AD9912: Frequency Sweep Response Time and Minimum Update Interval
Category: Datasheet/Specs
Product Number: AD9912
To generate a sweeping frequency from 260 MHz to 340 MHz using the AD9912, I need to know the response time of the accumulator when the frequency is changed.
In other words, how much time does it take for the output to change after I send a command via the serial port? I plan to continuously change the frequency by sending commands, so I'm wondering what the minimum time interval between commands can be.
Any insights on this would be greatly appreciated.
  • Thank you for posting in the Direct Digital Synthesis (DDS) community on EngineerZone!
    We appreciate you taking the time to engage with the forum. Our team has received your inquiry and will review it shortly. You can expect a response along with any relevant guidance or potential solutions within 24 hours.
    In the meantime, feel free to explore related discussions or share any additional details that might help us assist you more effectively.
    Thanks again for being part of the EngineerZone community!
  • Hi  ,
    It is dependent on your system clock as well. And it will be based on your IO_Update Pin Setup Time which is at minimum the period of your SCLK in Hz.
    All the best,
    Jules
