Can we short output pins MSBOUT and VOUT of AD5932?
In my application I will be using either sine wave or square wave output at a time. On my board there is no space to put analog mux to select one of two output. Can I short the two output pins of IC (MSBOUT and VOUT)
On page 16 in datasheet its mentioned that we can disable DAC by setting  DAC Enable pin to 0 and we can disable MSBOUT by MSBOUTEN=0. So if I want sine wave output I will disable MSBOUTEN and if I want square wave output I will disable DAC Enable bit and enable only MSBOUTEN.
Will this work?
Parents Reply Children
No Data
