-0064: could not write to register 0
    [  250.461582] addi9036 0-0064: could not write to register 0
    [  250.461586] addi9036 0-0064: could not write to register 0
    [  250.461593] addi9036 0-0064: could not write to register 0
    [  250.461597] addi9036 0-0064: could not write to register 0
    [  250.461601] addi9036 0-0064: could not write to register 0
    [  250.461605] addi9036 0-0064: could not write to register 0
    [  250.461609] addi9036 0-0064: could not write to register 0
    [  250.461613] addi9036 0-0064: could not write to register 0
    [  250.461616] addi9036 0-0064: could not write to register 0
    [  250.461620] addi9036 0-0064: could not write to register 0
    [  250.461624] addi9036 0-0064: could not write to register 0
    [  250.461628] addi9036 0-0064: could not write to register 0
    [  250.461632] addi9036 0-0064: could not write to register 0
    [  250.461636] addi9036 0-0064: could not write to register 0
    [  250.461640] addi9036 0-0064: could not write to register 0
    [  250.461644] addi9036 0-0064: could not write to register 0
    [  250.461648] addi9036 0-0064: could not write to register 0
    [  250.461652] addi9036 0-0064: could not write to register 0
    [  250.461656] addi9036 0-0064: could not write to register 0
    [  250.461659] addi9036 0-0064: could not write to register 0
    [  250.461663] addi9036 0-0064: could not write to register 0
    [  250.461667] addi9036 0-0064: could not write to register 0
    [  250.461671] addi9036 0-0064: could not write to register 0
    [  250.461675] addi9036 0-0064: could not write to register 0
    [  250.461679] addi9036 0-0064: could not write to register 0
    [  250.461683] addi9036 0-0064: could not write to register 0
    [  250.461687] addi9036 0-0064: could not write to register 0
    [  250.461691] addi9036 0-0064: could not write to register 0
    [  250.461695] addi9036 0-0064: could not write to register 0
    [  250.461698] addi9036 0-0064: could not write to register 0
    [  250.461702] addi9036 0-0064: could not write to register 0
    [  250.461706] addi9036 0-0064: could not write to register 0
    [  250.461710] addi9036 0-0064: could not write to register 0
    [  250.461714] addi9036 0-0064: could not write to register 0
    [  250.461718] addi9036 0-0064: could not write to register 0
    [  250.461722] addi9036 0-0064: could not write to register 0
    [  250.461726] addi9036 0-0064: could not write to register 0
    [  250.461730] addi9036 0-0064: could not write to register 0
    [  250.461734] addi9036 0-0064: could not write to register 0
    [  250.461737] addi9036 0-0064: could not write to register 0
    [  250.461741] addi9036 0-0064: could not write to register 0
    [  250.461745] addi9036 0-0064: could not write to register 0
    [  250.461749] addi9036 0-0064: could not write to register 0
    [  250.461753] addi9036 0-0064: could not write to register 0
    [  250.461757] addi9036 0-0064: could not write to register 0
    [  250.461761] addi9036 0-0064: could not write to register 0
    [  250.461765] addi9036 0-0064: could not write to register 0
    [  250.461769] addi9036 0-0064: could not write to register 0
    [  250.461773] addi9036 0-0064: could not write to register 0
    [  250.461777] addi9036 0-0064: could not write to register 0
    [  250.461780] addi9036 0-0064: could not write to register 0
    [  250.461784] addi9036 0-0064: could not write to register 0
    [  250.461788] addi9036 0-0064: could not write to register 0
    [  250.461792] addi9036 0-0064: could not write to register 0
    [  250.461796] addi9036 0-0064: could not write to register 0
    [  250.461800] addi9036 0-0064: could not write to register 0
    [  250.461804] addi9036 0-0064: could not write to register 0
    [  250.461808] addi9036 0-0064: could not write to register 0
    [  250.461812] addi9036 0-0064: could not write to register 0
    [  250.461815] addi9036 0-0064: could not write to register 0
    [  250.461819] addi9036 0-0064: could not write to register 0
    [  250.461823] addi9036 0-0064: could not write to register 0
    [  250.461827] addi9036 0-0064: could not write to register 0
    [  250.461831] addi9036 0-0064: could not write to register 0
    [  250.461835] addi9036 0-0064: could not write to register 0
    [  250.461839] addi9036 0-0064: could not write to register 0
    [  250.461843] addi9036 0-0064: could not write to register 0
    [  250.461847] addi9036 0-0064: could not write to register 0
    [  250.461851] addi9036 0-0064: could not write to register 0
    [  250.461855] addi9036 0-0064: could not write to register 0
    [  250.461859] addi9036 0-0064: could not write to register 0
    [  250.461862] addi9036 0-0064: could not write to register 0
    [  250.461866] addi9036 0-0064: could not write to register 0
    [  250.461870] addi9036 0-0064: could not write to register 0
    [  250.461874] addi9036 0-0064: could not write to register 0
    [  250.461878] addi9036 0-0064: could not write to register 0
    [  250.461882] addi9036 0-0064: could not write to register 0
    [  250.461886] addi9036 0-0064: could not write to register 0
    [  250.461890] addi9036 0-0064: could not write to register 0
    [  250.461894] addi9036 0-0064: could not write to register 0
    [  250.461898] addi9036 0-0064: could not write to register 0
    [  250.461902] addi9036 0-0064: could not write to register 0
    [  250.461905] addi9036 0-0064: could not write to register 0
    [  250.461909] addi9036 0-0064: could not write to register 0
    [  250.461913] addi9036 0-0064: could not write to register 0
    [  250.461917] addi9036 0-0064: could not write to register 0
    [  250.461921] addi9036 0-0064: could not write to register 0
    [  250.461925] addi9036 0-0064: could not write to register 0
    [  250.461929] addi9036 0-0064: could not write to register 0
    [  250.461933] addi9036 0-0064: could not write to register 0
    [  250.461937] addi9036 0-0064: could not write to register 0
    [  250.461941] addi9036 0-0064: could not write to register 0
    [  250.461945] addi9036 0-0064: could not write to register 0
    [  250.461949] addi9036 0-0064: could not write to register 0
    [  250.461952] addi9036 0-0064: could not write to register 0
    [  250.461957] addi9036 0-0064: could not write to register 0
    [  250.461960] addi9036 0-0064: could not write to register 0
    [  250.461964] addi9036 0-0064: could not write to register 0
    [  250.461969] addi9036 0-0064: could not write to register 0
    [  250.461973] addi9036 0-0064: could not write to register 0
    [  250.461977] addi9036 0-0064: could not write to register 0
    [  250.461981] addi9036 0-0064: could not write to register 0
    [  250.461985] addi9036 0-0064: could not write to register 0
    [  250.461988] addi9036 0-0064: could not write to register 0
    [  250.461992] addi9036 0-0064: could not write to register 0
    [  250.461996] addi9036 0-0064: could not write to register 0
    [  250.462000] addi9036 0-0064: could not write to register 0
    [  250.462004] addi9036 0-0064: could not write to register 0
    [  250.462008] addi9036 0-0064: could not write to register 0
    [  250.462012] addi9036 0-0064: could not write to register 0
    [  250.462016] addi9036 0-0064: could not write to register 0
    [  250.462020] addi9036 0-0064: could not write to register 0
    [  250.462024] addi9036 0-0064: could not write to register 0
    [  250.462028] addi9036 0-0064: could not write to register 0
    [  250.462032] addi9036 0-0064: could not write to register 0
    [  250.462036] addi9036 0-0064: could not write to register 0
    [  250.462040] addi9036 0-0064: could not write to register 0
    [  250.462044] addi9036 0-0064: could not write to register 0
    [  250.462048] addi9036 0-0064: could not write to register 0
    [  250.462052] addi9036 0-0064: could not write to register 0
    [  250.462056] addi9036 0-0064: could not write to register 0
    [  250.462059] addi9036 0-0064: could not write to register 0
    [  250.462063] addi9036 0-0064: could not write to register 0
    [  250.462067] addi9036 0-0064: could not write to register 0
    [  250.462071] addi9036 0-0064: could not write to register 0
    [  250.462076] addi9036 0-0064: could not write to register 0
    [  250.462080] addi9036 0-0064: could not write to register 0
    [  250.462084] addi9036 0-0064: could not write to register 0
    [  250.462088] addi9036 0-0064: could not write to register 0
    [  250.462092] addi9036 0-0064: could not write to register 0
    [  250.462096] addi9036 0-0064: could not write to register 0
    [  250.462100] addi9036 0-0064: could not write to register 0
    [  250.462104] addi9036 0-0064: could not write to register 0
    [  250.462108] addi9036 0-0064: could not write to register 0
    [  250.462111] addi9036 0-0064: could not write to register 0
    [  250.462115] addi9036 0-0064: could not write to register 0
    [  250.462119] addi9036 0-0064: could not write to register 0
    [  250.462123] addi9036 0-0064: could not write to register 0
    [  250.462127] addi9036 0-0064: could not write to register 0
    [  250.462131] addi9036 0-0064: could not write to register 0
    [  250.462135] addi9036 0-0064: could not write to register 0
    [  250.462139] addi9036 0-0064: could not write to register 0
    [  250.462143] addi9036 0-0064: could not write to register 0
    [  250.462147] addi9036 0-0064: could not write to register 0
    [  250.462151] addi9036 0-0064: could not write to register 0
    [  250.462155] addi9036 0-0064: could not write to register 0
    [  250.462159] addi9036 0-0064: could not write to register 0
    [  250.462163] addi9036 0-0064: could not write to register 0
    [  250.462167] addi9036 0-0064: could not write to register 0
    [  250.462170] addi9036 0-0064: could not write to register 0
    [  250.462174] addi9036 0-0064: could not write to register 0
    [  250.462178] addi9036 0-0064: could not write to register 0
    [  250.462182] addi9036 0-0064: could not write to register 0
    [  250.462186] addi9036 0-0064: could not write to register 0
    [  250.462190] addi9036 0-0064: could not write to register 0
    [  250.462194] addi9036 0-0064: could not write to register 0
    [  250.462199] addi9036 0-0064: could not write to register 0
    [  250.462203] addi9036 0-0064: could not write to register 0
    [  250.462207] addi9036 0-0064: could not write to register 0
    [  250.462211] addi9036 0-0064: could not write to register 0
    [  250.462215] addi9036 0-0064: could not write to register 0
    [  250.462218] addi9036 0-0064: could not write to register 0
    [  250.462222] addi9036 0-0064: could not write to register 0
    [  250.462226] addi9036 0-0064: could not write to register 0
    [  250.462230] addi9036 0-0064: could not write to register 0
    [  250.462234] addi9036 0-0064: could not write to register 0
    [  250.462238] addi9036 0-0064: could not write to register 0
    [  250.462242] addi9036 0-0064: could not write to register 0
    [  250.462246] addi9036 0-0064: could not write to register 0
    [  250.462250] addi9036 0-0064: could not write to register 0
    [  250.462254] addi9036 0-0064: could not write to register 0
    [  250.462258] addi9036 0-0064: could not write to register 0
    [  250.462262] addi9036 0-0064: could not write to register 0
    [  250.462266] addi9036 0-0064: could not write to register 0
    [  250.462270] addi9036 0-0064: could not write to register 0
    [  250.462274] addi9036 0-0064: could not write to register 0
    [  250.462278] addi9036 0-0064: could not write to register 0
    [  250.462282] addi9036 0-0064: could not write to register 0
    [  250.462286] addi9036 0-0064: could not write to register 0
    [  250.462292] addi9036 0-0064: could not write to register 0
    [  250.462296] addi9036 0-0064: could not write to register 0
    [  250.462300] addi9036 0-0064: could not write to register 0
    [  250.462304] addi9036 0-0064: could not write to register 0
    [  250.462308] addi9036 0-0064: could not write to register 0
    [  250.462312] addi9036 0-0064: could not write to register 0
    [  250.462316] addi9036 0-0064: could not write to register 0
    [  250.462320] addi9036 0-0064: could not write to register 0
    [  250.462323] addi9036 0-0064: could not write to register 0
    [  250.462327] addi9036 0-0064: could not write to register 0
    [  250.462331] addi9036 0-0064: could not write to register 0
    [  250.462335] addi9036 0-0064: could not write to register 0
    [  250.462339] addi9036 0-0064: could not write to register 0
    [  250.462343] addi9036 0-0064: could not write to register 0
    [  250.462347] addi9036 0-0064: could not write to register 0
    [  250.462352] addi9036 0-0064: could not write to register 0
    [  250.462356] addi9036 0-0064: could not write to register 0
    [  250.462360] addi9036 0-0064: could not write to register 0
    [  250.462364] addi9036 0-0064: could not write to register 0
    [  250.462368] addi9036 0-0064: could not write to register 0
    [  250.462371] addi9036 0-0064: could not write to register 0
    [  250.462375] addi9036 0-0064: could not write to register 0
    [  250.462379] addi9036 0-0064: could not write to register 0
    [  250.462383] addi9036 0-0064: could not write to register 0
    [  250.462387] addi9036 0-0064: could not write to register 0
    [  250.462391] addi9036 0-0064: could not write to register 0
    [  250.462395] addi9036 0-0064: could not write to register 0
    [  250.462399] addi9036 0-0064: could not write to register 0
    [  250.462403] addi9036 0-0064: could not write to register 0
    [  250.462407] addi9036 0-0064: could not write to register 0
    [  250.462411] addi9036 0-0064: could not write to register 0
    [  250.462415] addi9036 0-0064: could not write to register 0
    [  250.462419] addi9036 0-0064: could not write to register 0
    [  250.462423] addi9036 0-0064: could not write to register 0
    [  250.462427] addi9036 0-0064: could not write to register 0
    [  250.462431] addi9036 0-0064: could not write to register 0
    [  250.462435] addi9036 0-0064: could not write to register 0
    [  250.462439] addi9036 0-0064: could not write to register 0
    [  250.462443] addi9036 0-0064: could not write to register 0
    [  250.462446] addi9036 0-0064: could not write to register 0
    [  250.462450] addi9036 0-0064: could not write to register 0
    [  250.462454] addi9036 0-0064: could not write to register 0
    [  250.462459] addi9036 0-0064: could not write to register 0
    [  250.462463] addi9036 0-0064: could not write to register 0
    [  250.462467] addi9036 0-0064: could not write to register 0
    [  250.462471] addi9036 0-0064: could not write to register 0
    [  250.462475] addi9036 0-0064: could not write to register 0
    [  250.462479] addi9036 0-0064: could not write to register 0
    [  250.462483] addi9036 0-0064: could not write to register 0
    [  250.462609] addi9036 0-0064: could not write to register 0
    [  250.462613] addi9036 0-0064: could not write to register 0
    [  250.462617] addi9036 0-0064: could not write to register 0
    [  250.462621] addi9036 0-0064: could not write to register 0
    [  250.462631] addi9036 0-0064: could not write to register 0
    [  250.462638] addi9036 0-0064: could not write to register 0
    [  250.462644] addi9036 0-0064: could not write to register 0
    [  250.462651] addi9036 0-0064: could not write to register 0
    [  250.462658] addi9036 0-0064: could not write to register 0
