I'm trying to build the aditof_sdk on Windows 10. (https://github.com/analogdevicesinc/aditof_sdk/blob/master/doc/windows/build_instructions.md)
The line I entered is the first below, after which follows the message I received from the command window.
cmake -DCMAKE_PREFIX_PATH="C:\projects\aditof-sdk\deps\glog\build_0_3_5\local_path\glog;C:\projects\aditof-sdk\deps\protobuf\build_3_9_0\local_path\protobuf;C:\projects\aditof-sdk\deps\libwebsockets\build_3_1\local_path\websockets" -G "Visual Studio 14 2015 Win64" -DOPENSSL_INCLUDE_DIRS="C:\OpenSSL-Win64\include" -DWITH_EXAMPLES=off ..
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- Selecting Windows SDK version to target Windows 10.0.19041.
-- The C compiler identification is MSVC 19.0.24215.1
-- The CXX compiler identification is MSVC 19.0.24215.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio 14.0/VC/bin/x86_amd64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Deprecation Warning at sdk/CMakeLists.txt:1 (cmake_minimum_required):
CMake.
CMake Error at C:/Program Files/CMake/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:218 (message):
Could NOT find Protobuf (missing: Protobuf_LIBRARIES Protobuf_INCLUDE_DIR)
(Required is at least version "3.9.0")
Call Stack (most recent call first):
C:/Program Files/CMake/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:582 (_FPHSA_FAILURE_MESSAGE)
C:/Program Files/CMake/share/cmake-3.19/Modules/FindProtobuf.cmake:628 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
sdk/CMakeLists.txt:8 (find_package)
-- Configuring incomplete, errors occurred!
See also "C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeOutput.log".
I've attached the referenced .log below. Please advise on how to proceed.
JohnCMakeOutput.logThe system is: Windows - 10.0.19041 - AMD64 Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded. Compiler: Build flags: Id flags: The output was: 0 Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Build started 1/19/2021 10:35:33 AM. Project "C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdC\CompilerIdC.vcxproj" on node 1 (default targets). PrepareForBuild: Creating directory "Debug\". Creating directory "Debug\CompilerIdC.tlog\". InitializeBuildStatus: Creating "Debug\CompilerIdC.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified. ClCompile: C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\CL.exe /c /nologo /W0 /WX- /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc140.pdb" /Gd /TC /errorReport:queue CMakeCCompilerId.c CMakeCCompilerId.c Link: C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdC.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdC.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdC.lib" /MACHINE:X64 Debug\CMakeCCompilerId.obj CompilerIdC.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdC\.\CompilerIdC.exe PostBuildEvent: for %%i in (cl.exe) do @echo CMAKE_C_COMPILER=%%~$PATH:i :VCEnd CMAKE_C_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe FinalizeBuildStatus: Deleting file "Debug\CompilerIdC.tlog\unsuccessfulbuild". Touching "Debug\CompilerIdC.tlog\CompilerIdC.lastbuildstate". Done Building Project "C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdC\CompilerIdC.vcxproj" (default targets). Build succeeded. 0 Warning(s) 0 Error(s) Time Elapsed 00:00:01.11 Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.exe" Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CompilerIdC.vcxproj" The C compiler identification is MSVC, found in "C:/Users/Owner/aditof_sdk/build/CMakeFiles/3.19.3/CompilerIdC/CompilerIdC.exe" Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded. Compiler: Build flags: Id flags: The output was: 0 Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Build started 1/19/2021 10:35:34 AM. Project "C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdCXX\CompilerIdCXX.vcxproj" on node 1 (default targets). PrepareForBuild: Creating directory "Debug\". Creating directory "Debug\CompilerIdCXX.tlog\". InitializeBuildStatus: Creating "Debug\CompilerIdCXX.