AD9913 - Electromagnetic Susceptibility Test Failure
Hello
I could find that AD9913 is failing one EMC susceptibility test: When applying 10V/m @ 250MHz, device stop working.
Test has been run using a TEMCell. AD9913 is running on a custom PCB using a 25MHz quartz. Internal clock is running at 250MHz.
Do you confirm ?
Do you have any hint to avoid this problem ?
Thank you in advance
Best Regards
STH
Parents Reply
    The device is not inherently designed to operate under EMC impairment. The introduced impairment of 10V/m @ 250MHz is at the same frequency as the system clock. This is likely imposing excessive jitter on the system clock resulting in internal setup/hold violations within the clock tree. If the intent is to operate in an impaired environment, the device should be shielded against those impairments.
    Mark
Children
No Data