    [  250.462664] addi9036 0-0064: could not write to register 0
    [  250.462671] addi9036 0-0064: could not write to register 0
    [  250.462677] addi9036 0-0064: could not write to register 0
    [  250.462683] addi9036 0-0064: could not write to register 0
    [  250.462689] addi9036 0-0064: could not write to register 0
    [  250.462695] addi9036 0-0064: could not write to register 0
    [  250.462702] addi9036 0-0064: could not write to register 0
    [  250.462708] addi9036 0-0064: could not write to register 0
    [  250.462714] addi9036 0-0064: could not write to register 0
    [  250.462720] addi9036 0-0064: could not write to register 0
    [  250.462726] addi9036 0-0064: could not write to register 0
    [  250.462732] addi9036 0-0064: could not write to register 0
    [  250.462738] addi9036 0-0064: could not write to register 0
    [  250.462745] addi9036 0-0064: could not write to register 0
    [  250.462751] addi9036 0-0064: could not write to register 0
    [  250.462757] addi9036 0-0064: could not write to register 0
    [  250.462763] addi9036 0-0064: could not write to register 0
    [  250.462769] addi9036 0-0064: could not write to register 0
    [  250.462776] addi9036 0-0064: could not write to register 0
    [  250.462782] addi9036 0-0064: could not write to register 0
    [  250.462788] addi9036 0-0064: could not write to register 0
    [  250.462794] addi9036 0-0064: could not write to register 0
    [  250.462800] addi9036 0-0064: could not write to register 0
    [  250.462806] addi9036 0-0064: could not write to register 0
    [  250.462813] addi9036 0-0064: could not write to register 0
    [  250.462819] addi9036 0-0064: could not write to register 0
    [  250.462825] addi9036 0-0064: could not write to register 0
    [  250.462833] addi9036 0-0064: could not write to register 0
    [  250.462839] addi9036 0-0064: could not write to register 0
    [  250.462845] addi9036 0-0064: could not write to register 0
    [  250.462852] addi9036 0-0064: could not write to register 0
    [  250.462858] addi9036 0-0064: could not write to register 0
    [  250.462864] addi9036 0-0064: could not write to register 0
    [  250.462871] addi9036 0-0064: could not write to register 0
    [  250.462877] addi9036 0-0064: could not write to register 0
    [  250.462883] addi9036 0-0064: could not write to register 0
    [  250.462889] addi9036 0-0064: could not write to register 0
    [  250.462896] addi9036 0-0064: could not write to register 0
    [  250.462902] addi9036 0-0064: could not write to register 0
    [  250.462909] addi9036 0-0064: could not write to register 0
    [  250.462915] addi9036 0-0064: could not write to register 0
    [  250.462922] addi9036 0-0064: could not write to register 0
    [  250.462928] addi9036 0-0064: could not write to register 0
    [  250.462934] addi9036 0-0064: could not write to register 0
    [  250.462941] addi9036 0-0064: could not write to register 0
    [  250.462947] addi9036 0-0064: could not write to register 0
    [  250.462953] addi9036 0-0064: could not write to register 0
    [  250.462960] addi9036 0-0064: could not write to register 0
    [  250.462966] addi9036 0-0064: could not write to register 0
    [  250.462972] addi9036 0-0064: could not write to register 0
    [  250.462979] addi9036 0-0064: could not write to register 0
    [  250.462985] addi9036 0-0064: could not write to register 0
    [  250.462992] addi9036 0-0064: could not write to register 0
    [  250.462999] addi9036 0-0064: could not write to register 0
    [  250.463005] addi9036 0-0064: could not write to register 0
    [  250.463011] addi9036 0-0064: could not write to register 0
    [  250.463017] addi9036 0-0064: could not write to register 0
    [  250.463024] addi9036 0-0064: could not write to register 0
    [  250.463028] addi9036 0-0064: could not write to register 0
    [  250.463032] addi9036 0-0064: could not write to register 0
    [  250.463036] addi9036 0-0064: could not write to register 0
    [  250.463040] addi9036 0-0064: could not write to register 0
    [  250.463044] addi9036 0-0064: could not write to register 0
    [  250.463048] addi9036 0-0064: could not write to register 0
    [  250.463052] addi9036 0-0064: could not write to register 0
    [  250.463056] addi9036 0-0064: could not write to register 0
    [  250.463061] addi9036 0-0064: could not write to register 0
    [  250.463064] addi9036 0-0064: could not write to register 0
    [  250.463069] addi9036 0-0064: could not write to register 0
    [  250.463073] addi9036 0-0064: could not write to register 0
    [  250.463076] addi9036 0-0064: could not write to register 0
    [  250.463080] addi9036 0-0064: could not write to register 0
    [  250.463084] addi9036 0-0064: could not write to register 0
    [  250.463088] addi9036 0-0064: could not write to register 0
    [  250.463092] addi9036 0-0064: could not write to register 0
    [  250.463096] addi9036 0-0064: could not write to register 0
    [  250.463100] addi9036 0-0064: could not write to register 0
    [  250.463104] addi9036 0-0064: could not write to register 0
    [  250.463108] addi9036 0-0064: could not write to register 0
    [  250.463112] addi9036 0-0064: could not write to register 0
    [  250.463116] addi9036 0-0064: could not write to register 0
    [  250.463120] addi9036 0-0064: could not write to register 0
    [  250.463124] addi9036 0-0064: could not write to register 0
    [  250.463128] addi9036 0-0064: could not write to register 0
    [  250.463132] addi9036 0-0064: could not write to register 0
    [  250.463136] addi9036 0-0064: could not write to register 0
    [  250.463140] addi9036 0-0064: could not write to register 0
    [  250.463144] addi9036 0-0064: could not write to register 0
    [  250.463148] addi9036 0-0064: could not write to register 0
    [  250.463152] addi9036 0-0064: could not write to register 0
    [  250.463156] addi9036 0-0064: could not write to register 0
    [  250.463160] addi9036 0-0064: could not write to register 0
    [  250.463164] addi9036 0-0064: could not write to register 0
    [  250.463168] addi9036 0-0064: could not write to register 0
    [  250.463172] addi9036 0-0064: could not write to register 0
    [  250.463176] addi9036 0-0064: could not write to register 0
    [  250.463180] addi9036 0-0064: could not write to register 0
    [  250.463183] addi9036 0-0064: could not write to register 0
    [  250.463187] addi9036 0-0064: could not write to register 0
    [  250.463191] addi9036 0-0064: could not write to register 0
    [  250.463195] addi9036 0-0064: could not write to register 0
    [  250.463199] addi9036 0-0064: could not write to register 0
    [  250.463203] addi9036 0-0064: could not write to register 0
    [  250.463207] addi9036 0-0064: could not write to register 0
    [  250.463211] addi9036 0-0064: could not write to register 0
    [  250.463215] addi9036 0-0064: could not write to register 0
    [  250.463219] addi9036 0-0064: could not write to register 0
    [  250.463223] addi9036 0-0064: could not write to register 0
    [  250.463227] addi9036 0-0064: could not write to register 0
    [  250.463231] addi9036 0-0064: could not write to register 0
    [  250.463235] addi9036 0-0064: could not write to register 0
    [  250.463239] addi9036 0-0064: could not write to register 0
    [  250.463248] addi9036 0-0064: could not write to register 0
    [  250.463252] addi9036 0-0064: could not write to register 0
    [  250.463256] addi9036 0-0064: could not write to register 0
    [  250.463260] addi9036 0-0064: could not write to register 0
    [  250.463264] addi9036 0-0064: could not write to register 0
    [  250.463268] addi9036 0-0064: could not write to register 0
    [  250.463272] addi9036 0-0064: could not write to register 0
    [  250.463276] addi9036 0-0064: could not write to register 0
    [  250.463280] addi9036 0-0064: could not write to register 0
    [  250.463284] addi9036 0-0064: could not write to register 0
    [  250.463288] addi9036 0-0064: could not write to register 0
    [  250.463292] addi9036 0-0064: could not write to register 0
    [  250.463296] addi9036 0-0064: could not write to register 0
    [  250.463299] addi9036 0-0064: could not write to register 0
    [  250.463303] addi9036 0-0064: could not write to register 0
    [  250.463307] addi9036 0-0064: could not write to register 0
    [  250.463311] addi9036 0-0064: could not write to register 0
    [  250.463315] addi9036 0-0064: could not write to register 0
    [  250.463319] addi9036 0-0064: could not write to register 0
    [  250.463323] addi9036 0-0064: could not write to register 0
    [  250.463327] addi9036 0-0064: could not write to register 0
    [  250.463332] addi9036 0-0064: could not write to register 0
    [  250.463336] addi9036 0-0064: could not write to register 0
    [  250.463340] addi9036 0-0064: could not write to register 0
    [  250.463344] addi9036 0-0064: could not write to register 0
    [  250.463348] addi9036 0-0064: could not write to register 0
    [  250.463352] addi9036 0-0064: could not write to register 0
    [  250.463356] addi9036 0-0064: could not write to register 0
    [  250.463360] addi9036 0-0064: could not write to register 0
    [  250.463364] addi9036 0-0064: could not write to register 0
    [  250.463368] addi9036 0-0064: could not write to register 0
    [  250.463371] addi9036 0-0064: could not write to register 0
    [  250.463375] addi9036 0-0064: could not write to register 0
    [  250.463379] addi9036 0-0064: could not write to register 0
    [  250.463383] addi9036 0-0064: could not write to register 0
    [  250.463387] addi9036 0-0064: could not write to register 0
    [  250.463391] addi9036 0-0064: could not write to register 0
    [  250.463395] addi9036 0-0064: could not write to register 0
    [  250.463399] addi9036 0-0064: could not write to register 0
    [  250.463403] addi9036 0-0064: could not write to register 0
    [  250.463407] addi9036 0-0064: could not write to register 0
    [  250.463411] addi9036 0-0064: could not write to register 0
    [  250.463414] addi9036 0-0064: could not write to register 0
    [  250.463418] addi9036 0-0064: could not write to register 0
    [  250.463422] addi9036 0-0064: could not write to register 0
    [  250.463426] addi9036 0-0064: could not write to register 0
    [  250.463430] addi9036 0-0064: could not write to register 0
    [  250.463434] addi9036 0-0064: could not write to register 0
    [  250.463438] addi9036 0-0064: could not write to register 0
    [  250.463442] addi9036 0-0064: could not write to register 0
    [  250.463446] addi9036 0-0064: could not write to register 0
    [  250.463450] addi9036 0-0064: could not write to register 0
    [  250.463454] addi9036 0-0064: could not write to register 0
    [  250.463457] addi9036 0-0064: could not write to register 0
    [  250.463461] addi9036 0-0064: could not write to register 0
    [  250.463465] addi9036 0-0064: could not write to register 0
    [  250.463470] addi9036 0-0064: could not write to register 0
    [  250.463474] addi9036 0-0064: could not write to register 0
    [  250.463478] addi9036 0-0064: could not write to register 0
    [  250.463482] addi9036 0-0064: could not write to register 0
    [  250.463486] addi9036 0-0064: could not write to register 0
    [  250.463489] addi9036 0-0064: could not write to register 0
    [  250.463493] addi9036 0-0064: could not write to register 0
    [  250.463497] addi9036 0-0064: could not write to register 0
    [  250.463501] addi9036 0-0064: could not write to register 0
    [  250.463505] addi9036 0-0064: could not write to register 0
    [  250.463509] addi9036 0-0064: could not write to register 0
    [  250.463513] addi9036 0-0064: could not write to register 0
    [  250.463517] addi9036 0-0064: could not write to register 0
    [  250.463521] addi9036 0-0064: could not write to register 0
    [  250.463525] addi9036 0-0064: could not write to register 0
    [  250.463529] addi9036 0-0064: could not write to register 0
    [  250.463533] addi9036 0-0064: could not write to register 0
    [  250.463537] addi9036 0-0064: could not write to register 0
    [  250.463540] addi9036 0-0064: could not write to register 0
    [  250.463544] addi9036 0-0064: could not write to register 0
    [  250.463548] addi9036 0-0064: could not write to register 0
    [  250.463552] addi9036 0-0064: could not write to register 0
    [  250.463556] addi9036 0-0064: could not write to register 0
    [  250.463560] addi9036 0-0064: could not write to register 0
    [  250.463564] addi9036 0-0064: could not write to register 0
    [  250.463568] addi9036 0-0064: could not write to register 0
    [  250.463572] addi9036 0-0064: could not write to register 0
    [  250.463576] addi9036 0-0064: could not write to register 0
    [  250.463580] addi9036 0-0064: could not write to register 0
    [  250.463584] addi9036 0-0064: could not write to register 0
    [  250.463587] addi9036 0-0064: could not write to register 0
    [  250.463591] addi9036 0-0064: could not write to register 0
    [  250.463595] addi9036 0-0064: could not write to register 0
    [  250.463599] addi9036 0-0064: could not write to register 0
    [  250.463603] addi9036 0-0064: could not write to register 0
    [  250.463608] addi9036 0-0064: could not write to register 0
    [  250.463612] addi9036 0-0064: could not write to register 0
    [  250.463615] addi9036 0-0064: could not write to register 0
    [  250.463619] addi9036 0-0064: could not write to register 0
    [  250.463623] addi9036 0-0064: could not write to register 0
    [  250.463627] addi9036 0-0064: could not write to register 0
    [  250.463631] addi9036 0-0064: could not write to register 0
    [  250.463635] addi9036 0-0064: could not write to register 0
    [  250.463639] addi9036 0-0064: could not write to register 0
    [  250.463643] addi9036 0-0064: could not write to register 0
    [  250.463647] addi9036 0-0064: could not write to register 0
    [  250.463651] addi9036 0-0064: could not write to register 0
    [  250.463654] addi9036 0-0064: could not write to register 0
    [  250.463658] addi9036 0-0064: could not write to register 0
    [  250.463662] addi9036 0-0064: could not write to register 0
    [  250.463666] addi9036 0-0064: could not write to register 0
    [  250.463670] addi9036 0-0064: could not write to register 0
    [  250.463674] addi9036 0-0064: could not write to register 0
    [  250.463683] addi9036 0-0064: could not write to register 0
    [  250.463690] addi9036 0-0064: could not write to register 0
    [  250.463697] addi9036 0-0064: could not write to register 0
    [  250.463703] addi9036 0-0064: could not write to register 0
    [  250.463710] addi9036 0-0064: could not write to register 0
    [  250.463716] addi9036 0-0064: could not write to register 0
    [  250.463722] addi9036 0-0064: could not write to register 0
    [  250.463729] addi9036 0-0064: could not write to register 0
    [  250.463736] addi9036 0-0064: could not write to register 0
    [  250.463742] addi9036 0-0064: could not write to register 0
    [  250.463749] addi9036 0-0064: could not write to register 0
    [  250.463755] addi9036 0-0064: could not write to register 0
    [  250.463761] addi9036 0-0064: could not write to register 0
    [  250.463767] addi9036 0-0064: could not write to register 0
    [  250.463773] addi9036 0-0064: could not write to register 0
    [  250.463780] addi9036 0-0064: could not write to register 0
    [  250.463786] addi9036 0-0064: could not write to register 0
