Aditof_sdk
Hey there,
I am trying to set the flags for the bindings on in my SDK but I run into an error of OpenCV_Viz module is missing. This stops any flags that I am trying to set. I have tried reflashing the SD but I still run into the same error. I can't reinstall OpenCV again as the hardware does not have the capability of handling such a large download. Could you give me the steps to figuring this error out?
  • Hi!
    The images that are created for customers are reduces to minimal size. In order to solve the problem with memory could you use a bigger SD-card (most probably a 32Gb would be fine), and after flashing the image on it just resize the main partition to the size of the SD card. By doing this you allow the system to access all the memory space. This way you can update easily the OpenCV library.
    R.b.
