Auto clear sweep and phase accumulators
I'm a little confused in the use of  the auto clear phase accumulator
and auto clear sweep accumulator bits.
A have few questions about this:
1.What is difference in the use of bits  FR[12..15] and CRF[0..3]
and how  to  set these bits in the  frequency sweep mode for one channel.
2. From the data sheet of AD9958/59 it follows that:  "The automatic clearing function is
repeated for every subsequent I/O update or change in profile pins until the clear and release bits are reset
I/O update or change in profile pins  via the serial port" (page 27).
It is not clear what kind of change in a profile pin have in mind.
For example consider "LINEAR SWEEP MODE ENABLE—NO-DWELL BIT SET" (Fig 38).
The signal P2 on profile pin changed twice during the sweep interval -  (at point A, he rises and between points A and B, it falls).
It is logical to assume that clearing takes place only on the rising edge, but I would like to know exactly.
3. In the  frequency sweep mode I use I/O update within sweep interval to change signal amplitude.
   Does this mean that the phase accumulator (or sweep accumulator) will be immediately cleared?
Many thanks for your advice.
Vlad
    on May 9, 2011 9:45 PM over 9 years ago
    Hi Vlad,
    Bits <15:12> in Function Register 2 are global bits. This means all channels (phase accumulator and/or sweep accumulators) will be affected. So,to impact only one channel use bits <4:1> in the Channel Function Register.
    In most of ADI's DDSs, a profile change is equivalent to issuing an IO_UPDATE, however not in the multi-channel DDS (AD9958 or AD9959). Page 27 under Clear and Release Bits is in error, only the IO_UPDATE does the clearing, not a profile pin change.
    If the phase accumulator clear bits (auto/manual) or sweep accumulator clear bits (auto/manual) are set on any channel, an IO_UPDATE will reset accumulator each time it's issued.
    on Aug 2, 2018 4:21 PM over 2 years ago
    Thank you,
    EZ Admin
