AD9910's necessary pins to make its external control
I'm a student and I'm working on my first project with a DDS. My project consists in making the communication between the DDS and a MBED controller via SPI. The pins I have been using to try it are:
AT THE U5 IO HEADER:
-IO_RESET
-CSB
-SCLK
-SDO
-SDIO
AT THE U6 IO HEADER:
-IO_UPDATE
AT THE U9 IO HEADER:
-EXT_PWR_DWN (grounded)
About the IO_UPDATE and the EXT_PWR_DWN I didn't understand their behavior. Can Someone help me?
 Thanks for the attention,
Vinicius
  • Hi Vinicius,
    Check out this document for the basic things to be checked when using the DDS evaluation board via external control. As for the IO_UPDATE and EXT_PWR_DWN, the IO_UPDATE transfers programmed data from the buffers to the active registers while a high on EXT_PWR_DWN will initiate the currently programmed power down mode. If unused, it is advisable to connect this pin to ground.
    Mark
  • Hi Mark,
    I found out that I hadn't defined the MASTER_RESET status. Now I sent one pulse to it, and the SYNC_CLK output  is responding to changes in the CFR2's 22nd bit.
    Thanks for the help,
    Vinícius
