AD9837
Production
The AD9837 is a low power, programmable waveform generator
capable of producing sine, triangular, and square wave outputs.
Waveform generation is required...
Datasheet
AD9837 on Analog.com
Can I use AD 9837 to generate sine wave in the range of 20-50kHz, and output voltage range 50-80Vpp.
Is this something that can be done with this device and can ADI propose components that could meet this requirement?
Thanks!
Yes, the AD9837 can generate sinewaves in that frequency range. The output can be amplified using a high-voltage signal chain. You can use this collateral material as a starting point: https://www.analog.com/media/en/news-marketing-collateral/product-selection-guide/phv-high-voltage-high-current-drive-high-voltage-drive.pdf