    [  250.463793] addi9036 0-0064: could not write to register 0
    [  250.463799] addi9036 0-0064: could not write to register 0
    [  250.463805] addi9036 0-0064: could not write to register 0
    [  250.463811] addi9036 0-0064: could not write to register 0
    [  250.463818] addi9036 0-0064: could not write to register 0
    [  250.463824] addi9036 0-0064: could not write to register 0
    [  250.463830] addi9036 0-0064: could not write to register 0
    [  250.463836] addi9036 0-0064: could not write to register 0
    [  250.463843] addi9036 0-0064: could not write to register 0
    [  250.463850] addi9036 0-0064: could not write to register 0
    [  250.463856] addi9036 0-0064: could not write to register 0
    [  250.463863] addi9036 0-0064: could not write to register 0
    [  250.463869] addi9036 0-0064: could not write to register 0
    [  250.463875] addi9036 0-0064: could not write to register 0
    [  250.463882] addi9036 0-0064: could not write to register 0
    [  250.463888] addi9036 0-0064: could not write to register 0
    [  250.463894] addi9036 0-0064: could not write to register 0
    [  250.463901] addi9036 0-0064: could not write to register 0
    [  250.463907] addi9036 0-0064: could not write to register 0
    [  250.463914] addi9036 0-0064: could not write to register 0
    [  250.463921] addi9036 0-0064: could not write to register 0
    [  250.463927] addi9036 0-0064: could not write to register 0
    [  250.463934] addi9036 0-0064: could not write to register 0
    [  250.463940] addi9036 0-0064: could not write to register 0
    [  250.463946] addi9036 0-0064: could not write to register 0
    [  250.463953] addi9036 0-0064: could not write to register 0
    [  250.463959] addi9036 0-0064: could not write to register 0
    [  250.463966] addi9036 0-0064: could not write to register 0
    [  250.463972] addi9036 0-0064: could not write to register 0
    [  250.463979] addi9036 0-0064: could not write to register 0
    [  250.463985] addi9036 0-0064: could not write to register 0
    [  250.463991] addi9036 0-0064: could not write to register 0
    [  250.463997] addi9036 0-0064: could not write to register 0
    [  250.464004] addi9036 0-0064: could not write to register 0
    [  250.464010] addi9036 0-0064: could not write to register 0
    [  250.464016] addi9036 0-0064: could not write to register 0
    [  250.464022] addi9036 0-0064: could not write to register 0
    [  250.464029] addi9036 0-0064: could not write to register 0
    [  250.464035] addi9036 0-0064: could not write to register 0
    [  250.464041] addi9036 0-0064: could not write to register 0
    [  250.464048] addi9036 0-0064: could not write to register 0
    [  250.464054] addi9036 0-0064: could not write to register 0
    [  250.464060] addi9036 0-0064: could not write to register 0
    [  250.464066] addi9036 0-0064: could not write to register 0
    [  250.464073] addi9036 0-0064: could not write to register 0
    [  250.464080] addi9036 0-0064: could not write to register 0
    [  250.464084] addi9036 0-0064: could not write to register 0
    [  250.464088] addi9036 0-0064: could not write to register 0
    [  250.464092] addi9036 0-0064: could not write to register 0
    [  250.464096] addi9036 0-0064: could not write to register 0
    [  250.464099] addi9036 0-0064: could not write to register 0
    [  250.464103] addi9036 0-0064: could not write to register 0
    [  250.464107] addi9036 0-0064: could not write to register 0
    [  250.464111] addi9036 0-0064: could not write to register 0
    [  250.464115] addi9036 0-0064: could not write to register 0
    [  250.464119] addi9036 0-0064: could not write to register 0
    [  250.464129] addi9036 0-0064: could not write to register 0
    [  250.464133] addi9036 0-0064: could not write to register 0
    [  250.464137] addi9036 0-0064: could not write to register 0
    [  250.464141] addi9036 0-0064: could not write to register 0
    [  250.464144] addi9036 0-0064: could not write to register 0
    [  250.464148] addi9036 0-0064: could not write to register 0
    [  250.464152] addi9036 0-0064: could not write to register 0
    [  250.464156] addi9036 0-0064: could not write to register 0
    [  250.464160] addi9036 0-0064: could not write to register 0
    [  250.464164] addi9036 0-0064: could not write to register 0
    [  250.464168] addi9036 0-0064: could not write to register 0
    [  250.464172] addi9036 0-0064: could not write to register 0
    [  250.464176] addi9036 0-0064: could not write to register 0
    [  250.464179] addi9036 0-0064: could not write to register 0
    [  250.464183] addi9036 0-0064: could not write to register 0
    [  250.464187] addi9036 0-0064: could not write to register 0
    [  250.464191] addi9036 0-0064: could not write to register 0
    [  250.464195] addi9036 0-0064: could not write to register 0
    [  250.464199] addi9036 0-0064: could not write to register 0
    [  250.464203] addi9036 0-0064: could not write to register 0
    [  250.464206] addi9036 0-0064: could not write to register 0
    [  250.464210] addi9036 0-0064: could not write to register 0
    [  250.464214] addi9036 0-0064: could not write to register 0
    [  250.464218] addi9036 0-0064: could not write to register 0
    [  250.464222] addi9036 0-0064: could not write to register 0
    [  250.464226] addi9036 0-0064: could not write to register 0
    [  250.464230] addi9036 0-0064: could not write to register 0
    [  250.464234] addi9036 0-0064: could not write to register 0
    [  250.464238] addi9036 0-0064: could not write to register 0
    [  250.464242] addi9036 0-0064: could not write to register 0
    [  250.464246] addi9036 0-0064: could not write to register 0
    [  250.464250] addi9036 0-0064: could not write to register 0
    [  250.464254] addi9036 0-0064: could not write to register 0
    [  250.464257] addi9036 0-0064: could not write to register 0
    [  250.464261] addi9036 0-0064: could not write to register 0
    [  250.464265] addi9036 0-0064: could not write to register 0
    [  250.464269] addi9036 0-0064: could not write to register 0
    [  250.464273] addi9036 0-0064: could not write to register 0
    [  250.464277] addi9036 0-0064: could not write to register 0
    [  250.464282] addi9036 0-0064: could not write to register 0
    [  250.464285] addi9036 0-0064: could not write to register 0
    [  250.464289] addi9036 0-0064: could not write to register 0
    [  250.464293] addi9036 0-0064: could not write to register 0
    [  250.464297] addi9036 0-0064: could not write to register 0
    [  250.464301] addi9036 0-0064: could not write to register 0
    [  250.464305] addi9036 0-0064: could not write to register 0
    [  250.464309] addi9036 0-0064: could not write to register 0
    [  250.464313] addi9036 0-0064: could not write to register 0
    [  250.464316] addi9036 0-0064: could not write to register 0
    [  250.464320] addi9036 0-0064: could not write to register 0
    [  250.464324] addi9036 0-0064: could not write to register 0
    [  250.464328] addi9036 0-0064: could not write to register 0
    [  250.464332] addi9036 0-0064: could not write to register 0
    [  250.464336] addi9036 0-0064: could not write to register 0
    [  250.464340] addi9036 0-0064: could not write to register 0
    [  250.464343] addi9036 0-0064: could not write to register 0
    [  250.464347] addi9036 0-0064: could not write to register 0
    [  250.464351] addi9036 0-0064: could not write to register 0
    [  250.464355] addi9036 0-0064: could not write to register 0
    [  250.464359] addi9036 0-0064: could not write to register 0
    [  250.464363] addi9036 0-0064: could not write to register 0
    [  250.464367] addi9036 0-0064: could not write to register 0
    [  250.464371] addi9036 0-0064: could not write to register 0
    [  250.464374] addi9036 0-0064: could not write to register 0
    [  250.464378] addi9036 0-0064: could not write to register 0
    [  250.464382] addi9036 0-0064: could not write to register 0
    [  250.464386] addi9036 0-0064: could not write to register 0
    [  250.464390] addi9036 0-0064: could not write to register 0
    [  250.464394] addi9036 0-0064: could not write to register 0
    [  250.464398] addi9036 0-0064: could not write to register 0
    [  250.464401] addi9036 0-0064: could not write to register 0
    [  250.464405] addi9036 0-0064: could not write to register 0
    [  250.464409] addi9036 0-0064: could not write to register 0
    [  250.464413] addi9036 0-0064: could not write to register 0
    [  250.464417] addi9036 0-0064: could not write to register 0
    [  250.464421] addi9036 0-0064: could not write to register 0
    [  250.464425] addi9036 0-0064: could not write to register 0
    [  250.464429] addi9036 0-0064: could not write to register 0
    [  250.464432] addi9036 0-0064: could not write to register 0
    [  250.464436] addi9036 0-0064: could not write to register 0
    [  250.464440] addi9036 0-0064: could not write to register 0
    [  250.464444] addi9036 0-0064: could not write to register 0
    [  250.464448] addi9036 0-0064: could not write to register 0
    [  250.464452] addi9036 0-0064: could not write to register 0
    [  250.464456] addi9036 0-0064: could not write to register 0
    [  250.464460] addi9036 0-0064: could not write to register 0
    [  250.464463] addi9036 0-0064: could not write to register 0
    [  250.464467] addi9036 0-0064: could not write to register 0
    [  250.464471] addi9036 0-0064: could not write to register 0
    [  250.464475] addi9036 0-0064: could not write to register 0
    [  250.464479] addi9036 0-0064: could not write to register 0
    [  250.464483] addi9036 0-0064: could not write to register 0
    [  250.464487] addi9036 0-0064: could not write to register 0
    [  250.464491] addi9036 0-0064: could not write to register 0
    [  250.464495] addi9036 0-0064: could not write to register 0
    [  250.464498] addi9036 0-0064: could not write to register 0
    [  250.464502] addi9036 0-0064: could not write to register 0
    [  250.464506] addi9036 0-0064: could not write to register 0
    [  250.464510] addi9036 0-0064: could not write to register 0
    [  250.464514] addi9036 0-0064: could not write to register 0
    [  250.464518] addi9036 0-0064: could not write to register 0
    [  250.464522] addi9036 0-0064: could not write to register 0
    [  250.464527] addi9036 0-0064: could not write to register 0
    [  250.464530] addi9036 0-0064: could not write to register 0
    [  250.464534] addi9036 0-0064: could not write to register 0
    [  250.464538] addi9036 0-0064: could not write to register 0
    [  250.464542] addi9036 0-0064: could not write to register 0
    [  250.464546] addi9036 0-0064: could not write to register 0
    [  250.464550] addi9036 0-0064: could not write to register 0
    [  250.464554] addi9036 0-0064: could not write to register 0
    [  250.464558] addi9036 0-0064: could not write to register 0
    [  250.464562] addi9036 0-0064: could not write to register 0
    [  250.464566] addi9036 0-0064: could not write to register 0
    [  250.464569] addi9036 0-0064: could not write to register 0
    [  250.464573] addi9036 0-0064: could not write to register 0
    [  250.464577] addi9036 0-0064: could not write to register 0
    [  250.464581] addi9036 0-0064: could not write to register 0
    [  250.464585] addi9036 0-0064: could not write to register 0
    [  250.464589] addi9036 0-0064: could not write to register 0
    [  250.464593] addi9036 0-0064: could not write to register 0
    [  250.464596] addi9036 0-0064: could not write to register 0
    [  250.464600] addi9036 0-0064: could not write to register 0
    [  250.464604] addi9036 0-0064: could not write to register 0
    [  250.464608] addi9036 0-0064: could not write to register 0
    [  250.464612] addi9036 0-0064: could not write to register 0
    [  250.464616] addi9036 0-0064: could not write to register 0
    [  250.464620] addi9036 0-0064: could not write to register 0
    [  250.464624] addi9036 0-0064: could not write to register 0
    [  250.464628] addi9036 0-0064: could not write to register 0
    [  250.464637] addi9036 0-0064: could not write to register 0
    [  250.464643] addi9036 0-0064: could not write to register 0
    [  250.464650] addi9036 0-0064: could not write to register 0
    [  250.464656] addi9036 0-0064: could not write to register 0
    [  250.464662] addi9036 0-0064: could not write to register 0
    [  250.464669] addi9036 0-0064: could not write to register 0
    [  250.464675] addi9036 0-0064: could not write to register 0
    [  250.464682] addi9036 0-0064: could not write to register 0
    [  250.464688] addi9036 0-0064: could not write to register 0
    [  250.464694] addi9036 0-0064: could not write to register 0
    [  250.464701] addi9036 0-0064: could not write to register 0
    [  250.464707] addi9036 0-0064: could not write to register 0
    [  250.464714] addi9036 0-0064: could not write to register 0
    [  250.464720] addi9036 0-0064: could not write to register 0
    [  250.464726] addi9036 0-0064: could not write to register 0
    [  250.464733] addi9036 0-0064: could not write to register 0
    [  250.464739] addi9036 0-0064: could not write to register 0
    [  250.464745] addi9036 0-0064: could not write to register 0
    [  250.464751] addi9036 0-0064: could not write to register 0
    [  250.464758] addi9036 0-0064: could not write to register 0
    [  250.464764] addi9036 0-0064: could not write to register 0
    [  250.464770] addi9036 0-0064: could not write to register 0
    [  250.464776] addi9036 0-0064: could not write to register 0
    [  250.464783] addi9036 0-0064: could not write to register 0
    [  250.464789] addi9036 0-0064: could not write to register 0
    [  250.464795] addi9036 0-0064: could not write to register 0
    [  250.464802] addi9036 0-0064: could not write to register 0
    [  250.464809] addi9036 0-0064: could not write to register 0
    [  250.464815] addi9036 0-0064: could not write to register 0
    [  250.464821] addi9036 0-0064: could not write to register 0
    [  250.464828] addi9036 0-0064: could not write to register 0
    [  250.464834] addi9036 0-0064: could not write to register 0
    [  250.464840] addi9036 0-0064: could not write to register 0
    [  250.464846] addi9036 0-0064: could not write to register 0
    [  250.464853] addi9036 0-0064: could not write to register 0
    [  250.464859] addi9036 0-0064: could not write to register 0
    [  250.464865] addi9036 0-0064: could not write to register 0
    [  250.464871] addi9036 0-0064: could not write to register 0
    [  250.464878] addi9036 0-0064: could not write to register 0
    [  250.464885] addi9036 0-0064: could not write to register 0
    [  250.464891] addi9036 0-0064: could not write to register 0
    [  250.464897] addi9036 0-0064: could not write to register 0
    [  250.464904] addi9036 0-0064: could not write to register 0
    [  250.464910] addi9036 0-0064: could not write to register 0
    [  250.464916] addi9036 0-0064: could not write to register 0
    [  250.464923] addi9036 0-0064: could not write to register 0
    [  250.464929] addi9036 0-0064: could not write to register 0
    [  250.464935] addi9036 0-0064: could not write to register 0
    [  250.464941] addi9036 0-0064: could not write to register 0
    [  250.464948] addi9036 0-0064: could not write to register 0
    [  250.464954] addi9036 0-0064: could not write to register 0
    [  250.464960] addi9036 0-0064: could not write to register 0
    [  250.464966] addi9036 0-0064: could not write to register 0
