AD9106 When to set RAMUPDATE and RUN bits?
According to the datasheet, you need to set the RAMUPDATA bit after the configuration. Does this include setting the RUN bit? The reason I asked is that I try to save one address cycle. My idea is:
1. Configure other registers first.
2. Do a burst SPI write to RAMUPDATE (set to 1)  and PAT_STATUS (set RUN to 1).
Will this work? Or I need to set RUN first and then RAMUPDATE?
Thanks
Tony
