ad9913
Hi, on the AD9913, how much worse should the phase noise be when the PLL is engaged (2x multiplication) vs.
when it is direct fed? In this specific case:
Fref: 90 MHz  = sysclk
vs.
Fref: 90MHz using PLL=2x, 180 MHz = sysclk
For a FIXED output frequency, would there be a 20*log(2) degradation? That is not clear to me since the output frequency
is actually fixed.
The data sheet does not show this kind of comparison, only residual phase noise for direct fed and absolute
phase noise for PLL=4x.
Thanks, Jerry
  • Dear Louijie, I heard about this issue with the AD9913 DDS. Could you confirm and expand on this? We have been having some intermittent problems with the DDS.
    >>There is a well-known issue with the ADD9913 wherein the serial bus gets one bit off the message it's supposed to be receiving and then remains one bit off indefinitely.  He said there was a dedicated pin on the IC which issues a command to clear the SPI input buffer so that it can get back in sync with the master.
    Do you know which pin is being referred to? We assumed it was not the master reset pin. Thanks,
    Gerald
    on Aug 2, 2018 3:39 PM over 2 years ago
    Thank you,
    EZ Admin