    [  250.464972] addi9036 0-0064: could not write to register 0
    [  250.464979] addi9036 0-0064: could not write to register 0
    [  250.464985] addi9036 0-0064: could not write to register 0
    [  250.464992] addi9036 0-0064: could not write to register 0
    [  250.464998] addi9036 0-0064: could not write to register 0
    [  250.465005] addi9036 0-0064: could not write to register 0
    [  250.465011] addi9036 0-0064: could not write to register 0
    [  250.465018] addi9036 0-0064: could not write to register 0
    [  250.465024] addi9036 0-0064: could not write to register 0
    [  250.465030] addi9036 0-0064: could not write to register 0
    [  250.465034] addi9036 0-0064: could not write to register 0
    [  250.465038] addi9036 0-0064: could not write to register 0
    [  250.465042] addi9036 0-0064: could not write to register 0
    [  250.465046] addi9036 0-0064: could not write to register 0
    [  250.465050] addi9036 0-0064: could not write to register 0
    [  250.465054] addi9036 0-0064: could not write to register 0
    [  250.465058] addi9036 0-0064: could not write to register 0
    [  250.465063] addi9036 0-0064: could not write to register 0
    [  250.465067] addi9036 0-0064: could not write to register 0
    [  250.465070] addi9036 0-0064: could not write to register 0
    [  250.465074] addi9036 0-0064: could not write to register 0
    [  250.465082] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465083] addi9036 0-0064: could not write to register 0
    [  250.465087] addi9036 0-0064: could not write to register 0
    [  250.465091] addi9036 0-0064: could not write to register 0
    [  250.465095] addi9036 0-0064: could not write to register 0
    [  250.465099] addi9036 0-0064: could not write to register 0
    [  250.465103] addi9036 0-0064: could not write to register 0
    [  250.465107] addi9036 0-0064: could not write to register 0
    [  250.465111] addi9036 0-0064: could not write to register 0
    [  250.465115] addi9036 0-0064: could not write to register 0
    [  250.465119] addi9036 0-0064: could not write to register 0
    [  250.465124] addi9036 0-0064: could not write to register 0
    [  250.465125] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465129] addi9036 0-0064: could not write to register 0
    [  250.465133] addi9036 0-0064: could not write to register 0
    [  250.465137] addi9036 0-0064: could not write to register 0
    [  250.465141] addi9036 0-0064: could not write to register 0
    [  250.465145] addi9036 0-0064: could not write to register 0
    [  250.465149] addi9036 0-0064: could not write to register 0
    [  250.465153] addi9036 0-0064: could not write to register 0
    [  250.465157] addi9036 0-0064: could not write to register 0
    [  250.465161] addi9036 0-0064: could not write to register 0
    [  250.465162] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465165] addi9036 0-0064: could not write to register 0
    [  250.465170] addi9036 0-0064: could not write to register 0
    [  250.465174] addi9036 0-0064: could not write to register 0
    [  250.465178] addi9036 0-0064: could not write to register 0
    [  250.465182] addi9036 0-0064: could not write to register 0
    [  250.465186] addi9036 0-0064: could not write to register 0
    [  250.465190] addi9036 0-0064: could not write to register 0
    [  250.465194] addi9036 0-0064: could not write to register 0
    [  250.465195] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465198] addi9036 0-0064: could not write to register 0
    [  250.465202] addi9036 0-0064: could not write to register 0
    [  250.465206] addi9036 0-0064: could not write to register 0
    [  250.465210] addi9036 0-0064: could not write to register 0
    [  250.465214] addi9036 0-0064: could not write to register 0
    [  250.465218] addi9036 0-0064: could not write to register 0
    [  250.465222] addi9036 0-0064: could not write to register 0
    [  250.465226] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465228] addi9036 0-0064: could not write to register 0
    [  250.465231] addi9036 0-0064: could not write to register 0
    [  250.465235] addi9036 0-0064: could not write to register 0
    [  250.465239] addi9036 0-0064: could not write to register 0
    [  250.465243] addi9036 0-0064: could not write to register 0
    [  250.465247] addi9036 0-0064: could not write to register 0
    [  250.465251] addi9036 0-0064: could not write to register 0
    [  250.465255] addi9036 0-0064: could not write to register 0
    [  250.465258] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465260] addi9036 0-0064: could not write to register 0
    [  250.465263] addi9036 0-0064: could not write to register 0
    [  250.465267] addi9036 0-0064: could not write to register 0
    [  250.465271] addi9036 0-0064: could not write to register 0
    [  250.465275] addi9036 0-0064: could not write to register 0
    [  250.465279] addi9036 0-0064: could not write to register 0
    [  250.465283] addi9036 0-0064: could not write to register 0
    [  250.465287] addi9036 0-0064: could not write to register 0
    [  250.465291] addi9036 0-0064: could not write to register 0
    [  250.465295] addi9036 0-0064: could not write to register 0
    [  250.465299] addi9036 0-0064: could not write to register 0
    [  250.465303] addi9036 0-0064: could not write to register 0
    [  250.465308] addi9036 0-0064: could not write to register 0
    [  250.465309] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465313] addi9036 0-0064: could not write to register 0
    [  250.465317] addi9036 0-0064: could not write to register 0
    [  250.465320] addi9036 0-0064: could not write to register 0
    [  250.465324] addi9036 0-0064: could not write to register 0
    [  250.465328] addi9036 0-0064: could not write to register 0
    [  250.465332] addi9036 0-0064: could not write to register 0
    [  250.465336] addi9036 0-0064: could not write to register 0
    [  250.465340] addi9036 0-0064: could not write to register 0
    [  250.465341] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    [  250.465345] addi9036 0-0064: could not write to register 0
    [  250.465349] addi9036 0-0064: could not write to register 0
    [  250.465354] addi9036 0-0064: could not write to register 0
    [  250.465358] addi9036 0-0064: could not write to register 0
    [  250.465362] addi9036 0-0064: could not write to register 0
    [  250.465365] addi9036 0-0064: could not write to register 0
    [  250.465369] addi9036 0-0064: could not write to register 0
    [  250.465372] systemd-journald[117]: /dev/kmsg buffer overrun, some messages lost.
    Unfortunately there are no other outputs than the register 0 output and some overruns.
    Best regards
    Dustin
  • This has more logs but it's not the full log.
    Please try to dump the entire output into a file and attach it here. Something like:
    dmesg > mylog.txt
  • Hope this is now the complete log. It is out of the syslog file, including a reboot of the Raspberry Pi and running of the aditof-demo.sh until the error messages occure.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopping Session c1 of user pi.
    Jul 19 14:17:01 raspberrypi systemd[1]: systemd-rfkill.socket: Succeeded.
    Jul 19 14:17:01 raspberrypi systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopped target Bluetooth.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopped target Sound Card.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopping BluezALSA proxy...
    Jul 19 14:17:01 raspberrypi systemd[1]: Removed slice system-bthelper.slice.
    Jul 19 14:17:01 raspberrypi systemd[1]: Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopping Authorization Manager...
    Jul 19 14:17:01 raspberrypi bluetoothd[690]: Endpoint unregistered: sender=:1.15 path=/org/bluez/hci0/A2DP/SBC/Source/1
    Jul 19 14:17:01 raspberrypi systemd[1]: Unmounting RPC Pipe File System...
    Jul 19 14:17:01 raspberrypi bluetoothd[690]: Endpoint unregistered: sender=:1.15 path=/org/bluez/hci0/A2DP/SBC/Source/2
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopping Save/Restore Sound Card State...
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopped target Graphical Interface.
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopping Disk Manager...
    Jul 19 14:17:01 raspberrypi systemd[1]: Stopped target Multi-User System.
    Jul 19 14:17:08 raspberrypi systemd-modules-load[119]: Inserted module 'i2c_dev'
    Jul 19 14:17:08 raspberrypi fake-hwclock[114]: Mon 19 Jul 2021 12:17:03 PM UTC
    Jul 19 14:17:08 raspberrypi systemd-fsck[134]: e2fsck 1.44.5 (15-Dec-2018)
    Jul 19 14:17:08 raspberrypi systemd-fsck[134]: rootfs: clean, 132858/941616 files, 1161189/3822976 blocks
    Jul 19 14:17:08 raspberrypi systemd[1]: Started File System Check on Root Device.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
    Jul 19 14:17:08 raspberrypi systemd[1]: Started udev Coldplug all Devices.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Load/Save Random Seed...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Create System Users...
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Load/Save Random Seed.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Set the console keyboard layout.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Create System Users.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
    Jul 19 14:17:08 raspberrypi systemd[1]: Started udev Kernel Device Manager.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
    Jul 19 14:17:08 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 166 (plymouthd).
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Local Encrypted Volumes.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Paths.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
    Jul 19 14:17:08 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
    Jul 19 14:17:08 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
    Jul 19 14:17:08 raspberrypi systemd[1]: Found device /dev/serial1.
    Jul 19 14:17:08 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Jul 19 14:17:08 raspberrypi mtp-probe: bus: 1, device: 5 was not an MTP device
    Jul 19 14:17:08 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
    Jul 19 14:17:08 raspberrypi mtp-probe: bus: 1, device: 4 was not an MTP device
    Jul 19 14:17:08 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/d9b3f436-01.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/d9b3f436-01...
    Jul 19 14:17:08 raspberrypi systemd-udevd[159]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Jul 19 14:17:08 raspberrypi systemd-udevd[162]: Using default interface naming scheme 'v240'.
    Jul 19 14:17:08 raspberrypi systemd-fsck[228]: fsck.fat 4.1 (2017-01-24)
    Jul 19 14:17:08 raspberrypi systemd-fsck[228]: /dev/mmcblk0p1: 228 files, 186920/516190 clusters
    Jul 19 14:17:08 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/d9b3f436-01.
    Jul 19 14:17:08 raspberrypi systemd[1]: Mounting /boot...
    Jul 19 14:17:08 raspberrypi systemd[1]: Mounted /boot.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Local File Systems.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Set console font and keymap...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Raise network interfaces...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Set console font and keymap.
    Jul 19 14:17:08 raspberrypi systemd[1]: nfs-config.service: Succeeded.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Preprocess NFS configuration.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target NFS client services.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Remote File Systems.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Network Time Synchronization...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
    Jul 19 14:17:08 raspberrypi systemd-udevd[155]: Using default interface naming scheme 'v240'.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    Jul 19 14:17:08 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Raise network interfaces.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Network Time Synchronization.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target System Time Synchronized.
    Jul 19 14:17:08 raspberrypi systemd-udevd[156]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Jul 19 14:17:08 raspberrypi systemd-udevd[164]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Jul 19 14:17:08 raspberrypi systemd-udevd[165]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Jul 19 14:17:08 raspberrypi systemd-udevd[158]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Jul 19 14:17:08 raspberrypi systemd[1]: plymouth-read-write.service: Succeeded.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target System Initialization.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Daily rotation of log files.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Daily apt download activities.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Daily man-db regeneration.
    Jul 19 14:17:08 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    Jul 19 14:17:08 raspberrypi systemd[1]: Listening on triggerhappy.socket.
    Jul 19 14:17:08 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Sockets.
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Basic System.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started tof-server.service.
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Linux version 4.19.86-v7+ (btogorean@btogorean-pc) (gcc version 9.1.0 (GCC)) #1 SMP Tue Apr 13 10:45:36 EEST 2021
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] CPU: div instructions available: patching division code
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Memory policy: Data cache writealloc
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x37800000
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] On node 0 totalpages: 229376
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]   Normal zone: 2016 pages used for memmap
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]   Normal zone: 229376 pages, LIFO batch:63
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xb0/0x4c0 with crng_init=0
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] percpu: Embedded 16 pages/cpu s35660 r8192 d21684 u65536
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] pcpu-alloc: s35660 r8192 d21684 u65536 alloc=16*4096
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 227360
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1680 bcm2708_fb.fbheight=1050 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Regular background program processing daemon.
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Memory: 877480K/917504K available (11264K kernel code, 1234K rwdata, 7200K rodata, 1024K init, 866K bss, 31832K reserved, 8192K cma-reserved)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Disk Manager...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]     vmalloc : 0xb8800000 - 0xff800000   (1136 MB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]     lowmem  : 0x80000000 - 0xb8000000   ( 896 MB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Check for v3d driver...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
    Jul 19 14:17:08 raspberrypi cron[403]: (CRON) INFO (pidfile fd = 3)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   (1235 kB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 867 kB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] ftrace: allocating 39311 entries in 116 pages
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] rcu: Hierarchical RCU implementation.
