ad9914
Product Number: AD9914
In my DDS output at 400Mhz some oscillations or harmonics i am exactly not getting that issue till now is coming.
My sweep time is 1microsec and my sweep range is 200-500Mhz .
and i  using a 50Mhz diff input clock and i enabled PLL and iam operating a system frequency of 2.4GHz and iam using a 3.3K resistor to ground at DAC_Rset.
can you explain why my output is only 200-280Mv and my dc offset 2.8v.
here i am giving my diff clock from FPGA with coupling capacitors 0.1 uf.is it recommended?
in my   DAC_BP pin i am getting 0.6V .is it correct or what should actually i get ?
how can i calculate and configure My DAC voltage for Max Value?
Thread Notes
