Power supply sequence
The user inquired about the power-up sequence for VDD and VLOGIC and the impact of applying SPI signals before power-on. The final answer confirms no specific sequence is required for VDD and VLOGIC due to the POR circuit, but SPI lines must be kept in high impedance during power cycles to prevent erratic behavior through ESD diodes.
Product Number: AD5674R
Thank you always for your great support.
I would like to confirm the subject of the device mentioned above.
Are there any restrictions or recommendations regarding the order in which the VDD and VLOGIC power supplies should be turned on/off? (The datasheet does not mention this.)
Also, are there any problems if SPI-related signals are input before the power is turned on?
I understand that there are probably no restrictions on the order of the VDD and VLOGIC power supplies, but I understand that the SPI signals will fall below their rated voltage if the VLOGIC power supply is not turned on. Is this understanding correct?
More Content