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
    Jul 19 14:17:08 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    Jul 19 14:17:08 raspberrypi kernel: [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    Jul 19 14:17:08 raspberrypi kernel: [    0.000017] Switching to timer-based delay loop, resolution 52ns
    Jul 19 14:17:08 raspberrypi thd[396]: Found socket passed from systemd
    Jul 19 14:17:08 raspberrypi kernel: [    0.000279] Console: colour dummy device 80x30
    Jul 19 14:17:08 raspberrypi kernel: [    0.000297] console [tty1] enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.000339] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    Jul 19 14:17:08 raspberrypi kernel: [    0.000356] pid_max: default: 32768 minimum: 301
    Jul 19 14:17:08 raspberrypi kernel: [    0.000688] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Login Service...
    Jul 19 14:17:08 raspberrypi kernel: [    0.000704] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.001619] CPU: Testing write buffer coherency: ok
    Jul 19 14:17:08 raspberrypi kernel: [    0.002087] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Jul 19 14:17:08 raspberrypi systemd[1]: Started D-Bus System Message Bus.
    Jul 19 14:17:08 raspberrypi kernel: [    0.002729] Setting up static identity map for 0x100000 - 0x10003c
    Jul 19 14:17:08 raspberrypi kernel: [    0.002879] rcu: Hierarchical SRCU implementation.
    Jul 19 14:17:08 raspberrypi kernel: [    0.003674] smp: Bringing up secondary CPUs ...
    Jul 19 14:17:08 raspberrypi alsactl[416]: alsactl 1.1.8 daemon started
    Jul 19 14:17:08 raspberrypi kernel: [    0.004514] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    Jul 19 14:17:08 raspberrypi kernel: [    0.005444] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    Jul 19 14:17:08 raspberrypi kernel: [    0.006314] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
    Jul 19 14:17:08 raspberrypi kernel: [    0.006441] smp: Brought up 1 node, 4 CPUs
    Jul 19 14:17:08 raspberrypi kernel: [    0.006453] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    Jul 19 14:17:08 raspberrypi kernel: [    0.006459] CPU: All CPU(s) started in HYP mode.
    Jul 19 14:17:08 raspberrypi kernel: [    0.006464] CPU: Virtualization extensions available.
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Successfully dropped root privileges.
    Jul 19 14:17:08 raspberrypi kernel: [    0.007436] devtmpfs: initialized
    Jul 19 14:17:08 raspberrypi kernel: [    0.021096] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    Jul 19 14:17:08 raspberrypi kernel: [    0.021342] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: avahi-daemon 0.7 starting up.
    Jul 19 14:17:08 raspberrypi kernel: [    0.021360] futex hash table entries: 1024 (order: 4, 65536 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.021969] pinctrl core: initialized pinctrl subsystem
    Jul 19 14:17:08 raspberrypi kernel: [    0.022827] NET: Registered protocol family 16
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting WPA supplicant...
    Jul 19 14:17:08 raspberrypi kernel: [    0.025998] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    Jul 19 14:17:08 raspberrypi kernel: [    0.031955] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    Jul 19 14:17:08 raspberrypi kernel: [    0.031963] hw-breakpoint: maximum watchpoint size is 8 bytes.
    Jul 19 14:17:08 raspberrypi kernel: [    0.032172] Serial: AMBA PL011 UART driver
    Jul 19 14:17:08 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
    Jul 19 14:17:08 raspberrypi kernel: [    0.034462] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.073197] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
    Jul 19 14:17:08 raspberrypi kernel: [    0.075543] SCSI subsystem initialized
    Jul 19 14:17:08 raspberrypi kernel: [    0.075777] usbcore: registered new interface driver usbfs
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
    Jul 19 14:17:08 raspberrypi kernel: [    0.075839] usbcore: registered new interface driver hub
    Jul 19 14:17:08 raspberrypi kernel: [    0.075935] usbcore: registered new device driver usb
    Jul 19 14:17:08 raspberrypi kernel: [    0.076126] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
    Jul 19 14:17:08 raspberrypi kernel: [    0.076196] usb_phy_generic phy: Linked as a consumer to regulator.0
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting System Logging Service...
    Jul 19 14:17:08 raspberrypi kernel: [    0.076411] media: Linux media interface: v0.10
    Jul 19 14:17:08 raspberrypi kernel: [    0.076453] videodev: Linux video capture interface: v2.00
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
    Jul 19 14:17:08 raspberrypi kernel: [    0.090304] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:39, variant start_x
    Jul 19 14:17:08 raspberrypi kernel: [    0.100124] raspberrypi-firmware soc:firmware: Firmware hash is 6820edeee4ef3891b95fc01cf02a7abd7ca52f17
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Timers.
    Jul 19 14:17:08 raspberrypi kernel: [    0.110666] jesd204: found 0 devices and 0 topologies
    Jul 19 14:17:08 raspberrypi kernel: [    0.110776] Advanced Linux Sound Architecture Driver Initialized.
    Jul 19 14:17:08 raspberrypi kernel: [    0.112506] clocksource: Switched to clocksource arch_sys_counter
    Jul 19 14:17:08 raspberrypi kernel: [    0.213146] VFS: Disk quotas dquot_6.6.0
    Jul 19 14:17:08 raspberrypi systemd[1]: Starting rng-tools.service...
    Jul 19 14:17:08 raspberrypi kernel: [    0.213239] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.213427] FS-Cache: Loaded
    Jul 19 14:17:08 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
    Jul 19 14:17:08 raspberrypi kernel: [    0.213638] CacheFiles: Loaded
    Jul 19 14:17:08 raspberrypi kernel: [    0.223724] NET: Registered protocol family 2
    Jul 19 14:17:08 raspberrypi kernel: [    0.224476] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.224514] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
    Jul 19 14:17:08 raspberrypi kernel: [    0.224622] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.224807] TCP: Hash tables configured (established 8192 bind 8192)
    Jul 19 14:17:08 raspberrypi kernel: [    0.224944] UDP hash table entries: 512 (order: 2, 16384 bytes)
    Jul 19 14:17:08 raspberrypi systemd[1]: Reached target Sound Card.
    Jul 19 14:17:08 raspberrypi kernel: [    0.224990] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.225311] NET: Registered protocol family 1
    Jul 19 14:17:08 raspberrypi kernel: [    0.225894] RPC: Registered named UNIX socket transport module.
    Jul 19 14:17:08 raspberrypi kernel: [    0.225900] RPC: Registered udp transport module.
    Jul 19 14:17:08 raspberrypi cron[403]: (CRON) INFO (Running @reboot jobs)
    Jul 19 14:17:08 raspberrypi kernel: [    0.225906] RPC: Registered tcp transport module.
    Jul 19 14:17:08 raspberrypi kernel: [    0.225912] RPC: Registered tcp NFSv4.1 backchannel transport module.
    Jul 19 14:17:08 raspberrypi kernel: [    0.227781] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    Jul 19 14:17:08 raspberrypi kernel: [    0.230824] Initialise system trusted keyrings
    Jul 19 14:17:08 raspberrypi kernel: [    0.231023] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    Jul 19 14:17:08 raspberrypi kernel: [    0.240855] FS-Cache: Netfs 'nfs' registered for caching
    Jul 19 14:17:08 raspberrypi kernel: [    0.241415] NFS: Registering the id_resolver key type
    Jul 19 14:17:08 raspberrypi kernel: [    0.241444] Key type id_resolver registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.241450] Key type id_legacy registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.241466] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    Jul 19 14:17:08 raspberrypi kernel: [    0.247071] Key type asymmetric registered
    Jul 19 14:17:08 raspberrypi rngd[451]: rngd 2-unofficial-mt.14 starting up...
    Jul 19 14:17:08 raspberrypi kernel: [    0.247082] Asymmetric key parser 'x509' registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.247142] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    Jul 19 14:17:08 raspberrypi kernel: [    0.247317] io scheduler noop registered
    Jul 19 14:17:08 raspberrypi rng-tools[441]: Starting Hardware RNG entropy gatherer daemon: rngd.
    Jul 19 14:17:08 raspberrypi kernel: [    0.247324] io scheduler deadline registered (default)
    Jul 19 14:17:08 raspberrypi kernel: [    0.247521] io scheduler cfq registered
    Jul 19 14:17:08 raspberrypi rngd[451]: entropy feed to the kernel ready
    Jul 19 14:17:08 raspberrypi dhcpcd[414]: dev: loaded udev
    Jul 19 14:17:08 raspberrypi dphys-swapfile[387]: want /var/swap=100MByte, checking existing: keeping it
    Jul 19 14:17:08 raspberrypi dhcpcd[414]: forked to background, child pid 465
    Jul 19 14:17:08 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
    Jul 19 14:17:08 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="439" x-info="https://www.rsyslog.com"] start
    Jul 19 14:17:08 raspberrypi kernel: [    0.247529] io scheduler mq-deadline registered (default)
    Jul 19 14:17:08 raspberrypi kernel: [    0.247535] io scheduler kyber registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.250150] bcm2708_fb soc:fb: FB found 1 display(s)
    Jul 19 14:17:08 raspberrypi kernel: [    0.276824] Console: switching to colour frame buffer device 210x65
    Jul 19 14:17:08 raspberrypi kernel: [    0.291799] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1680x1050
    Jul 19 14:17:08 raspberrypi kernel: [    0.294244] bcm2835-rng 3f104000.rng: hwrng registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.294679] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    Jul 19 14:17:08 raspberrypi kernel: [    0.295206] vc-sm: Videocore shared memory driver
    Jul 19 14:17:08 raspberrypi kernel: [    0.295540] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    Jul 19 14:17:08 raspberrypi kernel: [    0.306528] brd: module loaded
    Jul 19 14:17:08 raspberrypi kernel: [    0.316656] loop: module loaded
    Jul 19 14:17:08 raspberrypi kernel: [    0.317387] Loading iSCSI transport class v2.0-870.
    Jul 19 14:17:08 raspberrypi kernel: [    0.318355] libphy: Fixed MDIO Bus: probed
    Jul 19 14:17:08 raspberrypi kernel: [    0.318507] usbcore: registered new interface driver lan78xx
    Jul 19 14:17:08 raspberrypi kernel: [    0.318565] usbcore: registered new interface driver smsc95xx
    Jul 19 14:17:08 raspberrypi kernel: [    0.318580] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jul 19 14:17:08 raspberrypi kernel: [    0.318883] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    Jul 19 14:17:08 raspberrypi kernel: [    0.346733] dwc_otg 3f980000.usb: base=(ptrval)
    Jul 19 14:17:08 raspberrypi kernel: [    0.546997] Core Release: 2.80a
    Jul 19 14:17:08 raspberrypi kernel: [    0.547007] Setting default values for core params
    Jul 19 14:17:08 raspberrypi kernel: [    0.547032] Finished setting default values for core params
    Jul 19 14:17:08 raspberrypi kernel: [    0.747344] Using Buffer DMA mode
    Jul 19 14:17:08 raspberrypi kernel: [    0.747352] Periodic Transfer Interrupt Enhancement - disabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.747358] Multiprocessor Interrupt Enhancement - disabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.747365] OTG VER PARAM: 0, OTG VER FLAG: 0
    Jul 19 14:17:08 raspberrypi kernel: [    0.747384] Dedicated Tx FIFOs mode
    Jul 19 14:17:08 raspberrypi kernel: [    0.747867] WARN::dwc_otg_hcd_init:1043: FIQ DMA bounce buffers: virt = b7914000 dma = 0xf7914000 len=9024
    Jul 19 14:17:08 raspberrypi kernel: [    0.747892] FIQ FSM acceleration enabled for :
    Jul 19 14:17:08 raspberrypi kernel: [    0.747892] Non-periodic Split Transactions
    Jul 19 14:17:08 raspberrypi kernel: [    0.747892] Periodic Split Transactions
    Jul 19 14:17:08 raspberrypi kernel: [    0.747892] High-Speed Isochronous Endpoints
    Jul 19 14:17:08 raspberrypi kernel: [    0.747892] Interrupt/Control Split Transaction hack enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.747900] dwc_otg: Microframe scheduler enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.747962] WARN::hcd_init_fiq:457: FIQ on core 1
    Jul 19 14:17:08 raspberrypi kernel: [    0.747974] WARN::hcd_init_fiq:458: FIQ ASM at 806e632c length 36
    Jul 19 14:17:08 raspberrypi kernel: [    0.747986] WARN::hcd_init_fiq:496: MPHI regs_base at b8810000
    Jul 19 14:17:08 raspberrypi kernel: [    0.748004] dwc_otg 3f980000.usb: DWC OTG Controller
    Jul 19 14:17:08 raspberrypi kernel: [    0.748036] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    Jul 19 14:17:08 raspberrypi kernel: [    0.748072] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    Jul 19 14:17:08 raspberrypi kernel: [    0.748119] Init: Port Power? op_state=1
    Jul 19 14:17:08 raspberrypi kernel: [    0.748125] Init: Power Port (0)
    Jul 19 14:17:08 raspberrypi kernel: [    0.748382] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    Jul 19 14:17:08 raspberrypi kernel: [    0.748394] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jul 19 14:17:08 raspberrypi kernel: [    0.748403] usb usb1: Product: DWC OTG Controller
    Jul 19 14:17:08 raspberrypi kernel: [    0.748412] usb usb1: Manufacturer: Linux 4.19.86-v7+ dwc_otg_hcd
    Jul 19 14:17:08 raspberrypi kernel: [    0.748421] usb usb1: SerialNumber: 3f980000.usb
    Jul 19 14:17:08 raspberrypi kernel: [    0.749043] hub 1-0:1.0: USB hub found
    Jul 19 14:17:08 raspberrypi kernel: [    0.749086] hub 1-0:1.0: 1 port detected
    Jul 19 14:17:08 raspberrypi kernel: [    0.749656] dwc_otg: FIQ enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.749662] dwc_otg: NAK holdoff enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.749667] dwc_otg: FIQ split-transaction FSM enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.749678] Module dwc_common_port init
    Jul 19 14:17:08 raspberrypi kernel: [    0.750625] usbcore: registered new interface driver uas
    Jul 19 14:17:08 raspberrypi kernel: [    0.750718] usbcore: registered new interface driver usb-storage
    Jul 19 14:17:08 raspberrypi kernel: [    0.750823] usbcore: registered new interface driver usbserial_generic
    Jul 19 14:17:08 raspberrypi kernel: [    0.750867] usbserial: USB Serial support registered for generic
    Jul 19 14:17:08 raspberrypi kernel: [    0.750911] usbcore: registered new interface driver ftdi_sio
    Jul 19 14:17:08 raspberrypi kernel: [    0.750953] usbserial: USB Serial support registered for FTDI USB Serial Device
    Jul 19 14:17:08 raspberrypi kernel: [    0.751065] usbcore: registered new interface driver upd78f0730
    Jul 19 14:17:08 raspberrypi kernel: [    0.751100] usbserial: USB Serial support registered for upd78f0730
    Jul 19 14:17:08 raspberrypi kernel: [    0.752608] mousedev: PS/2 mouse device common for all mice
    Jul 19 14:17:08 raspberrypi kernel: [    0.753700] usbcore: registered new interface driver uvcvideo
    Jul 19 14:17:08 raspberrypi kernel: [    0.753705] USB Video Class driver (1.1.1)
    Jul 19 14:17:08 raspberrypi kernel: [    0.755537] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    Jul 19 14:17:08 raspberrypi kernel: [    0.755776] bcm2835-cpufreq: min=600000 max=1400000
    Jul 19 14:17:08 raspberrypi kernel: [    0.756257] sdhci: Secure Digital Host Controller Interface driver
    Jul 19 14:17:08 raspberrypi kernel: [    0.756262] sdhci: Copyright(c) Pierre Ossman
    Jul 19 14:17:08 raspberrypi kernel: [    0.756702] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    Jul 19 14:17:08 raspberrypi kernel: [    0.757122] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    Jul 19 14:17:08 raspberrypi kernel: [    0.757256] sdhci-pltfm: SDHCI platform and OF driver helper
    Jul 19 14:17:08 raspberrypi kernel: [    0.758920] ledtrig-cpu: registered to indicate activity on CPUs
    Jul 19 14:17:08 raspberrypi kernel: [    0.759076] hidraw: raw HID events driver (C) Jiri Kosina
    Jul 19 14:17:08 raspberrypi kernel: [    0.759247] usbcore: registered new interface driver usbhid
    Jul 19 14:17:08 raspberrypi kernel: [    0.759252] usbhid: USB HID core driver
    Jul 19 14:17:08 raspberrypi kernel: [    0.760715] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    Jul 19 14:17:08 raspberrypi kernel: [    0.762289] [vc_sm_connected_init]: start
    Jul 19 14:17:08 raspberrypi kernel: [    0.771351] [vc_sm_connected_init]: end - returning 0
    Jul 19 14:17:08 raspberrypi kernel: [    0.779436] usbcore: registered new interface driver snd-usb-audio
    Jul 19 14:17:08 raspberrypi kernel: [    0.781717] Initializing XFRM netlink socket
    Jul 19 14:17:08 raspberrypi kernel: [    0.782591] NET: Registered protocol family 10
    Jul 19 14:17:08 raspberrypi kernel: [    0.783793] Segment Routing with IPv6
    Jul 19 14:17:08 raspberrypi kernel: [    0.783881] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    Jul 19 14:17:08 raspberrypi kernel: [    0.784638] NET: Registered protocol family 17
    Jul 19 14:17:08 raspberrypi kernel: [    0.784687] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    Jul 19 14:17:08 raspberrypi kernel: [    0.785126] Key type dns_resolver registered
    Jul 19 14:17:08 raspberrypi kernel: [    0.785820] Registering SWP/SWPB emulation handler
    Jul 19 14:17:08 raspberrypi kernel: [    0.786491] registered taskstats version 1
    Jul 19 14:17:08 raspberrypi kernel: [    0.786509] Loading compiled-in X.509 certificates
    Jul 19 14:17:08 raspberrypi kernel: [    0.793345] uart-pl011 3f201000.serial: cts_event_workaround enabled
    Jul 19 14:17:08 raspberrypi kernel: [    0.793427] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
    Jul 19 14:17:08 raspberrypi kernel: [    0.795234] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    Jul 19 14:17:08 raspberrypi kernel: [    0.795245] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    Jul 19 14:17:08 raspberrypi kernel: [    0.821529] sdhost: log_buf @ (ptrval) (f7913000)
    Jul 19 14:17:08 raspberrypi kernel: [    0.856526] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.858115] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.859699] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.862547] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    Jul 19 14:17:08 raspberrypi kernel: [    0.870115] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    Jul 19 14:17:08 raspberrypi kernel: [    0.871730] of_cfs_init
    Jul 19 14:17:08 raspberrypi kernel: [    0.871772] of_cfs_init: OK
    Jul 19 14:17:08 raspberrypi kernel: [    0.872046] ALSA device list:
    Jul 19 14:17:08 raspberrypi kernel: [    0.872051]   No soundcards found.
