fopen() error: permission denied on jetson nano for ad-96tof1-ebz
Product Number: ad-96tof1-ebz
Software Version: aditof_sdk 3.1.0
I am trying to run the aditof-demo for ad96tof1 sensor and I am getting the permission denied error for fopen() function in eeprom.cpp
See the following log.
I0114 09:36:36.030292 17818 system_impl.cpp:116] SDK version: 3.1.0 | branch: HEAD | commit: 6a6ab0a
I0114 09:36:36.031961 17818 system_impl.cpp:121] SDK built with websockets version:3.1.0
I0114 09:36:36.090860 17818 sensor_enumerator_jetson.cpp:48] Looking for devices on the target: Jetson
I0114 09:36:36.095347 17818 camera_96tof1.cpp:152] Initializing camera
I0114 09:36:36.095558 17818 addi9036_sensor.cpp:149] Opening device
I0114 09:36:36.095654 17818 addi9036_sensor.cpp:167] Looking for the following cards:
I0114 09:36:36.095721 17818 addi9036_sensor.cpp:169] vi-output, addi9036 6-0064
E0114 09:36:36.120378 17818 eeprom.cpp:64] fopen() failed. Error: Permission denied
E0114 09:36:36.122148 17818 camera_96tof1.cpp:178] Failed to open EEPROM with name 24c1024
I0114 09:36:36.127333 17818 addi9036_sensor.cpp:266] Starting device 0
I0114 09:36:36.128038 17818 camera_96tof1.cpp:241] Chosen mode: near
I0114 09:36:36.128185 17818 camera_96tof1.cpp:285] Camera range for mode: near is: 250 mm and 800 mm
W0114 09:36:36.128270 17818 camera_96tof1.cpp:292] Failed to read firmware from eeprom
This is happening in every demo example.
and i observed that the eeprom mentioned in 53-aditofsdkjetson.rules does not exist in /sys/bus/i2c/devices/6-0056/. also it shows 6-0064 in above log so should we change that here in the 53-aditofsdkjetson.rules file?
please help se the proper permissions needed to run the demo.
thanks.
    Does it work if you run the demo with 'sudo'? Or that doesn't help either?
  • I was running it with "sudo'' only.
    I used i2cdetect for checking the connection and had to change the port. And after restart it worked for me.
    In current SD card image I am unable to use the internet using usb tethering and also I am unable to use the wifi adaptor also.
    I had also installed the appropriate drivers and this drives works with another jetson image.
    There was also issue with building the driver since there are no built modules in the /lib/modules/4.9.140-tegra.
    How can I resolve that?
    Alternatively, I'm trying to build the new kernel with instructions from  wiki.analog.com/.../ug_jetson on latest jetson nano image[new image taken from https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#write] for tof sensor to work.
    I did all the steps but after rebooting it seems like jetson did not boot up.
    I connected jetson to pc using PUYTTY and I was getting log there.
    Afterwords I was able tousethhe monitor via HDMI cable. Is there any specific option in kernel configuration that is responsible for dp port failure?
