AD9910 RAM mode - writing whilst it is still enabled
Hi
I have found that it is not possible to send sections of the RAM samples to two different DDS chips/channels at the same time. The only workaround I have found to this is to not disable the RAM when writing the RAM samples for the DDS second chip. For reference there are 1024 RAM words in total. For example for the first channel I have written to RAM words 0-24 and for the second channel I have used RAM words 25-49, but I have first disabled the RAM for channel 1, written the RAM values for the first channel, enabled the RAM and then written the  RAM words for the second channel without disabling the RAM again. To reiterate in the manual it states that it is strongly recommended not to do this, but is this to possible erroneous values or due to damage to the RAM of the board.
Essentially I want to know whether I can write to the RAM whilst it is still enabled without damaging the board. I would really appreciate advice on this matter.
Edit Notes
fixed typos
[edited by: Strontium-bham at 8:31 AM (GMT -4) on 2 Jul 2021]
  • You did not mention if you are working with two AD9910 Evaluation Boards (EVBs) or a custom design PCB. In the case of EVBs, it is likely not possible to program RAM on two boards simultaneously. However, if you have a custom PCB, it should be possible to program RAM on two devices in parallel.
    It has been my experience that writing to RAM actually requires the RAM be enabled (contrary to the instructions). However, because RAM segments relate to Profiles, it would be difficult to properly coordinate Profile selection and RAM writes to two different devices.
    I would recommend having a single "RAM load" function that programs Profile 0 of both devices with a RAM segment spanning the length of the RAM (i.e., 0 to 1023). Then select Profile 0 and write all 1024 RAM samples to both devices (you should be able to write to RAM in both devices simultaneously). With the full set of RAM data loaded in both devices, go back to each device and program the RAM profiles with the desired address ranges for each RAM segment. You can then control the RAM data playback of both devices independently (via the Profile control pins of each device).
    Finally, to answer your last question, writing to RAM with RAM enabled will not damage the device.