    Jul 19 14:17:08 raspberrypi kernel: [    0.872401] Waiting for root device PARTUUID=d9b3f436-02...
    Jul 19 14:17:08 raspberrypi kernel: [    0.929337] mmc0: host does not support reading read-only switch, assuming write-enable
    Jul 19 14:17:08 raspberrypi kernel: [    0.932281] mmc0: new high speed SDHC card at address 0001
    Jul 19 14:17:08 raspberrypi kernel: [    0.933607] mmcblk0: mmc0:0001 SD16G 29.2 GiB
    Jul 19 14:17:08 raspberrypi kernel: [    0.935671] random: fast init done
    Jul 19 14:17:08 raspberrypi kernel: [    0.935951]  mmcblk0: p1 p2
    Jul 19 14:17:08 raspberrypi kernel: [    0.946686] mmc1: new high speed SDIO card at address 0001
    Jul 19 14:17:08 raspberrypi kernel: [    0.964826] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    Jul 19 14:17:08 raspberrypi kernel: [    0.964883] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    Jul 19 14:17:08 raspberrypi kernel: [    0.966010] devtmpfs: mounted
    Jul 19 14:17:08 raspberrypi kernel: [    0.972676] Indeed it is in host mode hprt0 = 00021501
    Jul 19 14:17:08 raspberrypi kernel: [    0.973317] Freeing unused kernel memory: 1024K
    Jul 19 14:17:08 raspberrypi kernel: [    1.053152] Run /sbin/init as init process
    Jul 19 14:17:08 raspberrypi kernel: [    1.182559] usb 1-1: new high-speed USB device number 2 using dwc_otg
    Jul 19 14:17:08 raspberrypi kernel: [    1.182698] Indeed it is in host mode hprt0 = 00001101
    Jul 19 14:17:08 raspberrypi kernel: [    1.422880] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    Jul 19 14:17:08 raspberrypi kernel: [    1.422896] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Jul 19 14:17:08 raspberrypi kernel: [    1.423565] hub 1-1:1.0: USB hub found
    Jul 19 14:17:08 raspberrypi kernel: [    1.423675] hub 1-1:1.0: 4 ports detected
    Jul 19 14:17:08 raspberrypi kernel: [    1.742559] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    Jul 19 14:17:08 raspberrypi kernel: [    1.873203] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
    Jul 19 14:17:08 raspberrypi kernel: [    1.873224] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Jul 19 14:17:08 raspberrypi kernel: [    1.874183] hub 1-1.1:1.0: USB hub found
    Jul 19 14:17:08 raspberrypi kernel: [    1.874313] hub 1-1.1:1.0: 3 ports detected
    Jul 19 14:17:08 raspberrypi kernel: [    1.972661] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
    Jul 19 14:17:08 raspberrypi kernel: [    2.128348] usb 1-1.2: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
    Jul 19 14:17:08 raspberrypi kernel: [    2.128363] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    Jul 19 14:17:08 raspberrypi kernel: [    2.128373] usb 1-1.2: Product: Dell KB216 Wired Keyboard
    Jul 19 14:17:08 raspberrypi kernel: [    2.142017] input: Dell KB216 Wired Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:2113.0001/input/input0
    Jul 19 14:17:08 raspberrypi kernel: [    2.203162] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.2/input0
    Jul 19 14:17:08 raspberrypi kernel: [    2.221045] input: Dell KB216 Wired Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:413C:2113.0002/input/input1
    Jul 19 14:17:08 raspberrypi kernel: [    2.282804] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:413C:2113.0002/input/input2
    Jul 19 14:17:08 raspberrypi kernel: [    2.283043] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.2/input1
    Jul 19 14:17:08 raspberrypi kernel: [    2.382572] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
    Jul 19 14:17:08 raspberrypi kernel: [    2.517698] usb 1-1.3: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
    Jul 19 14:17:08 raspberrypi kernel: [    2.517714] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Jul 19 14:17:08 raspberrypi kernel: [    2.517723] usb 1-1.3: Product: Dell MS116 USB Optical Mouse
    Jul 19 14:17:08 raspberrypi kernel: [    2.517732] usb 1-1.3: Manufacturer: PixArt
    Jul 19 14:17:08 raspberrypi kernel: [    2.522050] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:301A.0003/input/input3
    Jul 19 14:17:08 raspberrypi kernel: [    2.522441] hid-generic 0003:413C:301A.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-3f980000.usb-1.3/input0
    Jul 19 14:17:08 raspberrypi kernel: [    2.708654] random: systemd: uninitialized urandom read (16 bytes read)
    Jul 19 14:17:08 raspberrypi kernel: [    2.720663] random: systemd: uninitialized urandom read (16 bytes read)
    Jul 19 14:17:08 raspberrypi kernel: [    2.722050] random: systemd: uninitialized urandom read (16 bytes read)
    Jul 19 14:17:08 raspberrypi kernel: [    2.772597] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
    Jul 19 14:17:08 raspberrypi kernel: [    2.906762] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
    Jul 19 14:17:08 raspberrypi kernel: [    2.906778] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Jul 19 14:17:08 raspberrypi kernel: [    2.989429] i2c /dev entries driver
    Jul 19 14:17:08 raspberrypi kernel: [    3.194760] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
    Jul 19 14:17:08 raspberrypi kernel: [    3.195876] libphy: lan78xx-mdiobus: probed
    Jul 19 14:17:08 raspberrypi kernel: [    3.216414] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
    Jul 19 14:17:08 raspberrypi kernel: [    3.506461] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Jul 19 14:17:08 raspberrypi kernel: [    4.574433] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.577404] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    Jul 19 14:17:08 raspberrypi kernel: [    4.577421] [vc_sm_connected_init]: start
    Jul 19 14:17:08 raspberrypi kernel: [    4.577639] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.579995] [vc_sm_connected_init]: installed successfully
    Jul 19 14:17:08 raspberrypi kernel: [    4.584601] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.594885] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.612429] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.632804] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    Jul 19 14:17:08 raspberrypi kernel: [    4.632845] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    Jul 19 14:17:08 raspberrypi kernel: [    4.646897] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    Jul 19 14:17:08 raspberrypi kernel: [    4.646935] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    Jul 19 14:17:08 raspberrypi kernel: [    4.656739] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    Jul 19 14:17:08 raspberrypi kernel: [    4.656775] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    Jul 19 14:17:08 raspberrypi kernel: [    4.679306] addi9036 0-0064: addi9036 detected at address 0x64
    Jul 19 14:17:08 raspberrypi kernel: [    4.869159] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    Jul 19 14:17:08 raspberrypi kernel: [    4.880005] bcm2835_audio soc:audio: card created with 8 channels
    Jul 19 14:17:08 raspberrypi kernel: [    4.911444] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Jul 19 14:17:08 raspberrypi kernel: [    4.975479] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Jul 19 14:17:08 raspberrypi kernel: [    5.040563] brcmfmac: F1 signature read @0x18000000=0x15264345
    Jul 19 14:17:08 raspberrypi kernel: [    5.050014] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Jul 19 14:17:08 raspberrypi kernel: [    5.050626] usbcore: registered new interface driver brcmfmac
    Jul 19 14:17:08 raspberrypi kernel: [    5.284171] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Jul 19 14:17:08 raspberrypi kernel: [    5.300061] random: crng init done
    Jul 19 14:17:08 raspberrypi kernel: [    5.300074] random: 7 urandom warning(s) missed due to ratelimiting
    Jul 19 14:17:08 raspberrypi kernel: [    5.303674] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
    Jul 19 14:17:08 raspberrypi kernel: [    6.243941] at24 0-0056: 131072 byte 24c1024 EEPROM, writable, 32 bytes/write
    Jul 19 14:17:08 raspberrypi kernel: [    8.130668] uart-pl011 3f201000.serial: no DMA platform data
    Jul 19 14:17:08 raspberrypi kernel: [    8.483595] 8021q: 802.1Q VLAN Support v1.8
    Jul 19 14:17:08 raspberrypi udisksd[408]: udisks daemon version 2.8.1 starting
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Login Service.
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Successfully called chroot().
    Jul 19 14:17:08 raspberrypi systemd[1]: Started System Logging Service.
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Successfully dropped remaining capabilities.
    Jul 19 14:17:08 raspberrypi wpa_supplicant[436]: Successfully initialized wpa_supplicant
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: No service file found in /etc/avahi/services.
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Network interface enumeration completed.
    Jul 19 14:17:08 raspberrypi avahi-daemon[386]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 3850213600.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started Check for v3d driver.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
    Jul 19 14:17:08 raspberrypi systemd[1]: Started rng-tools.service.
    Jul 19 14:17:09 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Jul 19 14:17:09 raspberrypi systemd[1]: Started WPA supplicant.
    Jul 19 14:17:09 raspberrypi udisksd[408]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
    Jul 19 14:17:09 raspberrypi udisksd[408]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
    Jul 19 14:17:09 raspberrypi dhcpcd-run-hooks[489]: wlan0: starting wpa_supplicant
    Jul 19 14:17:09 raspberrypi systemd[1]: Reached target Network.
    Jul 19 14:17:09 raspberrypi aditof-server[385]: [2021/07/19 14:17:09:0354] NOTICE: Creating Vhost 'default' port 5000, 1 protocols, IPv6 off
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
    Jul 19 14:17:09 raspberrypi systemd[1]: Started VNC Server in Service Mode daemon.
    Jul 19 14:17:09 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
    Jul 19 14:17:09 raspberrypi udisksd[408]: Failed to load the 'mdraid' libblockdev plugin
    Jul 19 14:17:09 raspberrypi udisksd[408]: Failed to load the 'crypto' libblockdev plugin
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting Permit User Sessions...
    Jul 19 14:17:09 raspberrypi dbus-daemon[421]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.5' (uid=0 pid=408 comm="/usr/lib/udisks2/udisksd ")
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
    Jul 19 14:17:09 raspberrypi kernel: [    9.070220] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    Jul 19 14:17:09 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
    Jul 19 14:17:09 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
    Jul 19 14:17:09 raspberrypi systemd[1]: Started Permit User Sessions.
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting Light Display Manager...
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting Authorization Manager...
    Jul 19 14:17:09 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
    Jul 19 14:17:09 raspberrypi lightdm[502]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jul 19 14:17:09 raspberrypi polkitd[499]: started daemon version 0.105 using authority implementation `local' version `0.105'
    Jul 19 14:17:09 raspberrypi dbus-daemon[421]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
    Jul 19 14:17:09 raspberrypi systemd[1]: Started Authorization Manager.