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified. ClCompile: C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\CL.exe /c /nologo /W0 /WX- /Od /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"Debug\\" /Fd"Debug\vc140.pdb" /Gd /TP /errorReport:queue CMakeCXXCompilerId.cpp CMakeCXXCompilerId.cpp Link: C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\link.exe /ERRORREPORT:QUEUE /OUT:".\CompilerIdCXX.exe" /INCREMENTAL:NO /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /PDB:".\CompilerIdCXX.pdb" /SUBSYSTEM:CONSOLE /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:".\CompilerIdCXX.lib" /MACHINE:X64 Debug\CMakeCXXCompilerId.obj CompilerIdCXX.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdCXX\.\CompilerIdCXX.exe PostBuildEvent: for %%i in (cl.exe) do @echo CMAKE_CXX_COMPILER=%%~$PATH:i :VCEnd CMAKE_CXX_COMPILER=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\cl.exe FinalizeBuildStatus: Deleting file "Debug\CompilerIdCXX.tlog\unsuccessfulbuild". Touching "Debug\CompilerIdCXX.tlog\CompilerIdCXX.lastbuildstate". Done Building Project "C:\Users\Owner\aditof_sdk\build\CMakeFiles\3.19.3\CompilerIdCXX\CompilerIdCXX.vcxproj" (default targets). Build succeeded. 0 Warning(s) 0 Error(s) Time Elapsed 00:00:01.10 Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.exe" Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CompilerIdCXX.vcxproj" The CXX compiler identification is MSVC, found in "C:/Users/Owner/aditof_sdk/build/CMakeFiles/3.19.3/CompilerIdCXX/CompilerIdCXX.exe" Detecting C compiler ABI info compiled with the following output: Change Dir: C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/Program Files (x86)/MSBuild/14.0/bin/MSBuild.exe cmTC_ec0a6.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=14.0 /v:m && Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64 Copyright (C) Microsoft Corporation. All rights reserved. CMakeCCompilerABI.c cl /c /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_ec0a6.dir\Debug\\" /Fd"cmTC_ec0a6.dir\Debug\vc140.pdb" /Gd /TC /errorReport:queue "C:\Program Files\CMake\share\cmake-3.19\Modules\CMakeCCompilerABI.c" cmTC_ec0a6.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\CMakeTmp\Debug\cmTC_ec0a6.exe cmTC_ec0a6.vcxproj -> C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp/Debug/cmTC_ec0a6.pdb (Full PDB) Detecting CXX compiler ABI info compiled with the following output: Change Dir: C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/Program Files (x86)/MSBuild/14.0/bin/MSBuild.exe cmTC_ef668.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=14.0 /v:m && Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64 Copyright (C) Microsoft Corporation. All rights reserved. CMakeCXXCompilerABI.cpp cl /c /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_ef668.dir\Debug\\" /Fd"cmTC_ef668.dir\Debug\vc140.pdb" /Gd /TP /errorReport:queue "C:\Program Files\CMake\share\cmake-3.19\Modules\CMakeCXXCompilerABI.cpp" cmTC_ef668.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\CMakeTmp\Debug\cmTC_ef668.exe cmTC_ef668.vcxproj -> C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp/Debug/cmTC_ef668.pdb (Full PDB) Detecting CXX [-std:c++14] compiler features compiled with the following output: Change Dir: C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/Program Files (x86)/MSBuild/14.0/bin/MSBuild.exe cmTC_8641f.