ad9832 strange behavior
Hi! I am trying to build a sine waveform generator using ad9832. I already read the topics here with another people having problems with ad9832 but i didn't find the answer so i decided to post this question as a new one.
The problem is, that i am getting nothing on the output of ad9832, but in my opinion the communication with dds is correct (i have programming examples from AD). I attached my schematic to this post. Everything is similar to the datasheet of the ad9832, except the capacitor beetwen refin and agnd (i used 100nF instead of 10nF, does it make any difference ?). Very important thing is, that when i am measuring dc voltage beetwen refout and agnd i am getting something about 200mV. Here is the code for uC which steers ad9832:
void Podziel_Slowo(void)
czesc_slowa[0] = (uint8_t)(slowo&255); // less important 8 bits
czesc_slowa[1] = (uint8_t)((slowo>>8)&255);
czesc_slowa[2] = (uint8_t)((slowo>>16)&255);
czesc_slowa[3] = (uint8_t)((slowo>>24)&255); // most important 8 bits
}// this function divides 32-bit frequency word into the 8-bits parts
void InitSoftSPI_DDS(void)
//outputs MOSI, SCK, CS
DDRD |= (1<<DMOSI)|(1<<DSCK)|(1<<DCS);
PORTD |= (1<<DMOSI)|(1<<DSCK)|(1<<DCS); // everything on "1" at the beggining
}//this one inits the uC pins for soft spi communication
//here are the definitions:
#define DMOSI PD3
#define DSCK PD4
#define DCS PD5
#define DSCK_0 PORTD &= ~(1<<DSCK)
#define DSCK_1 PORTD |= (1<<DSCK)
#define DMOSI_0 PORTD &= ~(1<<DMOSI)
#define DMOSI_1 PORTD |= (1<<DMOSI)
//this function is an spi communication (sends 8-bit data)
void SendSoftSPI_DDS(uint8_t bajt)
uint8_t cnt = 128; //0b10000000
    while(cnt)
        _delay_ms(4);
        if(bajt&cnt) DMOSI_1;
        else DMOSI_0;
        _delay_ms(3); //3000
        DSCK_0;
        DSCK_1;
        cnt>>=1; //cnt = cnt>>1
//and finally this is the function which program dds:
void Wyslij_Freq_pozazakresem(void)
    Podziel_Slowo();
    PORTD &= ~(1<<DCS);    //set 0 on CS (communication active)
    SendSoftSPI_DDS(0b11111000);//turn dds into programming mode
    SendSoftSPI_DDS(0b00000000);//data = dont care
    _delay_ms(2);
    PORTD |= (1<<DCS); //
    _delay_ms(2);  //2000
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110000); / FREQ0 8L LSB
    SendSoftSPI_DDS(czesc_slowa[0]); //data
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100001); //iFREQ0 8H LSB
    SendSoftSPI_DDS(czesc_slowa[1]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110010); //FREQ0 8L MSB
    SendSoftSPI_DDS(czesc_slowa[2]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100011);    //FREQ1 8L LSB
    SendSoftSPI_DDS(czesc_slowa[3]);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //-------------------- freq1 ----------------------------
    SendSoftSPI_DDS(0b00110100);
    SendSoftSPI_DDS(czesc_slowa[0]); //freq1 8l lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100101);
    SendSoftSPI_DDS(czesc_slowa[1]); //freq1 8h lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00110110);
    SendSoftSPI_DDS(czesc_slowa[2]); //freq1 8l msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00100111);
    SendSoftSPI_DDS(czesc_slowa[3]); //freq1 8h msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //----------------phase registers = we will wrtie zeros----------------------------------
    SendSoftSPI_DDS(0b00011000); //ph0 8 lsb
    SendSoftSPI_DDS(0b00000000); //
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001001); //ph0 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011010); //ph1 8 lsb
    _delay_ms(2);
    PORTD |= (1<<DCS); //)
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001011); //ph1 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011100); //ph2 8 lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001101); //ph2 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00011110); //ph3 8 lsb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b00001111); //ph3 8 msb
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    //----------------selsrc i sync-----------
    SendSoftSPI_DDS(0b10000000);
    _delay_ms(2);
    PORTD &= ~(1<<DCS);
    SendSoftSPI_DDS(0b11000000);
    SendSoftSPI_DDS(0b00000000); // wake up ang generate : )
    _delay_ms(2);
I would like to add that the fselect pin is tied to gnd (i am using pins to select freq registers)
Today at school i checked the spi communication on the osciloscope and it looked correct (sorry i didn't shot any photo's).
Is it possible that ad9832 is broken or something ?
schemat1_black.pdf
  • hey! i was just able to get signal on the output using the code below, but the frequency using this code should be something about 22kHz but on the output the frequency is randomly from 3Hz to 60hz (my MCLK is 24Mhz). I noticed that vref = 1.21 V only for a 1 second (right after sending data), and after that it comes back to 200mV. Shouldn't it be 1.21 V for a whole time the signal is being generated ?
    here is the code, which generates this strange thing:(this time i didn't divided 32-bit frequency word, i just put the data into the instruction)
    void Wyslij_9_9khz(void)
           PORTD &= ~(1<<DCS);    //ustaw 0 na CS (transmisja aktywna)
        SendSoftSPI_DDS(0b11111000);//wprowadz ddsa w tryb programowania
        SendSoftSPI_DDS(0b00000000);//wprowadz ddsa w tryb programowania (dana dont care)
        _delay_ms(2);
        PORTD |= (1<<DCS); //ustaw 1 na CS (zatrzask 16 bitów)
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00110000); //instrukcja zapisu do FREQ0 8L LSB
        SendSoftSPI_DDS(0b00110100); //dana
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00100001); //intrukcja zapisu do FREQ0 8H LSB
        SendSoftSPI_DDS(0b00010001);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00110010); //zapis do FREQ0 8L MSB
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00100011);    //zapis do FREQ0 8H MSB
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        //--------------------tera do freq1 wpiszemy 10.4khz----------------------------
        SendSoftSPI_DDS(0b01000001); //freq1 8l lsb
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b11001100); //freq1 8h lsb
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00111000); //freq1 8l msb
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00000000); //freq1 8h msb
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        //----------------teraz wpis do rejestrow fazy----------------------------------
        SendSoftSPI_DDS(0b00000000); //wpisujemy tam zera
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        //----------------teraz wybor selsrc i sync, bedziemy sterowac pinami-----------
        _delay_ms(2);
        PORTD &= ~(1<<DCS);
        SendSoftSPI_DDS(0b00000000); //przebudzenie z programowania i generacja
        _delay_ms(2);
    }// koniec Wyslij_9_9khz
    on Dec 1, 2012 2:45 AM
    Hello Alf,
    Yes it should be 1.21v all the time.  I haven't read through your code yet but perhaps you are putting the part to sleep somehow or entering the reserved test mode?
  • Hello everyone!
    I solved my problem. PSEL0 and PSEL1 pins were tied together to gnd. Maybe that's why i was able to get nothing or random freqs on the output. When i had disconnected them from gnd and had left them floating, everything started to work... great! : ) Now my  project (signal generator using DDS technique) is completely done and 100% working! Hope i will get a good mark from a teacher ; )
