AD9959
Recommended for New Designs
The AD9959 consists of four direct digital synthesizer (DDS)
cores that provide independent frequency, phase, and amplitude
control on each channel. This...
Datasheet
AD9959 on Analog.com
Hi
I'm using a AD9959 to generate a CW signal but get a very distorted signal on the output.
Details of my setup:
Clock input = 275 MHz, DDS multiplier not enabled
Output frequency = 60 MHz
Filter after DDS: 5-th order Chebyshev low-pass with cut-off at 79 MHz
I measure the following output:
Note the large amplitude variance from one cycle to the next. This looks significantly worse than what AD's simulator predicts, which is:
Any help will be appreciated.
Regards
Hi tvil ,
Just wanted to as if you are using a custom board or the evaluation board? Can you by any chance share what your setup looks like?
All the best,
Jules
Hi Jules
I'm using a custom board.
I read the following values back from some of the registers via SPI, if it helps:
CSR: 0x000000F6
FR1: 0x00000000
FR2: 0x00000000
CFR: 0x00000314
CFTW0: 0x37DAC37E
CPOW0: 0x00000000
ACR: 0x000013FF
LSRR: 0x00000101
RDW: 0x0001BE9E
FDW: 0x0001BE9E
CW1: 0x37DAC2BD
(Some of the modulation-related registers have non-zero values since I want to implement FMCW later. But for now I just want to get a clean single tone - as you can see modulation is disabled via CFR[23:22])
Some relevant portions from the schematic:
All of the control signals goes to a FPGA.
(There are 3 DDS devices on the board.)
Filters on output of DDSs after the transformer.
Thanks
I found cause of my problem - we were driving the amplifier at the filter input (PSA-8A+) strongly into compression which distorted the signal. If we reduce the DDS output amplitude the signal looks much better.
My next problem - I still can't seem to control the output amplitude while frequency modulation is active - as explained in this old post of mine:
https://ez.analog.com/dds/f/q-a/564852/ad9959-constant-amplitude-multiplier
Regards
TV