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=14.0 /v:m && Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64 Copyright (C) Microsoft Corporation. All rights reserved. feature_tests.cxx cl /c /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_8641f.dir\Debug\\" /Fd"cmTC_8641f.dir\Debug\vc140.pdb" /Gd /TP /errorReport:queue -std:c++14 C:\Users\Owner\aditof_sdk\build\CMakeFiles\feature_tests.cxx cmTC_8641f.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\CMakeTmp\Debug\cmTC_8641f.exe cmTC_8641f.vcxproj -> C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp/Debug/cmTC_8641f.pdb (Full PDB) Feature record: CXX_FEATURE:1cxx_template_template_parameters Feature record: CXX_FEATURE:1cxx_alias_templates Feature record: CXX_FEATURE:1cxx_alignas Feature record: CXX_FEATURE:1cxx_alignof Feature record: CXX_FEATURE:1cxx_attributes Feature record: CXX_FEATURE:1cxx_auto_type Feature record: CXX_FEATURE:1cxx_constexpr Feature record: CXX_FEATURE:1cxx_decltype Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types Feature record: CXX_FEATURE:1cxx_default_function_template_args Feature record: CXX_FEATURE:1cxx_defaulted_functions Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers Feature record: CXX_FEATURE:1cxx_delegating_constructors Feature record: CXX_FEATURE:1cxx_deleted_functions Feature record: CXX_FEATURE:1cxx_enum_forward_declarations Feature record: CXX_FEATURE:1cxx_explicit_conversions Feature record: CXX_FEATURE:1cxx_extended_friend_declarations Feature record: CXX_FEATURE:1cxx_extern_templates Feature record: CXX_FEATURE:1cxx_final Feature record: CXX_FEATURE:1cxx_func_identifier Feature record: CXX_FEATURE:1cxx_generalized_initializers Feature record: CXX_FEATURE:1cxx_inheriting_constructors Feature record: CXX_FEATURE:1cxx_inline_namespaces Feature record: CXX_FEATURE:1cxx_lambdas Feature record: CXX_FEATURE:1cxx_local_type_template_args Feature record: CXX_FEATURE:1cxx_long_long_type Feature record: CXX_FEATURE:1cxx_noexcept Feature record: CXX_FEATURE:1cxx_nonstatic_member_init Feature record: CXX_FEATURE:1cxx_nullptr Feature record: CXX_FEATURE:1cxx_override Feature record: CXX_FEATURE:1cxx_range_for Feature record: CXX_FEATURE:1cxx_raw_string_literals Feature record: CXX_FEATURE:1cxx_reference_qualified_functions Feature record: CXX_FEATURE:1cxx_right_angle_brackets Feature record: CXX_FEATURE:1cxx_rvalue_references Feature record: CXX_FEATURE:1cxx_sizeof_member Feature record: CXX_FEATURE:1cxx_static_assert Feature record: CXX_FEATURE:1cxx_strong_enums Feature record: CXX_FEATURE:1cxx_thread_local Feature record: CXX_FEATURE:1cxx_trailing_return_types Feature record: CXX_FEATURE:1cxx_unicode_literals Feature record: CXX_FEATURE:1cxx_uniform_initialization Feature record: CXX_FEATURE:1cxx_unrestricted_unions Feature record: CXX_FEATURE:1cxx_user_literals Feature record: CXX_FEATURE:1cxx_variadic_macros Feature record: CXX_FEATURE:1cxx_variadic_templates Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers Feature record: CXX_FEATURE:1cxx_attribute_deprecated Feature record: CXX_FEATURE:1cxx_binary_literals Feature record: CXX_FEATURE:1cxx_contextual_conversions Feature record: CXX_FEATURE:1cxx_decltype_auto Feature record: CXX_FEATURE:1cxx_digit_separators Feature record: CXX_FEATURE:1cxx_generic_lambdas Feature record: CXX_FEATURE:1cxx_lambda_init_captures Feature record: CXX_FEATURE:0cxx_relaxed_constexpr Feature record: CXX_FEATURE:1cxx_return_type_deduction Feature record: CXX_FEATURE:1cxx_variable_templates Detecting CXX [] compiler features compiled with the following output: Change Dir: C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/Program Files (x86)/MSBuild/14.0/bin/MSBuild.exe cmTC_91a66.