DDS ad9910 - arduino
Hello guys ,
I have a AD9910 Evaluation Board and i can controlling with Pc software. So now i have project to do frequency's ramp.
Anyone knows how i controlling this board using ARDUINO ? I don't know how start . Is there a code for arduino ?
Thanks
Rick
  • Hi Rick,
    You can check this document for the basic things to do when controlling DDS evaluation boards externally.
    Mark
  • I've made all necessary connections among the AD9910 and the Arduino, but they haven't shown any changes in the output signal. I also have tried the Mbed code below, but no sucess. Got any ideia?
    #include "mbed.h"
    #include "stdio.h"
    //CONFIG PINS SPI
    SPI DDS(p5, p6, p7); // mosi, miso, sclk
    DigitalOut SPI_EN(p8); //DDS' Enable pin.
    DigitalOut IO_UPD(p9); //DDS' Output pin.
    DigitalOut RST(p10); //DDS' Reset pin.
    DigitalOut EXT_PWD(p11); //EXT_POWER_DOWN pin of DDS.
    //CONFIG SERIAL PC
    Serial pc(USBTX, USBRX); // tx, rx
    //CONIG DIGITAL OUTS
    DigitalOut Led1(LED1);
    DigitalOut Led2(LED2);
    DigitalOut Led3(LED3);
    DigitalOut Led4(LED4);
    //MAIN PROGRAM
    int main (void){
    //CONFIG INICIAL
      RST=0;
      wait_ms(1);
      EXT_PWD=0;
      wait_ms(1);
      SPI_EN = 1;
      wait_ms(1);
      IO_UPD = 0;
      wait_ms(1);
    //REGISTER DDS CONFIG
      char DDS_CONF[28]={0x00,0x00,0x00,0x00,0x00,0x40,0x08,0x20,0x1F,0x3F,0x40,0x00,0x00,0x00,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x05,0x1E,0xB8,0x52};
    //CONFIG SPI
      DDS.format(8,0);
      DDS.frequency(10000);
    //CONFIG CFR1
      SPI_EN = 0;
      DDS.write(0x00);
      for(int i=0; i<=3; i++){
      DDS.write(DDS_CONF[i]);
      SPI_EN = 1;
      wait_ms(1);
      IO_UPD = 1;
      wait_ms(1);
      IO_UPD = 0;
      Led1=1;
    //CONFIG CFR2
    SPI_EN = 0;
    DDS.write(0x01);
    for(int i=4; i<=7; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led2=1;
    //CONFIG CFR3
    SPI_EN = 0;
    DDS.write(0x02);
    for(int i=8; i<=11; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led3=1;
    //CONFIG AUXILIARY DAC CONTROL
    SPI_EN = 0;
    DDS.write(0x03);
    for(int i=12; i<=15; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led4=1;
    //CONFIG I/O UPDATE RATE
    SPI_EN = 0;
    DDS.write(0x04);
    for(int i=16; i<=19; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led1=0;
    //CONFIG FTW FREQUENCY TUNING WORD
    SPI_EN = 0;
    DDS.write(0x04);
    for(int i=20; i<=23; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led2=0;
    //CONFIG SINGLE TONE PROFILE 0
    SPI_EN = 0;
    DDS.write(0x0E);
    for(int i=24; i<=27; i++){
    SPI_EN = 1;
    wait_ms(1);
    IO_UPD = 1;
    wait_ms(1);
    IO_UPD = 0;
    Led3=0;
    Thanks in advance.
    For your program:
    1. The address for FTW should be 0x07.
    2. Eight bytes are assigned for Profile 0x0E. Having only four bytes for 0x0E does not program the FTW for the profile.
    Mark
  • Where did you find the mbed,h library? I am not getting it. Please help
  • Hi Azil,
    We're you able to get the output after the changes suggested by Mark...
    I am trying with Arduino, no success till now.