    Jul 19 14:17:09 raspberrypi kernel: [    9.541689] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    Jul 19 14:17:09 raspberrypi kernel: [    9.541723] brcmfmac: power management disabled
    Jul 19 14:17:09 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
    Jul 19 14:17:09 raspberrypi vncserver-x11[497,root]: ServerManager: Server started
    Jul 19 14:17:10 raspberrypi systemd[1]: Started Disk Manager.
    Jul 19 14:17:10 raspberrypi udisksd[408]: Acquired the name org.freedesktop.UDisks2 on the system message bus
    Jul 19 14:17:10 raspberrypi vncserver-x11[497,root]: ConsoleDisplay: Cannot find a running X server on vt1
    Jul 19 14:17:10 raspberrypi kernel: [   10.301845] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Jul 19 14:17:10 raspberrypi kernel: [   10.301862] 8021q: adding VLAN 0 to HW filter on device eth0
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: eth0: waiting for carrier
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: waiting for carrier
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: carrier acquired
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: DUID 00:01:00:01:25:1e:c3:54:dc:a6:32:09:d4:73
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: IAID eb:1c:44:12
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: adding address fe80::a065:314:1672:689e
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a065:314:1672:689e.
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: New relevant interface wlan0.IPv6 for mDNS.
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: carrier lost
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: Registering new address record for fe80::a065:314:1672:689e on wlan0.*.
    Jul 19 14:17:10 raspberrypi dhcpcd[465]: wlan0: deleting address fe80::a065:314:1672:689e
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: Withdrawing address record for fe80::a065:314:1672:689e on wlan0.
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a065:314:1672:689e.
    Jul 19 14:17:10 raspberrypi avahi-daemon[386]: Interface wlan0.IPv6 no longer relevant for mDNS.
    Jul 19 14:17:11 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Jul 19 14:17:12 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 166 (plymouthd).
    Jul 19 14:17:12 raspberrypi systemd[1]: plymouth-quit-wait.service: Succeeded.
    Jul 19 14:17:12 raspberrypi systemd[1]: Started Hold until boot process finishes up.
    Jul 19 14:17:12 raspberrypi systemd[1]: Started Getty on tty1.
    Jul 19 14:17:12 raspberrypi systemd[1]: Reached target Login Prompts.
    Jul 19 14:17:12 raspberrypi systemd[1]: plymouth-start.service: Succeeded.
    Jul 19 14:17:12 raspberrypi systemd[1]: Started Light Display Manager.
    Jul 19 14:17:13 raspberrypi vncserver-x11[497,root]: ConsoleDisplay: Found running X server (pid=543, binary=/usr/lib/xorg/Xorg)
    Jul 19 14:17:13 raspberrypi raspi-config[393]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
    Jul 19 14:17:13 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
    Jul 19 14:17:15 raspberrypi kernel: [   15.050805] Bluetooth: Core ver 2.22
    Jul 19 14:17:15 raspberrypi kernel: [   15.050864] NET: Registered protocol family 31
    Jul 19 14:17:15 raspberrypi kernel: [   15.050868] Bluetooth: HCI device and connection manager initialized
    Jul 19 14:17:15 raspberrypi kernel: [   15.050883] Bluetooth: HCI socket layer initialized
    Jul 19 14:17:15 raspberrypi kernel: [   15.050889] Bluetooth: L2CAP socket layer initialized
    Jul 19 14:17:15 raspberrypi kernel: [   15.050908] Bluetooth: SCO socket layer initialized
    Jul 19 14:17:15 raspberrypi btuart[388]: bcm43xx_init
    Jul 19 14:17:15 raspberrypi btuart[388]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
    Jul 19 14:17:15 raspberrypi btuart[388]: Set BDADDR UART: b8:27:eb:e3:bb:ed
    Jul 19 14:17:15 raspberrypi btuart[388]: Set Controller UART speed to 3000000 bit/s
    Jul 19 14:17:15 raspberrypi btuart[388]: Device setup complete
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
    Jul 19 14:17:15 raspberrypi kernel: [   15.064917] Bluetooth: HCI UART driver ver 2.3
    Jul 19 14:17:15 raspberrypi kernel: [   15.064925] Bluetooth: HCI UART protocol H4 registered
    Jul 19 14:17:15 raspberrypi kernel: [   15.065032] Bluetooth: HCI UART protocol Three-wire (H5) registered
    Jul 19 14:17:15 raspberrypi kernel: [   15.065177] Bluetooth: HCI UART protocol Broadcom registered
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Jul 19 14:17:15 raspberrypi systemd[1]: Created slice system-bthelper.slice.
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting Bluetooth service...
    Jul 19 14:17:15 raspberrypi systemd[1]: Reached target Multi-User System.
    Jul 19 14:17:15 raspberrypi systemd[1]: Reached target Graphical Interface.
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Jul 19 14:17:15 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Bluetooth daemon 5.50
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Bluetooth service.
    Jul 19 14:17:15 raspberrypi systemd[1]: Reached target Bluetooth.
    Jul 19 14:17:15 raspberrypi systemd[1]: Started BluezALSA proxy.
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Starting SDP server
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
    Jul 19 14:17:15 raspberrypi systemd[1]: Startup finished in 1.616s (kernel) + 13.629s (userspace) = 15.246s.
    Jul 19 14:17:15 raspberrypi bthelper[571]: Can't init device hci0: Operation not possible due to RF-kill (132)
    Jul 19 14:17:15 raspberrypi systemd[1]: bthelper@hci0.service: Main process exited, code=exited, status=1/FAILURE
    Jul 19 14:17:15 raspberrypi systemd[1]: bthelper@hci0.service: Failed with result 'exit-code'.
    Jul 19 14:17:15 raspberrypi kernel: [   15.285633] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Jul 19 14:17:15 raspberrypi kernel: [   15.285641] Bluetooth: BNEP filters: protocol multicast
    Jul 19 14:17:15 raspberrypi kernel: [   15.285656] Bluetooth: BNEP socket layer initialized
    Jul 19 14:17:15 raspberrypi dbus-daemon[421]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.9' (uid=0 pid=567 comm="/usr/lib/bluetooth/bluetoothd ")
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Bluetooth management interface 1.14 initialized
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Sap driver initialization failed.
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: sap-server: Operation not permitted (1)
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Failed to set mode: Blocked through rfkill (0x12)
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Endpoint registered: sender=:1.10 path=/org/bluez/hci0/A2DP/SBC/Source/1
    Jul 19 14:17:15 raspberrypi bluetoothd[567]: Endpoint registered: sender=:1.10 path=/org/bluez/hci0/A2DP/SBC/Source/2
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting Hostname Service...
    Jul 19 14:17:15 raspberrypi kernel: [   15.348988] Bluetooth: RFCOMM TTY layer initialized
    Jul 19 14:17:15 raspberrypi kernel: [   15.349011] Bluetooth: RFCOMM socket layer initialized
    Jul 19 14:17:15 raspberrypi kernel: [   15.349029] Bluetooth: RFCOMM ver 1.11
    Jul 19 14:17:15 raspberrypi dhcpcd[465]: wlan0: carrier acquired
    Jul 19 14:17:15 raspberrypi kernel: [   15.361079] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    Jul 19 14:17:15 raspberrypi dhcpcd[465]: wlan0: IAID eb:1c:44:12
    Jul 19 14:17:15 raspberrypi dhcpcd[465]: wlan0: adding address fe80::6a83:2445:e43f:4d9c
    Jul 19 14:17:15 raspberrypi avahi-daemon[386]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::6a83:2445:e43f:4d9c.
    Jul 19 14:17:15 raspberrypi avahi-daemon[386]: New relevant interface wlan0.IPv6 for mDNS.
    Jul 19 14:17:15 raspberrypi avahi-daemon[386]: Registering new address record for fe80::6a83:2445:e43f:4d9c on wlan0.*.
    Jul 19 14:17:15 raspberrypi lightdm[584]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Jul 19 14:17:15 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
    Jul 19 14:17:15 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
    Jul 19 14:17:15 raspberrypi systemd[1]: Starting User Manager for UID 1000...
    Jul 19 14:17:15 raspberrypi dbus-daemon[421]: [system] Successfully activated service 'org.freedesktop.hostname1'
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Hostname Service.
    Jul 19 14:17:15 raspberrypi dhcpcd[465]: wlan0: rebinding lease of 192.168.151.115
    Jul 19 14:17:15 raspberrypi dhcpcd[465]: wlan0: probing address 192.168.151.115/24
    Jul 19 14:17:15 raspberrypi systemd[599]: Reached target Paths.
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on GnuPG network certificate management daemon.
    Jul 19 14:17:15 raspberrypi systemd[599]: Reached target Timers.
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on GnuPG cryptographic agent and passphrase cache.
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Jul 19 14:17:15 raspberrypi systemd[599]: Starting D-Bus User Message Bus Socket.
    Jul 19 14:17:15 raspberrypi systemd[599]: Listening on D-Bus User Message Bus Socket.
    Jul 19 14:17:15 raspberrypi systemd[599]: Reached target Sockets.
    Jul 19 14:17:15 raspberrypi systemd[599]: Reached target Basic System.
    Jul 19 14:17:15 raspberrypi systemd[1]: Started User Manager for UID 1000.
    Jul 19 14:17:15 raspberrypi systemd[599]: Reached target Default.
    Jul 19 14:17:15 raspberrypi systemd[599]: Startup finished in 237ms.
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Session c1 of user pi.
    Jul 19 14:17:15 raspberrypi systemd[1]: Started Session c2 of user pi.
    Jul 19 14:17:15 raspberrypi lightdm[502]: Error opening audit socket: Protocol not supported
    Jul 19 14:17:16 raspberrypi systemd[599]: Started D-Bus User Message Bus.
    Jul 19 14:17:16 raspberrypi dhcpcd[465]: wlan0: soliciting an IPv6 router
    Jul 19 14:17:17 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=1000 pid=614 comm="/usr/bin/lxsession -s LXDE-pi -e LXDE ")
    Jul 19 14:17:17 raspberrypi systemd[599]: Starting Virtual filesystem service...
    Jul 19 14:17:17 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.Daemon'
    Jul 19 14:17:17 raspberrypi systemd[599]: Started Virtual filesystem service.
    Jul 19 14:17:17 raspberrypi kernel: [   17.370161] fuse init (API version 7.27)
    Jul 19 14:17:17 raspberrypi systemd[1]: Mounting FUSE Control File System...
    Jul 19 14:17:17 raspberrypi systemd[1]: Mounted FUSE Control File System.
    Jul 19 14:17:17 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:17:18 raspberrypi systemd[599]: Starting Virtual filesystem service - disk device monitor...
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
    Jul 19 14:17:18 raspberrypi systemd[599]: Started Virtual filesystem service - disk device monitor.
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:17:18 raspberrypi systemd[599]: Starting Virtual filesystem service - digital camera monitor...
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
    Jul 19 14:17:18 raspberrypi systemd[599]: Started Virtual filesystem service - digital camera monitor.
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:17:18 raspberrypi systemd[599]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
    Jul 19 14:17:18 raspberrypi systemd[599]: Started Virtual filesystem service - GNOME Online Accounts monitor.
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:17:18 raspberrypi systemd[599]: Starting Virtual filesystem service - Apple File Conduit monitor...
    Jul 19 14:17:18 raspberrypi gvfs-afc-volume-monitor[747]: Volume monitor alive
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
    Jul 19 14:17:18 raspberrypi systemd[599]: Started Virtual filesystem service - Apple File Conduit monitor.
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:17:18 raspberrypi systemd[599]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
    Jul 19 14:17:18 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
    Jul 19 14:17:18 raspberrypi systemd[599]: Started Virtual filesystem service - Media Transfer Protocol monitor.
    Jul 19 14:17:20 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
    Jul 19 14:17:20 raspberrypi dhcpcd[465]: wlan0: leased 192.168.151.115 for 84953 seconds
    Jul 19 14:17:20 raspberrypi avahi-daemon[386]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.151.115.
    Jul 19 14:17:20 raspberrypi avahi-daemon[386]: New relevant interface wlan0.IPv4 for mDNS.
    Jul 19 14:17:20 raspberrypi dhcpcd[465]: wlan0: adding route to 192.168.151.0/24
    Jul 19 14:17:20 raspberrypi avahi-daemon[386]: Registering new address record for 192.168.151.115 on wlan0.IPv4.