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=14.0 /v:m && Microsoft (R) Build Engine version 14.0.25420.1 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64 Copyright (C) Microsoft Corporation. All rights reserved. feature_tests.cxx cl /c /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /GR /Fo"cmTC_91a66.dir\Debug\\" /Fd"cmTC_91a66.dir\Debug\vc140.pdb" /Gd /TP /errorReport:queue C:\Users\Owner\aditof_sdk\build\CMakeFiles\feature_tests.cxx cmTC_91a66.vcxproj -> C:\Users\Owner\aditof_sdk\build\CMakeFiles\CMakeTmp\Debug\cmTC_91a66.exe cmTC_91a66.vcxproj -> C:/Users/Owner/aditof_sdk/build/CMakeFiles/CMakeTmp/Debug/cmTC_91a66.pdb (Full PDB) Feature record: CXX_FEATURE:1cxx_template_template_parameters Feature record: CXX_FEATURE:1cxx_alias_templates Feature record: CXX_FEATURE:1cxx_alignas Feature record: CXX_FEATURE:1cxx_alignof Feature record: CXX_FEATURE:1cxx_attributes Feature record: CXX_FEATURE:1cxx_auto_type Feature record: CXX_FEATURE:1cxx_constexpr Feature record: CXX_FEATURE:1cxx_decltype Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types Feature record: CXX_FEATURE:1cxx_default_function_template_args Feature record: CXX_FEATURE:1cxx_defaulted_functions Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers Feature record: CXX_FEATURE:1cxx_delegating_constructors Feature record: CXX_FEATURE:1cxx_deleted_functions Feature record: CXX_FEATURE:1cxx_enum_forward_declarations Feature record: CXX_FEATURE:1cxx_explicit_conversions Feature record: CXX_FEATURE:1cxx_extended_friend_declarations Feature record: CXX_FEATURE:1cxx_extern_templates Feature record: CXX_FEATURE:1cxx_final Feature record: CXX_FEATURE:1cxx_func_identifier Feature record: CXX_FEATURE:1cxx_generalized_initializers Feature record: CXX_FEATURE:1cxx_inheriting_constructors Feature record: CXX_FEATURE:1cxx_inline_namespaces Feature record: CXX_FEATURE:1cxx_lambdas Feature record: CXX_FEATURE:1cxx_local_type_template_args Feature record: CXX_FEATURE:1cxx_long_long_type Feature record: CXX_FEATURE:1cxx_noexcept Feature record: CXX_FEATURE:1cxx_nonstatic_member_init Feature record: CXX_FEATURE:1cxx_nullptr Feature record: CXX_FEATURE:1cxx_override Feature record: CXX_FEATURE:1cxx_range_for Feature record: CXX_FEATURE:1cxx_raw_string_literals Feature record: CXX_FEATURE:1cxx_reference_qualified_functions Feature record: CXX_FEATURE:1cxx_right_angle_brackets Feature record: CXX_FEATURE:1cxx_rvalue_references Feature record: CXX_FEATURE:1cxx_sizeof_member Feature record: CXX_FEATURE:1cxx_static_assert Feature record: CXX_FEATURE:1cxx_strong_enums Feature record: CXX_FEATURE:1cxx_thread_local Feature record: CXX_FEATURE:1cxx_trailing_return_types Feature record: CXX_FEATURE:1cxx_unicode_literals Feature record: CXX_FEATURE:1cxx_uniform_initialization Feature record: CXX_FEATURE:1cxx_unrestricted_unions Feature record: CXX_FEATURE:1cxx_user_literals Feature record: CXX_FEATURE:1cxx_variadic_macros Feature record: CXX_FEATURE:1cxx_variadic_templates Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers Feature record: CXX_FEATURE:1cxx_attribute_deprecated Feature record: CXX_FEATURE:1cxx_binary_literals Feature record: CXX_FEATURE:1cxx_contextual_conversions Feature record: CXX_FEATURE:1cxx_decltype_auto Feature record: CXX_FEATURE:1cxx_digit_separators Feature record: CXX_FEATURE:1cxx_generic_lambdas Feature record: CXX_FEATURE:1cxx_lambda_init_captures Feature record: CXX_FEATURE:0cxx_relaxed_constexpr Feature record: CXX_FEATURE:1cxx_return_type_deduction Feature record: CXX_FEATURE:1cxx_variable_templates
Take two
[edited by: JWilliams823 at 3:55 PM (GMT -5) on 19 Jan 2021]
