AD5144A: VSS/VDD/VLOGIC Power-Up Sequence Requirement
The user inquires about the power-up sequence for the AD5144A, specifically the order of VSS, VDD, and VLOGIC. The final answer clarifies that while the recommended sequence is VSS → VDD → VLOGIC, it is not strictly mandatory. VLOGIC should be powered up last if it is tied to the chip reference, but simultaneous power-up of VSS, VDD, and VLOGIC is generally acceptable.
Category: Datasheet/Specs
Product Number: AD5144A
I have a question regarding the power-up sequence of the AD5144A.
The AD5144A datasheet specifies the following ideal power-up sequence:
VSS → VDD → VLOGIC → digital inputs → VA/VB/VW
I would like to clarify the requirements for VSS, VDD, and VLOGIC.
  1. Why is the order VSS → VDD → VLOGIC recommended?
    Is there any internal circuit or device reliability reason that requires VSS to be powered before VDD, and VDD before VLOGIC?
  2. Is it acceptable to power up VSS, VDD, and VLOGIC simultaneously?
    In our application, these power supplies may start rising at approximately the same time.
  3. Is the specified sequence VSS → VDD → VLOGIC a mandatory requirement, or is it only an ideal/recommended sequence?
We understand that VA, VB, and VW should not be applied before the power supplies are established because of the internal protection diodes.
Could you please clarify whether simultaneous power-up of VSS, VDD, and VLOGIC is allowed and whether there are any restrictions on their relative ramp timing?
  • Hi  ,
    Thank you for using the AD5144A.
    Generally, the power-up sequence VSS → VDD → VLOGIC is recommended to digital potentiometers but there's no real harm if VDD is powered-up before VSS.
    VLOGIC however, should be powered up last of the three specifically in cases where the digital circuit's reference is tied to the chip reference (which is powered by VDD).
    Though the VLOGIC reasoning does not apply to AD5144A, to be safe, this power-up sequence is a good general tip, but not a strict rule.
    Hope this answers your questions.
    Flynn
More Content
