AD5933 Measurement (Status Reg)
im pretty new in programming IC's so please excuse my mistakes if they are dumb. So i use a Raspberry Pi for the communication and my code is in Python. My problem is i always keep getting 0x60, 0x66 in the Status Register which makes no sense. Just sometimes i get 0x62 which should indicate valid real/img data. As a result my measurements are wrong. I can show you my code maybe there are some mistakes
import smbus
import math
bus = smbus.SMBus(1)
ADRESSE = 0x0D
j=0
x=0
#Startfrequency
bus.write_byte_data(ADRESSE, 0x82, 0x07)          #051EB8 @10khz #028F5C @5khz
bus.write_byte_data(ADRESSE, 0x83, 0xAE)         #0F5C28 @30khz #07AE14 @15 khZ
bus.write_byte_data(ADRESSE, 0x84, 0x14)          #199999 @50khz #0CCCCC @25khz
#Frequency increment
bus.write_byte_data(ADRESSE, 0x85, 0x00)          #00014F @10hz
bus.write_byte_data(ADRESSE, 0x86, 0x41)          #004189 @500hz
bus.write_byte_data(ADRESSE, 0x87, 0x89)
#Number of increments
bus.write_byte_data(ADRESSE, 0x88, 0x00)
bus.write_byte_data(ADRESSE, 0x89, 0x96)
#Control Register Settling Time Cycles
bus.write_byte_data(ADRESSE, 0x8A, 0x00)
bus.write_byte_data(ADRESSE, 0x8B, 0x32)
#Control Register Standby Mode
bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 |0xB0)
#Control Register Initialiaze with start frequency
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x10)
  #Control Register Start Frequency Sweep
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x20)
  #Control Register Increment Frequency
bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x31)
bus.write_byte_data(ADRESSE, 0x81, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x00)
while x<8000:
  status = bus.read_byte_data(ADRESSE,0x8F)
  if status==0x62:
  real1= bus.read_byte_data(ADRESSE, 0x94)
  real2= bus.read_byte_data(ADRESSE, 0x95)
  imag1= bus.read_byte_data(ADRESSE, 0x96)
  imag2= bus.read_byte_data(ADRESSE, 0x97)
  r= (real1*256)+real2
  i= (imag1*256)+imag2
  #Magnitude Calculation
b=math.sqrt((r**2)+(i**2))
  #Gain Factior
  c=4.62e-11                #515.819e-12 #5.39e-11#6.93e-11
  #Impedance Calculation
  z=1/(b*c)
  print (z)
  print (r)
  print ( i)
  print (status)
  break
  if status!=0x62:
bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 | 0x30)
print(status)
  x=x+1
  • Meanwhile i've managed to get 0x47 in the Status Reg. which would be valid Temp., valid re/im data and frequency sweep complete. But my values seem to be wrong. I am keep getting around 65533 for Re and around 3 for Im. I would really appreciate it if anyone could help me.
    My new Code is:
    import smbus
    import math
    ADRESSE = 0x0D
    j=0
    x=0
    q=0
    #Startfrequency
    bus.write_byte_data(ADRESSE, 0x82, 0x0F)          #051EB8 @10khz #028F5C @5khz
    bus.write_byte_data(ADRESSE, 0x83, 0x5C)         #0F5C28 @30khz #07AE14 @15 khZ
    bus.write_byte_data(ADRESSE, 0x84, 0x28)          #199999 @50khz #0CCCCC @25khz
    bus.write_byte_data(ADRESSE, 0x86, 0x01)          #004189 @500hz
    bus.write_byte_data(ADRESSE, 0x87, 0x40)
    bus.write_byte_data(ADRESSE, 0x88, 0x01)
    bus.write_byte_data(ADRESSE, 0x89, 0xFF)
    bus.write_byte_data(ADRESSE, 0x8B, 0x0F)
    bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 |0xB1)
    bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x11)
    bus.write_byte_data(ADRESSE, 0x80, bus.read_byte_data(ADRESSE,0x80)&0x07 |0x21)
    while q<520:
      flag = bus.read_byte_data(ADRESSE,0x8F) & 4
      q=q+1
      if flag==4:
      #Gain Factior
      z=1/(b*c)
      print (z)
      print (r)
      print ( i)
      print (status)
      break
      if (bus.read_byte_data(ADRESSE,0x8F)&0x07)<4:
    bus.write_byte_data(ADRESSE, 0x80,bus.read_byte_data(ADRESSE,0x80)&0x07 | 0x31)
    on Jun 2, 2016 7:07 PM
    Your program looks fine to me.
    Can you try to measure the impedance you are using to calibrate the system?
    Mark
  • Hey Mark,
    thanks for your answer. Do you mean to calculate the gain factor with the values i get from the impedance? Because when i calculate it (Re:65533, Im:5) i keep getting the same Impedance for all kind of different impedances for expamle for 180k Ohm, 330k Ohm etc.
    on Jun 5, 2016 6:35 PM
    I think this application note might help you.
