Linear Gain Setting Mode settable by EEPROM
The user inquired if the AD5143 can be programmed to enter linear gain setting mode after power-up without I2C commands. The final answer confirms that the AD5143 reverts to potentiometer mode after reset or power-up, and it is not possible to set it to linear gain mode without I2C commands.
Category: Datasheet/Specs
Product Number: AD5143
I plan to use the AD5143 to set gain of an amplifier during production.In normal operation I2C is not used.
One thing not completely clear to me: is it possible to programm the chip so that linear gain setting mode is active after power up without I2C commands?
I assume that this is not possible because the datasheet states "The devices restore in potentiometer mode after a reset or power-up".
Is this assumption correct?
Regards Christian
More Content
