AD9912: Inquiry on Using an 850MHz System Clock for 260-340MHz Output
Category: Datasheet/Specs
Product Number: AD9912
I'm trying to generate an output frequency range of 260MHz to 340MHz using the AD9912. I'd like to use an 850MHz system clock. Will this be an issue?
According to the datasheet, it's possible to achieve a 400MHz output with a 1GHz system clock, so I don't anticipate any problems. However, I'd appreciate hearing from anyone who has experience using this device.
I look forward to hearing from you.