    Mark
  • Hey,
    yea i've already read the application note but didnt really help. I am not sure what is really wrong now. Maybe there is something wrong with my circuit.
    Meanwhile i've changed my Code a little bit and now the imaginary Datas are pretty good. So they are not around 5 anymore and real data isnt also around 65k.
    import smbus
    import math
    START_FREQ_1=0x82
    START_FREQ_2=0x83
    START_FREQ_3=0x84
    FREQ_INC_1=0x85
    FREQ_INC_2=0x86
    FREQ_INC_3=0x87
    NUM_FREQ_1=0x88
    NUM_FREQ_2=0x89
    SETTL_CYCL_1=0x8A
    SETTL_CYCL_2=0x8B
    CNTRL_1=0x80
    CNTRL_2=0x81
    STATUS_REG=0x8F
    TEMP_1=0x92
    TEMP_2=0x93
    REAL_1=0x94
    REAL_2=0x95
    IMAG_1=0x96
    IMAG_2=0x97
    ADRESSE = 0x0d
    j=0
    x=0
    c=0
    q=0
    #Startfrequency
    bus.write_byte_data(ADRESSE, START_FREQ_1, 0x0E)#051EB8 @10khz #028F5C @5khz #0EA645 @30khz (16,776mhz)
    bus.write_byte_data(ADRESSE, START_FREQ_2, 0xA6)#0F5C28 @30khz #07AE14 @15 khZ #075322 @ 15khz (16,776mhz)
    bus.write_byte_data(ADRESSE, START_FREQ_3, 0x45)#199999 @50khz #0CCCCC @25khz
    bus.write_byte_data(ADRESSE, FREQ_INC_1, 0x00)#00014F @10hz #000140 @10hz(16,776mhz)
    bus.write_byte_data(ADRESSE, FREQ_INC_2, 0x01)#004189 @500hz #003E81 @500hz (16,776mhz)
    bus.write_byte_data(ADRESSE, FREQ_INC_3, 0x40)
    bus.write_byte_data(ADRESSE, NUM_FREQ_1, 0x01)#0096 @ 150
    bus.write_byte_data(ADRESSE, NUM_FREQ_2, 0xff)#01FF @ 511
    bus.write_byte_data(ADRESSE, SETTL_CYCL_1, 0x00)
    bus.write_byte_data(ADRESSE, SETTL_CYCL_2, 0x0F)
    bus.write_byte_data(ADRESSE, CNTRL_1,bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 |0xB0)
    bus.write_byte_data(ADRESSE, CNTRL_1, bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 |0x10)
    while x<10000:
        x=x+1
    bus.write_byte_data(ADRESSE, CNTRL_1,bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 |0x20)
    status=bus.read_byte_data(ADRESSE,STATUS_REG)
    while (bus.read_byte_data(ADRESSE,STATUS_REG)&0x07)<4:
        while (bus.read_byte_data(ADRESSE,STATUS_REG)&0x02)==0:
        flag=bus.read_byte_data(ADRESSE,STATUS_REG)&2
        flag2=bus.read_byte_data(ADRESSE,STATUS_REG)&4
        if (flag==2)&(flag2!=4):
            real1= bus.read_byte_data(ADRESSE, REAL_1)
            real2= bus.read_byte_data(ADRESSE, REAL_2)
            imag1= bus.read_byte_data(ADRESSE, IMAG_1)
            imag2= bus.read_byte_data(ADRESSE, IMAG_2)
            #Temp
            bus.write_byte_data(ADRESSE, CNTRL_1, bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 |0x90)
            f=bus.read_byte_data(ADRESSE, TEMP_1)
            g=bus.read_byte_data(ADRESSE, TEMP_2)
            h=(f*256)+g
            if h<8192:
                h=h/32
            else:
                h=h-16384
                h=h/32
            #Gain Factior
            c=1.0756009e-10 #8.04780e-11
            z=1/(b*c)
            print '******************'
            print '|Z|=',int (z), 'Ohm'
            print 'RE:',r
            print 'IM:',i
            print 'Temp:', int (h), 'Grad'
            print 'Status Reg:',bus.read_byte_data(ADRESSE,STATUS_REG)
        if flag2==4:
            #Temp
            h=(f*256)+g
            if h<8192:
                h=h/32
            else:
                h=h-16384
                h=h/32
            #Gain Factior
            z=1/(b*c)
            print 'RESULT'
            print 'RE:',r
            print 'IM:',i
            break
        if (bus.read_byte_data(ADRESSE,STATUS_REG)&0x07)<4:
            bus.write_byte_data(ADRESSE, CNTRL_1,bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 | 0x30)
    #Shut Down
    bus.write_byte_data(ADRESSE, CNTRL_1,bus.read_byte_data(ADRESSE,CNTRL_1)&0x07 | 0xA0)