    Jul 19 14:17:20 raspberrypi dhcpcd[465]: wlan0: adding default route via 192.168.151.254
    Jul 19 14:17:29 raspberrypi dhcpcd[465]: wlan0: no IPv6 Routers available
    Jul 19 14:17:34 raspberrypi kernel: [   34.515882] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515896] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515906] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515915] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515924] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515933] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515942] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515951] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515960] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515969] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515978] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515986] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.515995] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516005] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516014] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516023] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516032] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516040] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516049] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516058] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516067] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516076] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516085] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516094] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516103] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516112] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516121] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516130] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516139] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516148] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516157] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516166] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516175] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516184] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516193] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516201] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516210] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516220] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516229] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516237] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516246] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516255] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516264] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516273] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516282] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516291] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516300] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516309] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516317] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516327] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516336] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516345] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516354] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516362] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516371] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516380] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516389] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516398] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516407] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516416] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516425] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516434] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516443] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516452] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516461] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516470] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516479] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516487] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516496] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516505] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516514] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516523] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516532] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516541] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516550] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516559] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516568] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516577] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516586] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516595] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516604] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516612] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516621] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516630] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516639] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516649] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516657] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516666] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516675] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516685] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516694] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516703] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516712] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516721] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516730] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516739] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516748] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516759] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516768] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516777] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516786] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516795] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516804] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516813] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516821] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516830] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516839] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516848] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516856] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516865] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516874] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516885] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516894] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516902] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516911] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516920] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516929] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516937] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516946] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516955] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516964] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516973] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516981] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516990] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.516999] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517010] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517019] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517027] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517036] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517045] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517054] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517062] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517071] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517080] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517089] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517097] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517106] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517115] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517124] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517134] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517143] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517152] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517161] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517170] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517179] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517187] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517196] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517205] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517214] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517222] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517231] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517240] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517249] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517259] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517268] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517277] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517286] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517294] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517303] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517312] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517321] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517330] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517338] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517347] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517356] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517365] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517373] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517384] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517393] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517402] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517411] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517420] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517428] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517437] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517446] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517455] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517463] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517472] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517481] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517490] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517498] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517509] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517518] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517527] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517535] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517544] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517553] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517562] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517570] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517579] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517588] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517597] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517606] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517614] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517623] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517634] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517643] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517652] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517660] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517669] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517678] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517687] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517696] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517705] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517714] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517723] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517732] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517741] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517750] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517760] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517769] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517778] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517787] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517796] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517804] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517813] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517822] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517831] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517840] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517849] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517858] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517867] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517876] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517885] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517894] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517903] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517912] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517921] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517930] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517938] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517947] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517956] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517966] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517974] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517983] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.517992] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518001] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518010] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518019] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518028] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518037] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518046] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518055] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518063] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518073] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518082] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518091] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518099] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518108] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518117] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518126] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518135] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518144] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518153] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518162] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518171] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518180] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518189] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518198] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518207] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518215] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518224] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518233] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518242] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518251] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518261] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518270] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518279] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518288] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518297] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518306] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518315] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518324] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518333] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518342] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518351] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518360] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518369] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518377] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518387] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518396] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518405] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518413] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518422] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518431] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518440] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518449] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518458] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518467] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518476] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518485] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518494] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518502] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518512] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518521] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518530] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518539] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518548] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518557] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518565] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518574] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518583] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518592] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518601] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518610] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518618] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518627] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518637] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518646] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518655] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518664] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518673] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518681] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518690] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518699] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518708] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518717] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518726] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518735] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518743] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518752] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518762] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518771] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518780] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518789] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518798] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518806] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518815] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518824] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518833] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518842] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518851] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518860] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518869] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518878] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518888] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518897] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518905] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518915] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518924] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518933] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518942] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518950] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518959] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518968] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518977] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518986] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.518995] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519004] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519013] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519023] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519031] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519040] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519049] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519058] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519067] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519075] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519084] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519093] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519102] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519111] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519120] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519129] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519138] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519147] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519156] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519165] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519174] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519183] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519191] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519200] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519209] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519218] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519227] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519236] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519244] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519253] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519263] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519272] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519280] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519289] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519298] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519307] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519316] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519325] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519334] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519343] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519351] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519360] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519369] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519378] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519388] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519397] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519406] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519415] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519424] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519433] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519441] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519451] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519460] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519469] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519478] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519486] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519495] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519504] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519513] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519522] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519530] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519539] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519548] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519557] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519566] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519575] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519583] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519592] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519601] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519610] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519618] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519627] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519637] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519645] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519654] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519663] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519672] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519681] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519690] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519699] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519707] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519716] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519725] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519734] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519742] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519751] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519760] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519769] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519777] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519786] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519795] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519804] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519813] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519821] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519830] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519839] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519848] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519856] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519865] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519874] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519884] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519893] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519902] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519911] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519920] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519929] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519938] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519947] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519955] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519964] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519973] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519982] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519990] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.519999] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520010] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520019] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520027] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520036] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520045] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520054] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520062] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520071] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520080] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520089] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520097] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520106] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520115] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520124] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520134] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520143] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520152] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520161] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520170] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520179] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520188] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520196] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520205] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520214] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520223] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520233] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520241] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520250] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520261] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520270] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520279] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520288] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520297] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.520306] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589071] addi9036 0-0064: could not write to register 1b80
    Jul 19 14:17:34 raspberrypi kernel: [   34.589079] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589083] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589087] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589091] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589095] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589099] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589103] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589107] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589111] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589114] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589118] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589122] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589126] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589131] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589135] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589139] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589143] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589147] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589151] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589155] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589159] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589163] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589169] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589173] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589176] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589180] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589184] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589188] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589192] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589196] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589200] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589204] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589208] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589211] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589215] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589219] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589223] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589227] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589231] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589235] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589239] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589242] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589247] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589251] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589256] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589260] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589264] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589267] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589271] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589275] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589279] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589283] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589287] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589290] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589294] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589298] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589302] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589306] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589310] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589313] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589317] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589321] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589325] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589329] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589333] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589336] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589340] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589344] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589348] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589352] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589356] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589360] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589363] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589367] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589371] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589375] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589379] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589383] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589386] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589390] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589394] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589398] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589402] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589406] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589409] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589413] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589417] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589421] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589425] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589429] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589432] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589436] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589440] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589444] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589448] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589452] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589455] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589459] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589463] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589467] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589471] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589475] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589479] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589483] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589486] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589490] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589494] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589498] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589502] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589507] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589510] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589514] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589518] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589523] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589527] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589530] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589534] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589538] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589542] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589546] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589550] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589554] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589557] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589561] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589565] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589569] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589573] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589577] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589581] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589584] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589588] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589592] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589596] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589600] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589604] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589607] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589611] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589615] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589619] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589623] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589627] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589631] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589635] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589639] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589643] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589647] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589651] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589654] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589658] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589662] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589666] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589670] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589674] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589678] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589681] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589685] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589689] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589693] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589697] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589701] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589705] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589709] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589713] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589717] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589720] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589725] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589728] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589732] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589736] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589740] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589744] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589748] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589752] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589756] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589760] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589764] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589768] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589772] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589776] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589779] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589783] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589787] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589791] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589795] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589799] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589803] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589807] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589810] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589814] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589818] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589822] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589826] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589830] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589834] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589838] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589841] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589845] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589849] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589856] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589860] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589864] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589868] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589871] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589875] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589879] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589883] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589887] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589891] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589895] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589898] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589902] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589906] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589910] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589914] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589918] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589921] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589925] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589929] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589933] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589937] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589941] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589944] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589948] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589952] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589956] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589960] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589964] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589967] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589971] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589975] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589979] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589983] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589987] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589991] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589994] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.589998] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590002] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590007] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590011] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590014] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590018] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590022] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590026] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590030] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590034] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590037] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590041] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590045] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590049] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590053] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590057] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590060] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590064] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590068] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590072] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590076] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590080] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590083] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590087] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590091] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590095] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590099] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590103] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590107] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590111] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590114] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590118] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590122] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590126] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590131] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590135] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590139] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590143] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590147] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590151] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590155] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590159] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590163] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590166] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590170] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590174] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590178] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590182] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590186] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590189] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590193] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590197] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590201] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590205] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590209] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590212] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590216] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590220] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590224] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590228] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590232] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590236] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590239] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590243] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590247] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590251] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590257] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590260] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590264] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590268] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590272] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590276] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590280] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590283] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590287] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590291] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590295] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590299] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590303] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590306] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590310] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590314] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590318] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590322] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590326] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590329] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590333] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590337] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590341] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590345] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590349] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590352] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590356] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590360] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590364] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590368] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590372] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590376] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590381] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590385] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590388] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590392] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590396] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590400] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590404] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590408] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590412] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590415] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590419] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590423] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590427] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590431] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590435] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590438] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590442] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590446] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590450] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590454] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590458] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590462] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590465] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590469] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590473] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590477] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590481] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590485] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590489] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590493] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590496] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590500] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590504] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590508] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590512] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590516] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590519] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590523] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590529] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590533] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590537] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590540] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590544] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590549] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590553] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590557] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590560] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590564] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590568] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590572] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590576] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590580] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590584] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590588] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590591] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590595] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590599] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590603] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590607] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590611] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590614] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590618] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590622] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590626] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590631] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590634] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590638] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590642] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590646] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590650] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590654] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590657] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590661] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590665] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590669] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590673] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590677] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590680] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590684] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590688] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590692] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590696] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590700] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590703] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590707] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590711] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590715] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590719] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590723] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590727] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590731] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590735] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590739] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590742] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590746] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590750] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590754] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590758] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590762] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590766] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590770] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590774] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590778] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590781] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590785] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590789] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590793] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590797] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590801] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590805] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590809] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590813] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590817] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590821] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590825] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590829] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590832] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590836] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590840] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590844] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590848] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590852] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590855] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590859] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590863] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590867] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590871] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590875] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590878] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590882] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590886] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590890] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590894] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590898] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590901] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590905] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590909] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590913] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590917] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590921] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590924] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590928] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590932] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590936] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590940] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590944] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590947] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590951] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590955] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590959] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590963] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590967] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590970] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590974] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590978] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590982] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590986] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590990] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590993] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.590997] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591001] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591006] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591009] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591013] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591017] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591021] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591025] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591029] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591033] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591036] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591040] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591044] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591048] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591052] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591055] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591059] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591063] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591067] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591071] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591075] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591079] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591082] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591086] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591090] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591094] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591098] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591102] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591105] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591109] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591113] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591117] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591121] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591125] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591129] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591133] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591136] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591140] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591144] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591148] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591152] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591156] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591160] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591164] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591168] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591172] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591175] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591179] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591183] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591187] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591191] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591195] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591199] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591203] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591210] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591213] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591217] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591221] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591225] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591229] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591233] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591236] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591240] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591244] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591248] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591252] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591256] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591260] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591264] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591268] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591272] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591276] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591279] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591283] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591287] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591291] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591295] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591299] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591302] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591306] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591310] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591314] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591318] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591321] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591325] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591329] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591333] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591337] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591341] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591345] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591348] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591352] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591356] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591361] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591365] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591368] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591372] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591376] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591381] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591385] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591389] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591392] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591396] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591400] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591404] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591408] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591412] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591415] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591419] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591423] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591427] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591431] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591435] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591439] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591443] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591446] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591450] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591454] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591458] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591462] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591466] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591470] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591474] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591478] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591482] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591486] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591489] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591493] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591497] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591501] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591506] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591510] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591514] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591518] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591522] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591526] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591530] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591534] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591537] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591541] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591545] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591549] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591553] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591557] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591561] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591565] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591569] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591573] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591576] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591580] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591584] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591588] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591592] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591596] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591600] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591604] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591608] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591612] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591616] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591620] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591623] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591627] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591632] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591637] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591641] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591645] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591648] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591652] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591656] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591660] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591664] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591668] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591672] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591676] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591680] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591684] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591688] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591692] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591695] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591700] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591703] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591707] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591711] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591715] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591719] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591723] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591727] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591731] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591735] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591739] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591743] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591747] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591751] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591755] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591759] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591763] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591767] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591771] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591775] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591779] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591783] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591787] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591791] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591795] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591799] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591803] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591807] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591811] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591815] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591819] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591823] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591827] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591831] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591836] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591840] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591844] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591848] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591852] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591855] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591860] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591863] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591867] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591871] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591875] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591879] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591886] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591890] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591894] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591898] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591901] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591905] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591909] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591913] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591917] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591921] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591925] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591929] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591933] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591937] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591941] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591945] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591949] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591953] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591957] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591961] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591965] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591968] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591972] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591976] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591980] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591984] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591989] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591993] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.591997] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592001] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592029] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592034] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592038] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592042] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592046] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592050] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592054] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592058] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592062] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592066] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592070] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592074] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592078] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592082] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592086] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592090] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592094] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592098] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592102] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592105] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592110] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592113] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592117] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592121] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592125] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592129] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592134] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592138] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592142] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592146] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592150] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592154] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592158] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592162] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592166] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592170] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592173] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592177] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592181] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592185] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592189] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592193] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592197] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592201] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592205] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592209] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592212] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592216] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592220] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592224] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592228] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592232] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592236] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592240] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592243] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592247] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592251] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592256] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592273] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592277] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592281] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592285] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592289] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592293] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592297] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592301] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592304] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592308] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592312] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592316] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592320] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592324] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592328] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592332] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592336] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592340] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592344] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592347] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592351] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592355] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592359] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592363] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592367] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592371] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592375] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592379] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592383] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592387] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592391] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592395] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592399] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592403] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592407] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592411] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592415] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592419] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592423] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592426] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592430] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592434] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592438] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592442] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592446] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592450] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592454] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592458] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592462] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592466] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592470] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592474] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592477] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592481] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592603] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592629] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592639] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592645] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592652] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592658] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592664] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592670] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592677] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592683] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592689] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592695] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592702] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592708] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592715] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592721] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592728] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592734] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592740] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592752] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592759] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592765] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592772] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592778] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592784] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592791] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592798] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592804] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592811] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592817] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592823] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592830] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592836] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592842] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592848] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592855] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592861] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592868] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592874] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592882] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592888] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592894] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592900] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592906] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592912] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592919] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592925] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592931] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592937] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592944] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592948] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592952] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592956] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592960] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592964] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592968] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592972] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592976] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592980] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592984] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592987] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592991] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.592995] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593000] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593004] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593008] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593012] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593016] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593020] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593024] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593028] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593032] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593036] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593040] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593044] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593048] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593051] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593055] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593059] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593063] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593067] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593071] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593075] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593079] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593083] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593087] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593091] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593095] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593098] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593102] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593107] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593111] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593115] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593119] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593123] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593127] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593133] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593137] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593140] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593144] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593148] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593153] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593157] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593161] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593165] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593169] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593173] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593176] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593180] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593184] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593188] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593192] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593196] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593200] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593204] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593208] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593212] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593216] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593220] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593223] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593227] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593231] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593235] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593239] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593243] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593247] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593251] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593257] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593261] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593265] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593269] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593273] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593277] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593281] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593285] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593288] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593292] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593296] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593300] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593304] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593308] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593312] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593316] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593320] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593324] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593328] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593332] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593336] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593340] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593343] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593347] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593352] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593356] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593360] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593364] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593368] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593372] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593376] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593381] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:34 raspberrypi kernel: [   34.593385] addi9036 0-0064: could not write to register 0
    Jul 19 14:17:35 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
    Jul 19 14:17:47 raspberrypi systemd-timesyncd[303]: Synchronized to time server for the first time 217.243.166.213:123 (2.debian.pool.ntp.org).
    Jul 19 14:17:55 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
    Jul 19 14:18:20 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.7' (uid=1000 pid=688 comm="pcmanfm --desktop --profile LXDE-pi ")
    Jul 19 14:18:20 raspberrypi systemd[599]: Starting Virtual filesystem metadata service...
    Jul 19 14:18:20 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'org.gtk.vfs.Metadata'
    Jul 19 14:18:20 raspberrypi systemd[599]: Started Virtual filesystem metadata service.
    Jul 19 14:18:34 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Activating service name='ca.desrt.dconf' requested by ':1.20' (uid=1000 pid=935 comm="gedit file:///var/log/syslog ")
    Jul 19 14:18:34 raspberrypi dbus-daemon[627]: [session uid=1000 pid=627] Successfully activated service 'ca.desrt.dconf'
    Best regards
    Dustin
  • This looks like a hardware issue. Did you buy the system directly from ADI or from a distributor?
    Andrei
  • The sensor I used so far was bought from a distributor.
    To be on the safe side, I have already ordered a new sensor, this time directly from Analog Devices. It should arrive in the next few days.
    Thank you for your patience and expertise.
    Best regards
    Dustin
