AD9914评估板一块,想通过GUI完成初步调试。按照AD9914/AD9915 Evaluation Board User Guide进行连接,并输入500M-3500M的时钟、1.8Voltage和3.3Votalge的电压。完成后,将模块连接到电脑上,但是GUI的右下角还是显示未连接,同时spectrum analyzer也理所应当的没有反应。想请问我调试的问题出在哪里?
AD9914
Recommended for New Designs
The AD9914 is a direct digital synthesizer (DDS) featuring a 12-bit DAC. The AD9914 uses advanced DDS technology, coupled with an internal high speed,...
Datasheet
AD9914 on Analog.com
Hi greenhan ,
Sorry I had to use Google Translate for this one. Correct me if the translation is wrong:
I have an AD9914 evaluation board and want to complete preliminary debugging through the GUI. Make connections according to the AD9914/AD9915 Evaluation Board User Guide and enter a clock of 500M-3500M, voltages of 1.8Voltage and 3.3Votalge. After completion, the module was connected to the computer, but the lower right corner of the GUI still showed that it was not connected, and the spectrum analyzer did not respond as it should. I would like to ask where the debugging problem lies?
I may have few things might be worth checking:
1. May I know if your computer detected the board? It might be that it was detected as a board but just needs to reprogram EEPROM. Here the link for the software.
2. Just making sure if you have used the PC mode when controlling the board.
For PC control (factory settings)
For external control
Just let me know if either of these worked.
All the best,
Jules
Hi greenhan ,
All the best,
Jules
