Hi!
I'm thinking to use AD5930 as a FSK modulator. To do so, I would like to know its latency and if is possible to use it this way. The carrier frequency is 7MHz and I'm planning to use a 30MHz master clock.
Ana
Hi!
Ana
Hi Ana,
The AD5930 was designed to generate a frequency sweep...
For a FSK I'll recommend the AD9838 or AD9834... regards,
Miguel
Hi, Miguel.
I need a single DDS chip to generate FSK for transmission and frequency sweep for receiving. Do you have a recommendation?
Hi anacosta,
Im sorry but we do not have a single chip solution in the low power DDS portfolio.
You will need to use two DDS in your application.
Miguel
the AD5930 is designed to generate a frequency sweep....
why you are not using a part like the AD9834 for the modulation?
Miguel
Hi, Miguel.
At first I thought to use AD5930 because I also need a frequency sweep.
But now AD9834 is the most probable to be used in modulation.
I'm not designing yet, just researching components to prepare a basic block diagram.
Ana
